The Official Panasonic VT50 Settings Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #91 of 2198 Old 06-11-2012, 10:12 AM
Tempest261's Avatar
Liked: 26
Originally Posted by SiGGy View Post
This is what I was afraid of, and making it impossible to really calibrate the TV to reference. Without the working luminance controls the CMS is busted.
RGB 4:4:4 just means full color (no subsampling) with separated RGB channels. Granted there is two different luminance ranges for RGB. I didn't make up the definition smile.gif I'm just using what was already defined. Don't kill the messenger wink.gif
http://en.wikipedia.org/wiki/Chroma_subsampling#4:4:4_R.27G.27B.27_.28no_subsampling.29
I too am seeing blue having way too much luminance with my RGB feed (almost +30%). There is no way to compensate for it. My green error isn't as bad as you describe, but it's there.
What size/type of patterns are you using for color calibration? I've tried small,media,large windows and APL versions. As well both 75% and 100%. Even with small windows I couldn't find any linearity measuring 75% and 100%; saturation wasn't consistent. Each one gave me different results frown.gif Which makes me think the TV will not track well from 0 to 100%.
Anyone know if there is a CMS fix in the works?
I think we all need to contact Panasonic support if we ever hope to have a fix for either the CMS or non-interpolating 10pt issue. Without support calls they probably figure it's not worth the FW update.
Calibration Equipment:
Meters: X-rite i1 Pro 2, X-rite i1 Display Pro
Software: Spectracal Calman DIY, ControlCAL
Televisions:
Panasonic TC-P65VT50 (currently own)
Samsung UN55D8000 (returned) Calibration and Settings Thread
Plasma IR Removal:
Post 1 - Post 2 - Post 3
Tempest261 is offline
post #92 of 2198 Old 06-11-2012, 11:21 AM
Quoted: 46 Post(s)
Liked: 61
kevin_mahaney likes this.
Mike
wmwilker is online now
post #93 of 2198 Old 06-11-2012, 03:32 PM
rmongiovi's Avatar
Quoted: 27 Post(s)
Not shooting the messenger. Just since chroma subsampling isn't a concept that means anything with respect to RGB I wanted to make sure you didn't mean something else.
Anyway, to answer your question I'm using the 10% size and 100% luminance/100% saturation windows from the new gamut calibration disk. I can switch my blu-ray player from YCbCr 4:2:2 to YCbCr 4:4:4 and my results stay the same: where all the color luminances are on the same side (high/low) of the desired value and the color control can be used to minimize the error. But if I leave everything else the same and just switch the blu-ray player to RGB and remeasure, red and blue are suddenly about 12-15% too bright and green is about 30% too dim. And that can't be fixed with the color control.
I asked D-Nice if he'd seen this before and he said "Nope." So for the time being I'm assuming it's a problem with my unit. Amazon is sending me a replacement so we'll see.
rmongiovi is offline
post #94 of 2198 Old 06-11-2012, 11:05 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Guys you may want to try this when using ISF mode.
1. Use 96K, 4.4.4, source direct, 24p auto settings on my Oppo BDP-95. The key words are source direct when using a calibration disc for colors and gray scale. And also in my VT50.
2. Set your bright, contrast, sharp and color.
3. Start with the 10pt gray scale, then check a 10 step gray scale pattern to be sure there is not tints of other colors, and check to see if your RGB luminous output are all the same.
4. Set your CMS. I like to use delta 94 here.
5. Go back to 10pt gray scale and touch it up, make sure 20% thru 100% settings are stable (10% close to stable), recheck 10 step gray pattern and RGB luminous levels.
Tip, when first setting your 10pt gray scale, set 100 percent white first and rough it in, then go to 10% drop your lume control to 0 and make small changes to your R/B (+/- 5% should be all you need to change controls).
Then take readings on 20% thru 90% just to see how your RGB is balancing and then go back to 20% thru 90% and set your gray scale .
Always make sure your CMS and 10pt gray scale settings are stable, (+/- 2%, depending on meter).
I use AVSHD for CMS and gray scale, warm 2, gamma 2.2. I don't use any disc to set the color control (tends to make color to saturated), so I use a setting of about 47 and what please my eyes best. I use a I1pro meter and Calman DIY, connect to my VT50 via LAN.
ss
RichB likes this.
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #95 of 2198 Old 06-12-2012, 06:26 AM
Quoted: 46 Post(s)
Liked: 61
ss
I'll try that next time I mess with mine. When you set your panels gamma to 2.2 does it not make the gamma too low? I usually set mine to 2.4 on the panel and I target 2.2 in ChromaPure and I still have to adjust it to get it up to 2.2.
Mike
post #96 of 2198 Old 06-12-2012, 07:55 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Same here. I have another VT50 calibration scheduled for Friday and will see if it is the same.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #97 of 2198 Old 06-12-2012, 09:01 AM
Quoted: 46 Post(s)
Liked: 61
BTW: I called Panasonic about the luminance controls and they want me to call a local service company. This should be interesting.
Mike
post #98 of 2198 Old 06-12-2012, 12:20 PM
Tempest261's Avatar
Liked: 26
Interesting... Please update us when the tech comes out. I have a tech visiting on Thurs. for a different issue but I plan on mentioning the CMS issue to him.
Televisions:
Plasma IR Removal:
post #99 of 2198 Old 06-12-2012, 12:41 PM
Quoted: 46 Post(s)
Liked: 61
When I spoke to the guy he said they would probably change a board. I hope I haven't screwed up by messing with this but I'm going to stick it out. They aren't coming until the 22nd
Mike
post #100 of 2198 Old 06-12-2012, 08:02 PM
billharris4's Avatar
Guys, is anyone using the Disney WOW disc for basic calibration? I did some basic adjustments last night, and everything went well except for the advanced contrast test, which uses a white checkerboard pattern (also star patterns above and below). Supposedly, you adjust the contrast so that the elements labeled "ideal white" in the pattern look like white snow. But it seemed like no matter how I changed the contrast, the look of that test pattern didn't really change. Is anyone else having better luck with this? Thanks very much.
billharris4 is offline
post #101 of 2198 Old 06-12-2012, 08:45 PM
Tempest261's Avatar
Liked: 26
Contrast (white level) is tricky, and somewhat less important to "get right", at least compared to brightness (black level). Most high-end TVs don't have trouble displaying most if not all of some contrast patterns. If you can see most if not all of the pattern, I wouldn't worry about it. I'd recommend setting contrast somewhere between 70-100, whatever looks good to your eye.
Televisions:
Plasma IR Removal:
post #102 of 2198 Old 06-12-2012, 10:54 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
No not at all, but don't forget I don't have ChromaPure. I would think that you may want to make sure your Y (light level) is close to ideal for each of your 10pt IRE settings, that should take care of you hitting your gamma setting, but not to say you can neglect your other levels because you can not.
I have spent some time seeing how Calman DIY and my I1Pro works in relation to the settings for my VT50.
Probably the most time I have spent is with IRE's is of 10 to 30%, once you understand how to get the 10 to 30% stable and correct the rest of your gray scale calibration should go fairly fast. But don't forget to go back to the next lowest IRE and recheck it if you make any changes to the IRE setting above or below. Check and recheck your gray scale settings to make sure they are correct and in harmony with the other 10pt IRE's and the rest of your settings.
As far as contrast go's, you don't really want to crank that setting to high, using Warm 2 and gamma target of 2.2. If you do you will end up crushing whites and get a washed out picture. eek.gif
Anyway the THX cinema has pretty good gray scale setting's, at least on my VT50.
ss
post #103 of 2198 Old 06-13-2012, 06:03 AM
Quoted: 46 Post(s)
Liked: 61
ss
Thanks ss. Right now I have a case open with Panasonic for the luminance controls and plan to see it through. I probably won't try any more calibrations until that it resolved. I will follow your tips and see how it works. Right now I'm pretty happy with my latest Day cal with the biggest problem being a little red tinge @ 10. It is barely noticeable but knowing it's there.....biggrin.gif. I'm very pleased with the the colors now and even with the contrast @ 100 I'm only getting 45 ftL so it's not eye scorching. I would not want to watch it in a dark room though.
Again, Thanks
Mike
post #104 of 2198 Old 06-14-2012, 12:34 AM
mconner's Avatar
Quoted: 22 Post(s)
Tonight I started to watch a DVD and I noticed a purple line at the top of the picture and it ran the width of the screen. I tried a different DVD and I still got the same effect.
Normal cable, no line. I went into settings and adjusted the HD setting from 2 to 1. With the setting on 2, the full picture come thru and and 1 gives 95%.
Has anyone else noticed this and if so, is there another fix?
Home Theater * Epson Home Cinema 5030UB * Screen Innovations 110" Zero Edge * Panasonic DMP BDT500 * Def Tech BP7004 * Def Tech CLR 2002 * Def Tech BP2X * Martin Logan EM-IW * Denon AVR-X4200W * Roku 4 * Netgear R7000 Router * Sonos Connect * Chief Rack Fan * (2) Sanus CFR1615 Racks * Royal Racks Sliding Base * Klipsch RF-12SW
Music - Guitar Room * Onkyo A9070 * SVS Prime Towers * SVS SB-2000 Sub * Emovtia ERC-3 CD Player * Sonos Connect * Def Tech Studio 350's Pr * Sonos Connect Amp
mconner is offline
post #105 of 2198 Old 06-14-2012, 04:07 AM
Quoted: 1393 Post(s)
Liked: 587
mconner
Since it's not doing it on your cable source (presume that you're using a cable box) it sounds like it's your DVD player. Try another DVD player.
JimP is offline
post #106 of 2198 Old 06-14-2012, 10:30 AM
mconner's Avatar
Quoted: 22 Post(s)
Originally Posted by JimP View Post
mconner
Thanks for the reply, I will try that. My DVD player is a Denon and had never seen this. I ruled out the movies as they are new. Is the hdmi cable any possibility?
Just trying to minimize anymore expense.
mconner is offline
post #107 of 2198 Old 06-14-2012, 11:28 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Again, Thanks
Thank You for taking up the fight over the CMS Lume controls with Panasonic.
Ya I had that red tint problem with my Kuro 141 at 10% IRE and was using a much lower contrast setting. I don't have the red tint problem with my VT50, but I have given up trying to get my light level down to specs at 10% IRE.
ss
post #108 of 2198 Old 06-15-2012, 01:06 AM
WiFi-Spy's Avatar
Quoted: 352 Post(s)
Liked: 672
Again, Thanks
ss
Sometimes you might need to fine tune 10IRE by eye in a completely dark room.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #109 of 2198 Old 06-15-2012, 06:56 AM
sante64's Avatar
Hi wmwilker.
I received my new Pana VT50, last week.
I'd like setting the run up values in the CMS adjustment.
Sorry I'm not an expert, but I know the the same setting changes results depending on the panel and different condition.
Anyway I have some questions, could you help me?
1) Run up: could I use the same setting for my old (beautiful) Kuro? Could you suggest some specific setting for run up?
2) When I will finish run up what kind of setting I can use in bright room? and in the night?
Thanks in advance
Sante
sante64 is offline
post #110 of 2198 Old 06-15-2012, 07:01 AM
sante64's Avatar
Sorry is there any expert online that can help me?
Tks
Sante
sante64 is offline
post #111 of 2198 Old 06-15-2012, 07:06 AM
sante64's Avatar
Hello
Is there any expert could help me for setting the break-in values for Pana VT50?
Thanks in advance.
Sante
sante64 is offline
post #112 of 2198 Old 06-15-2012, 07:38 AM
Quoted: 46 Post(s)
Liked: 61
If you are running slides as a break in I would lower the contrast to the mid 70's and the brightness to the mid 50's. There are settings listed in this thread which you can try. D-Nice should be posting his settings soon over on the web site high def junkies.
Mike
post #113 of 2198 Old 06-15-2012, 09:17 AM
sante64's Avatar
Thank you very much.
Sante
sante64 is offline
post #114 of 2198 Old 06-15-2012, 04:15 PM
SiGGy's Avatar
Quoted: 377 Post(s)
Liked: 330
To update I did full RGB calibrations, green was the furthest off in CMS and hardest to correct for. I posted the color tracking on HDJ. RGB has no major issues. My problems up to user error 1st time through.
-SiGGy
SiGGy is offline
post #115 of 2198 Old 06-15-2012, 04:21 PM
SiGGy's Avatar
Quoted: 377 Post(s)
Liked: 330
I'd concur with D-nice.
I had to adjust green a lot in the CMS (BTW luminance for green did move a bit as I adjusted hue and saturation and it was tricky to get it dialed in just right) However I got it dialed in decent. Did you see my tracking charts on HDJ?
I have not used slides, I'm just watching mixed content and I'm past 100 hours.
-SiGGy
SiGGy is offline
post #116 of 2198 Old 06-15-2012, 04:23 PM
SiGGy's Avatar
Quoted: 377 Post(s)
Liked: 330
Has anyone noticed the noise reduction controls do anything?
Block?
Mosquito?
I have sat and played with the block NR on lots of different material and I don't see anything happening. I haven't scrutinized the mosquito NR much, I will tonight though.
-SiGGy
SiGGy is offline
post #117 of 2198 Old 06-15-2012, 11:49 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Try adjusting Blue when you are running green, I think you will find Blue has the biggest affect on green using the CMS controls.
ss
post #118 of 2198 Old 06-16-2012, 03:34 AM
rmongiovi's Avatar
Quoted: 27 Post(s)
I couldn't find anything except your CIE chart for RGB, which wasn't my issue. It's the luminance that couldn't be fixed with only the color control operational. With YCbCr all the colors were either too bright or too dim so raising or lowering them all worked. With RGB some were too bright and some were too dim so what made some colors better made others worse (and verse visa).
post #119 of 2198 Old 06-16-2012, 11:01 PM
PINKTULIPS7's Avatar
Quoted: 92 Post(s)
Liked: 43
What is 10 Point White Balance?What should i use 10?or 20?
PANASONIC TC-P55VT50
HARMAN KARDON AVR 7300**PARASOUND HALO A21 250W**EMOTIVA UPA-1 200W
L & R :> POLK RTI A9 500W**POLK CSI A6 200W**POLK RTI A3 150W**POLK FXI A6 150W
PANASONIC DMP-BDT 500**SVS SB-16 ULTRA 1500W [DUAL]
PANAMAX M5400-EX
PINKTULIPS7 is offline
post #120 of 2198 Old 06-17-2012, 12:00 AM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
The 10 point white balance is your gray scale (very important), it can be found in Custom settings, advanced tab. Basically its one part of ISF calibration settings.
ss
Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65st50 Plasma Tv
