The Official Panasonic VT50 Settings Thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #2071 of 2198 Old 01-29-2014, 03:20 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Originally Posted by rahzel View Post
The C3 is based on the Colormunki Smile, which is basically an updated Chroma 5 that looks like an i1Display 2.
I agree with gadgetfreak, manually entering 0.002 should be close enough. An i1D3 or C6 are good reasonably priced meters that can measure low-light fairly accurately (good to about 0.001).
Yep, I've been eyeballing the C6, which seems like a really good meter, and reasonably priced in the realm of good meters. Though it's still $695, so I've been hesitant given that I'd be using it only on occasion and strictly for personal use... I think the i1D3 will be my next meter...
Z-Mad is offline
post #2072 of 2198 Old 01-29-2014, 03:27 PM
rahzel's Avatar
Liked: 148
In case you didn't know, the C6 is based on the D3, but it's a bit faster, includes more correction tables, is NIST certified and includes a tripod and case. The D3 itself is pretty fast already.
rahzel is offline
post #2073 of 2198 Old 01-29-2014, 03:42 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
I did see a lot of resemblance between the two in terms of the external housing, but didn't realize the C6 was literally based on the D3... Yes, I checked the specs on Spectracal's site and noted the NIST certification and other details you mentioned.... Since it seems to be more or less a "turbo" version of the D3, I'm fine with the D3 for my use... Thanks for the info!
Z-Mad is offline
post #2074 of 2198 Old 01-29-2014, 03:47 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Btw, anyone knows a good deal on an i1D3? Or is it best to just get it from Spectracal?
Z-Mad is offline
post #2075 of 2198 Old 01-30-2014, 11:02 AM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Just as an update: Got the gamma curve right this time, but still had to go to 2.6 gamma on the VT50 to be able to increase it where it needs to be in that 10 and 20% range. MLL was manually set to 0.002, which did change the curve appropriately. I am still not entirely happy. I don't seem to be benefiting from better detail, and the picture is a little too dark now overall. I feel I'm rather missing details... Plus, I still want to believe that with 2.4 gamma I am supposed to be able to get a proper 1886 curve... This was a quick "patch" job though, as I just jumped right into 10pt grayscale and corrected it.... Maybe I should start from scratch. Also, if I set the MLL manually, should I skip the 0% measurement completely (i.e. use 10pt. instead of 11pt scale)? I did my share of calibrations and am not a newbie, but not a pro either and haven't quite had this situation before... so thanks for everyone's comments and experience...
Z-Mad is offline
post #2076 of 2198 Old 01-30-2014, 11:16 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4000
I think overall, next time Chad comes through I may go to a 2.3 power curve or something of the sort. To be honest, my last night mode was 2.27 avg and it looked outstanding. Id say 80% of the time 1886 looks good, but I do see some issues.
gadgtfreek is online now
post #2077 of 2198 Old 01-30-2014, 11:23 AM
DavidHir's Avatar
Quoted: 1997 Post(s)
Liked: 1638
On my VT60, I am finding some issues with bt1886 on older released titles. It's very evident the vast majority were done somewhere closer to 2.2. Even when I use 2.3 power on them, some still look to be slightly crushing - or near crushing - near black detail. Something like 2.27 might be almost perfect on these at least to my subjective take on them. Some catalogs look fine with bt1886 though.
bt1886 is looking very good on almost all newer releases - although 2.3 power still looks damn good also and at times a little preferable.
I watch mostly Blu-ray and haven't done a lot of comparions to cable, but usually go with 2.3 on 60hz (as it was calibrated to that) which looks very good as my bt1886 was calibrated at 96hz and will for sure crush on 60hz material since the black levels are higher.
DavidHir is offline
post #2078 of 2198 Old 01-30-2014, 11:43 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4000
I think for dark room blu-rays, 1886 would be fine all the time.
I may aim for a 1080p/24 96hz cal for "night mode" and a 1080p/60 power power curve for a regular mode.
post #2079 of 2198 Old 01-30-2014, 11:52 AM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Yeah, I am starting to wonder if 1886 is truly the best way to go... Theoretically it sounds good, but like you said, I am also experiencing issues with it and am not quite seeing the benefits yet.... I'll still give it a shot with a calibration from scratch and with a better meter, but currently it's not yet working for me... My 2.3 power curve calibration from before still looks better to me too... Let's see...
Z-Mad is offline
post #2080 of 2198 Old 01-30-2014, 11:55 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4000
My biggest issue with the 1886 mode is that I cant stand to look at the 2.2 gamma day mode now lol.
post #2081 of 2198 Old 01-30-2014, 11:59 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
I like the 2.3 power with a taper at the lower end, there is a custom gamma that goes from 2.1 to 2.3 in Calman that I used for that calibration. Gadget completely agree on 2.2 how did we ever stomach that ? lol
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #2082 of 2198 Old 01-30-2014, 01:04 PM
Quoted: 1701 Post(s)
Liked: 731
Z-Mad
Back when I was trying to calibrate my 65VT50, I found that using a 5% size window with an 18%-23% surround, would move the gamma curve so that by using a gamma setting in the VT50 of 2.4 would be very close to 2.2 in the calibration software without much adjustment.
When I used a 5% windows pattern(without the APL surround),I'd have to make some pretty large adjustments to achieve a 2.2 gamm. I think what was happening was that the extra energy that would have gone into the surround wound up brightening up the windows pattern, thus making the adjustments more severe to push it down. Those calibration I thought looked dark even in a fairly dim room. Additionally, if you're making severe 10 pt white balance adjustment, run a 20 pt white balance and see what your inbetween points are doing. There was an article back during the time that the VT30 was the current set that recommended only doing a 2 pt as attempting to do a 10 pt could possibly hurt as these values shift around as the overall brightness of the scene changes.
In case you don't know, this whole which type of pattern has been argued to death here on AVS. I figured that even if I wasn't doing it the most correct way, I like the picture better anyway and I don't find myself thinking that the picture is too dark.
Best of luck figuring this out.
JimP is online now
post #2083 of 2198 Old 01-30-2014, 01:05 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
LOL, I hear ya... I'll tell you one thing, the 1886 based on 2.6 gamma on VT50 does produce some deep picture: the blacks are incredible!
Chunon, I remember we chatted about the tapered curve before... I may still look into that too. That may be a way to go and a good compromise between power and 1886...
Z-Mad is offline
post #2084 of 2198 Old 01-30-2014, 01:25 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4000
Yeah, that taper helps especially if you have a brighter room during the day.
post #2085 of 2198 Old 01-30-2014, 01:41 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Originally Posted by JimP View Post
Z-Mad
JimP, thanks for these insights and for your advice... this is very helpful info for my efforts to figure out the best way to get my calibration to where I think it should be... Indeed I have also read plenty of discussions on the best size of windows to be used etc., but have so far always stuck to the regular Calman windows... It may be time to try something different... Which source did you use for the APL windows btw? Thanks again...
Z-Mad is offline
post #2086 of 2198 Old 01-30-2014, 03:28 PM
Liked: 731
As a Chromapure user, I use an Accupel 5000 signal generator. I would recommend Mascorir's disk but the problem there is that there is something about the colors that makes it more suited for Chromapure and not quite right for Calman. Gotta be careful about those kind of details.
I suppose you could use Mascor's disk for grayscale and gamma and then one of the disk suited for Calman for the color side of it. Mascor's disk can be downloaded free from somewhere within the display calibration section of the forum.
Maybe another Calman user can recommend a disk that has APL patterns and the color patterns suited for Calman.
JimP is online now
post #2087 of 2198 Old 01-30-2014, 04:15 PM
DavidHir's Avatar
Liked: 1638
Yep, kind of what I am doing. At least with Blu-ray, you have a standard black level and in a dark room, that just works best with bt1886. With cable and other sources, hard to say where black level is and a power curve seems probably more ideal....especially with a wider fluctuation of material in general in regard to gammas.
DavidHir is offline
post #2088 of 2198 Old 01-30-2014, 04:36 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Thanks... I found Mascior's disk and downloading it as we speak... It does look like a great disk with some awesome menus and patterns... I think I'll give it a try for the grayscale calibration, assuming the Chromapure optimization does not affect the grayscale patterns...
Z-Mad is offline
post #2089 of 2198 Old 01-30-2014, 04:48 PM
chunon's Avatar
Liked: 2208
I've used that disc a lot it is a good one for everything
65C6 OLED/65 A1E
chunon is offline
post #2090 of 2198 Old 01-30-2014, 05:01 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Good to hear that from a Calman user... I will definitely try it out. It looks like a better disc than Spectracal's... Certainly a lot more options and windows to try out...
Z-Mad is offline
post #2091 of 2198 Old 01-30-2014, 06:37 PM
Liked: 731
Be sure to read some of the thread. I believe the author acknowledges that there is a difference and that his disk was created to work best with Chromapure. Sorry.
JimP is online now
post #2092 of 2198 Old 01-31-2014, 03:53 AM
chunon's Avatar
Liked: 2208
Have you used the disc Jim? I have, Yes from a pattern structure standpoint it is optimized for chromapure but the patterns works just fine in Calman. You can use the 75/75 saturation sweep patterns for CMS work.
65C6 OLED/65 A1E
chunon is offline
post #2093 of 2198 Old 01-31-2014, 05:18 AM
Liked: 731
I have used the disk for Chromapure but not for Calman. Mascori did a phenomenal job creating it.
Here's a link that you may find answers the question about usability for Calman. Short answer is that you can but you have to reconfigure Calman. http://www.avsforum.com/t/1463980/masciors-calibration-disc/240#post_23621455
JimP is online now
post #2094 of 2198 Old 01-31-2014, 01:07 PM
chunon's Avatar
Liked: 2208
Thanks Jim not sure what settings would have to be changed, I have used the 6.5% standard windows with great success on my ST60. Hope you are enjoying your new set would be curious what observations you have so far. Feel free to PM me
65C6 OLED/65 A1E
chunon is offline
post #2095 of 2198 Old 02-03-2014, 02:01 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
As an update for those interested: I went and finally bought myself my own i1Display Pro... Of course this made all the difference in my 1886 calibration... Finally I was able to get the proper readings in the low end and a much better calibration. 2.4 gamma was actually rather higher and needed to be brought down a bit instead of being way too low when using a C3 meter... The picture looks a lot better now, and I am seeing some of those benefits of the 1886 curve clearer. It does look brighter than power curve, which is good for details of some content, but as stated before, power 2.3 looks a bit better in some cases... That custom curve chunon was talking about would be the next step... I have a Calman 5 home license, so I don't have custom curves to work with, but what would be the taper? 2.1 at 10%, 2.2 at 20-30%, 2.3 by 40%?
Z-Mad is offline
post #2096 of 2198 Old 02-03-2014, 02:20 PM
chunon's Avatar
Liked: 2208
What level if liscense do you have? and congrats on the meter upgrade smile.gif
65C6 OLED/65 A1E
chunon is offline
post #2097 of 2198 Old 02-03-2014, 02:24 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
It's a home basic license... Yeah, thanks, I'm really glad I finally upgraded the meter - it was overdue smile.gif
Z-Mad is offline
post #2098 of 2198 Old 02-03-2014, 03:04 PM
chunon's Avatar
Liked: 2208
Ahhh I will check the custom gamma curve in Calman then get back to you
Btw I started out at the Control level license upgraded to Enthusiast a couple of months ago well worth it imo
65C6 OLED/65 A1E
chunon is offline
post #2099 of 2198 Old 02-03-2014, 03:30 PM
Z-Mad's Avatar
Quoted: 330 Post(s)
Liked: 332
Great, thanks! Oh, believe me, I have looked into other licenses and want to get to enthusiast at some point: really would like to run the full color checker, custom curves, reports, etc. But had to spend the money on a better meter first smile.gif I'll upgrade the license at some point...
Z-Mad is offline
post #2100 of 2198 Old 02-03-2014, 04:26 PM
chunon's Avatar
Liked: 2208
Zmad, Hope this is helpful:
65C6 OLED/65 A1E
chunon is offline
Panasonic Viera Tc P55vt50 , Plasma Hdtv , Displays , Panasonic Viera Tc P65st50 Plasma Tv
