Best 42" hdtv for gaming for $700 or under? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-13-2012, 01:03 PM - Thread Starter
lackingvoltage's Avatar
Looking for good pq, minimal input lag and blur/judder. This will be used only for gaming. Ive had the st30 in mind but ive heard it suffers from judder in 30fps games. I currently play on a 27" crt and im happy w it besides the pq and the fact that its 4:3 rather than the current 16:9, just to give u an idea of wat im looking for. Thanks!
lackingvoltage is offline
post #2 of 8 Old 05-14-2012, 09:25 AM
xtylerx's Avatar
I think the ST50 might be a good option. I heard it has better motion in 30fps games, no double image judder instead a slight fuzziness (sounds better to me). The two main things you'll want to consider are the motion judder in 30fps games and input lag.
I just got a 60ST30 before I knew about the motion judder even existed. It annoys me alot I still havent gotten used to it after almost a month but I got the TV on an open box great price deal so returning it isnt an option anymore. I almost hope something else goes wrong with it so Panasonic covers it and gives a refund or an ST50 replacement(sad).
xtylerx is offline
post #3 of 8 Old 05-14-2012, 11:06 AM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
There is no 42" st50 if he is lucky he may find a ut50..
CaTaSTrOphiK is offline
post #4 of 8 Old 05-14-2012, 11:14 AM
Dstew419's Avatar
Dstew419 is offline
post #5 of 8 Old 05-14-2012, 11:58 AM
sage11x's Avatar
Quoted: 731 Post(s)
Liked: 808
The st30 does not suffer 'judder'-- it properly displays 30fps games as they were meant to be displayed. For what it's worth I have played several 30fps games on my 50" S30 with no ill affect. Of course, as soon as I play anything at 60 I'm disabled from playing anything at 30 for the rest of my session!
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #6 of 8 Old 05-14-2012, 02:41 PM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
Are you telling us your 60 and can't handle someone half your age?
PathofNeo is offline
post #7 of 8 Old 05-14-2012, 02:43 PM
Jawzey's Avatar
Hey man, I'm looking to buy a Plasma for that same reason as you, as well as for watching sports.
Anyways, Paul's TVs has like 15 or so Panasonic 42" UT50's left in stock. I already put an order for mine. The UT50 I heard is a real winner this year, and it's around $700 so it certainly satisfies your budget. I'd definitely look into those if you haven't.
Jawzey is offline
post #8 of 8 Old 05-14-2012, 02:52 PM
PathofNeo's Avatar
Quoted: 67 Post(s)
Liked: 26
Join us in the UT50 club. I believe the UT50 is the hottest display this year by Panasonic. Upgraded panel, lack of filter for crisp motion picture, 3D with minimal crosstalk using 48hz, blacks that match upper models (read in UT50 thread for info), and a simple disney wow calibration nets you a very good picture all for a price tag that can't be passed.
