Pioneer 5020 not powering on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-15-2012, 07:57 PM - Thread Starter
caunyd's Avatar
Hi guys. I have the opportunity to buy a Pioneer 5020 for a very good price because the TV doesn't turn on. The glass, however, is perfectly fine. Certainly I could try taking a TV repair man with me to see the TV, but that would cost me like $70 ust for the estimate. Plus, the seller is 2 hours away from me, so it is really inconvenient.
In your experience, what might be some of the problems that could cause a plasma not to turn on? I know there might be many issues that might cause this problem, so just throw out a few ideas out there, since I know nothing about TV repair. Thanks.
caunyd is offline
post #2 of 9 Old 05-16-2012, 12:01 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
#1 likely cause: Power supply went kaput, which would be the cheapest problem to address.
vinnie97 is offline
post #3 of 9 Old 05-16-2012, 09:30 AM - Thread Starter
caunyd's Avatar
Thanks for the reply Vinnie. Anything else you think it might be?
caunyd is offline
post #4 of 9 Old 05-16-2012, 10:43 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 504 Post(s)
Liked: 769
I'd be suspicious that the seller has already had the TV diagnosed and found that either the necessary parts aren't available anymore or the cost to repair is very high and is now trying to unload it to an unsuspecting buyer.
Sometimes when a power supply fails or some other board fails, that failure also takes out other boards or damages the circuitry that's on-board the panel and that often makes the TV too expensive to repair.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 9 Old 05-16-2012, 08:20 PM - Thread Starter
caunyd's Avatar
Randy thanks for the thought. If the glass is still intact, and I were somehow able to acquire a broken 5020 for parts (sometimes broken glass pioneers are available for cheap) would the repair then be feasible, Since I would have all the part necessary?
caunyd is offline
post #6 of 9 Old 05-16-2012, 09:55 PM
"Don't PM Me Bro"
Quoted: 504 Post(s)
Liked: 769
There's no way to know until a technician first attempts to diagnose the problem, then starts installing board(s) that he suspects are bad. There is circuitry that's built into the plasma panel that could be bad rendering the whole panel as a total loss, even though the glass itself is intact. Even if it was one of the replaceable boards that caused the failure, you don't even know if replacement boards are available or not. Even if you only pay a hundred bucks for the dead Kuro, you could end up spending a hundred bucks for a diagnosis, then another $400-$1200 more having boards replaced, and still the TV might not power up. No matter what you do, it is a big gamble.
If i had a dead Kuro that i wanted to sell, i'd get it fixed first so that i could get top dollar for it.
Randy
post #7 of 9 Old 05-16-2012, 11:06 PM - Thread Starter
caunyd's Avatar
Randy. I was referring to getting the dead kuro with the intact glass, and then getting another dead kuro with broken glass that turns on and has fully functioning parts, except for the glAss. Therefore I would have all the parts necessary to repair the kuro with intact glass. (Usually broken glass kuros are relatively cheap). Would this be feasible?
caunyd is offline
post #8 of 9 Old 05-17-2012, 01:28 AM
cavisboung's Avatar
cavisboung is offline
post #9 of 9 Old 05-17-2012, 07:29 AM
"Don't PM Me Bro"
Quoted: 504 Post(s)
Liked: 769
You're missing the part where i'm telling you that there is on-board circuitry that's built into the plasma panel module which is not replaceable and not repairable, and this could be the reason why the TV won't power up. In this case, you'd have to replace the whole plasma panel module and that would probably cost a few thousand dollars.
Has the seller had a technician diagnose the TV? Why is he not just getting repaired himself so he can sell it for top dollar instead of dumping it? How much is he asking for it? Is it worth it to you to take a chance and buy it then get it diagnosed yourself? Are you willing to risk the chance that the TV needs a new $2,000 panel module? Is a new panel even available anymore?
Randy
