1 out of 3 HDMI Ports Not Working on Panasonic 50" Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-17-2012, 01:06 PM - Thread Starter
Biggbrother's Avatar
I have a Panasonic VIERA TC-P50S30 50-Inch 1080p Plasma and oddly enough, one HDMI port is not working. HDMI 2 to be exact. HDMI 1 on the back, and HDMI 3 on the side are both working fine. But when I plug an HDMI device into HDMI 2 it stays grayed out on the input selection screen.
Could I have accidentally disabled it in the settings? I dug through the settings but didn't seem to find anything related, other than labeling the inputs.
I searched and all the posts I found related to problems with all the HDMI ports on similar Panasonic plasmas not working, most likely due to a bad A-Board. But I have yet to find someone having only one port not working.
Any idea on how I can fix it? If hardware is needed, I will probably just buy a splitter and split the HDMI 1 port because I know the A-Boards are expensive, and unfortunately my 1 year warranty expired on April 4
Biggbrother is offline
post #2 of 15 Old 05-17-2012, 01:58 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Did you take one of the working hdmi cables and plug it into the one you're having a problem with?
sheshechic is offline
post #3 of 15 Old 05-17-2012, 02:48 PM - Thread Starter
Yes, I have it attached to an Xbox 360 which works fine attached to the other ports.
post #4 of 15 Old 05-17-2012, 03:15 PM
XJ6
XJ6's Avatar
Originally Posted by Biggbrother View Post
...But when I plug an HDMI device into HDMI 2 it stays grayed out on the input selection screen.
Could I have accidentally disabled it in the settings? I dug through the settings but didn't seem to find anything related, other than labeling the inputs...
Are you saying you cannot select HDMI 2? Your description of the problem sounds, to me, like the HDMI2 input has been disabled previously, either by you or someone else. I can't remember how Pana organizes the menus, but I think 'Input Label' is most likely the place to fix it. What if you just set the label for HDMI2 to 'DVD' (for example)? Does it work then?
XJ6 is offline
post #5 of 15 Old 05-17-2012, 03:49 PM - Thread Starter
The problem is that it's grayed out, and it doesn't become active when I connect a cable to it. When I connect a "live" HDMI cable to it, for example from the Xbox 360, the TV will not display anything on-screen. When I check the Input Menu on-screen, the input remains grayed out as it it doesn't detect a signal. But if I connect that same wire to another HDMI port, it will display. So I know it's not the wire.
post #6 of 15 Old 05-17-2012, 04:54 PM
XJ6
XJ6's Avatar
The problem is that it's grayed out..
Sorry, I am still not sure if you have followed my suggestion. I just looked up your model's user manual and it says the label can be any one of these: "[BLANK] Blu-ray/CABLE/SATELLITE/DVD/DVD REC/DVR/GAME/HOME THTR/
RECEIVER/COMPUTER/MEDIA CTR/MEDIA EXT/VCR/CAMERA/MONITOR/AUX/
OTHER/Not used". Notice, the last option is "Not used" and when such option is selected, the input will be greyed out. Your HDMI2's label may have been set to this one ("Not used"). So, can you go the "Input labels" menu and set HDMI2 to, say, DVD? If you have already done that and it's still not working then I don't have any other ideas.
XJ6 is offline
post #7 of 15 Old 05-17-2012, 05:20 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
The bottom line is that if the input is grayed out, it's been disabled in the Setup menu. Go into the Input Labels menu and change that HDMI input's name to GAME (or something other than blank or skip).
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #8 of 15 Old 05-17-2012, 07:13 PM - Thread Starter
Sorry guys. I had a duh moment. You're right I had set it to Not Used on the Input Label screen. I mistakingly thought this meant a label was not to be used.. not disable the entire input. I labeled it "Xbox" and its working again.
Thanks for the tips!
post #9 of 15 Old 05-17-2012, 11:36 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Sorry guys. I had a duh moment. You're right I had set it to Not Used on the Input Label screen. I mistakingly thought this meant a label was not to be used.. not disable the entire input. I labeled it "Xbox" and its working again. Thanks for the tips!
The reason the input becomes unavailable when set to Skip or Not Used is so that when toggling through the inputs by repeatedly hitting the Input key, it only toggles your active inputs so you don't have to skip past the blank inputs. I set up my SIL's Panny to toggle between HDMI (cable DVR) and Component (DVD) and skipped the rest to make it really easy for her to choose between her two sources. I keep all my inputs active since i press Input then the corresponding number key to go straight to a particular input - i never toggle
Randy
post #10 of 15 Old 01-02-2013, 10:25 PM
lmosca's Avatar
I have a Panasonic TH-42PX60U TV and just got a Roku Box for Christmas. Everyone had decided that the 2nd HDMI port was faulty. Then I happened upon this thread. Thank you so much, BiggBrother! HDMI2 was indeed a "Skipped" port. By going to Input Label and renaming it Aux, it works fine. You saved me a lot of grief and money (I was going to buy a splitter box)!
lmosca is offline
post #11 of 15 Old 11-06-2013, 10:11 PM
rkdkentsushi's Avatar
Liked: 0
the hdmi1 is not working
the tv has been in the same setting since it was purchased
i've tried different hdmi cables
i've tried to connect to different devices
i've tried resetting the tv to factory setting
and the problem still persists
after all that i though...
why not do a  hard reset?
so turn off the tv and  unplug it from the wall and tv 5 minutes go by and plug it in and now it works?!?!?
and i was about to pay some one to fix it :/
hope this helps
rkdkentsushi is offline
post #12 of 15 Old 02-05-2014, 10:27 AM
Heskatron's Avatar
OMG I've been having a nightmare, all my HDMI ports had stopped working after plugging in a new laptop with HDMI output. Found this thread and changed the input labels and everything's back to normal!!!!! Cheers guys!!!!!
Heskatron is offline
post #13 of 15 Old 02-05-2014, 12:42 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
While we're on the subject of HDMI, i heartily recommend you turn the TV OFF before plugging-in or un-plugging any HDMI cables. Some devices will send voltage through the HDMI connection and i've literally seen them arc at night as i'm just about to stick it the port. Others here have fried their TV's HDMI board by hot-swapping HDMI cables with the TV on, and replacing the input board is expensive even if the parts are still availble.
It's cheap insurance to just turn the TV OFF before fiddling with HDMI cables.
Randy
post #14 of 15 Old 04-06-2014, 02:16 AM
recam's Avatar
best thing that worked for me was to reset tv to "factory settings"
recam is offline
post #15 of 15 Old 03-05-2016, 03:46 PM
lebloom's Avatar
Liked: 0
New Amazon Fire tv Has NO sound
Have my new fire tv connected to the tv with an HDMI cable but can't figure what to do to get any sound since it has only a USB connection. The tv isn't wifi ready nor is the tuner. There's no USB on my tuner. What am I to do here?
lebloom is offline
Panasonic 50 Inch Hd Plasma Display , Panasonic Viera Tc P50s30 50 Inch Plasma Hdtv
