Just bought a display model Samsung p51d450 and it has some fingerprints on the screen. What should I clean it with that is safe for the screen? Thanks!
Most plasma manufacturers recommend using a lint-free cloth (i.e. microfiber) and if needed a diluted solution of mild dish soap and water. Mine (Panasonic) recommends a dilution of 1 part dish soap per 100 parts water. Of course, you just want to wring out any excess solution after dampening the cloth before use. Congratulations on your new purchase and good luck with the display.
This question comes up every few months and we just finished up the latest round in another thread.
The best, and safest, screen cleaner, for any screen type, is a clean microfiber cloth dampened with distilled water. Period. You can warm up the distilled water if you want to. A lot of commercial cleaners can leave a residue on the panel and you never know how the chemicals will react with the various coverings that may or may not be on the panel surface. For dusting only, I use the Swifter Sweeper Unscented refills for light dusting work. For serious smudges, you can use a very little bit of a commercial cleaner if you want to but make sure you clean the area off thoroughly with distilled water after using the cleaner. And always dampen the cloth first with whatever you use. You don't want it to drip down into the bezel. Oh, and I would never use any dish soap regardless of what Panasonic says. That's the quickest way to leave a small residue that may result in a rainbow effect. You don't want to "scrub" your panel to clean it.
I just use a Swiffer duster on it once a week. I've never felt a need to use a damp cloth as I don't touch the screen so there's no fingerprints or anything to wipe away. Just normal dust that needs cleaned off.
A Swiffer is great if the only thing on the screen is dust, but other stuff like sneeze spittle or insect poop or corn-on-the-cob-juice splattered on the screen needs the damp cloth method in which case the TV needs to be turned off and be stone cold. Cleaning it when the screen is warm or hot leaves streaks and smeary looking marks in the AR coating. Do it COLD.
No need to apologize. That's what the forums are for. If you have a question or concern, ask. A lot of the posters here have been around for awhile and are more than happy to share what they know from either first hand experience or others misfortunes. Does anybody remember the story about the guy who's plasma screen was cleaned with Windex?
I've used that on the rare occasions when my niece reached up and touched the screen on a small area and it worked well. But I followed it up with a distilled water wipe. I used the little blue bottle that Kaiser gave me for cleaning my glasses so I don't know what was in it. However, as a general cleaning procedure, distilled water is still the safest, and cheapest way to go for cleaning the entire panel on a routine basis.
Eh-- I've never had any issues with either my 2006 Olevia 537h, 2008 46pz800u or my 2011 50S30. I get that distilled water is safe but chances are if you need to CLEAN the display then water might not suffice as it won't cut grease/gunk. Personally, I would rather use a mild (MILD) detergent to weaken the dirt than scrub it off with a cloth regardless of how soft it is.
to clean off of my screen so it's up to you with what you want to do with your tv. The question was asked and answered with what most consider the safest and best way to normally clean a panel. But it's your call as to what you want to do.
Regular tap water, depending on where you live, is either soft or hard. Meaning that there are minerals in the water which could scratch or damage your screen over time. Distilled water, in theory, removes most of these minerals making the water very "soft".
It seems that you're referring to hard water which has stuff like calcium. The problem with this is if you let it air dry rather than drying it with a microfiber towel, then yes, it can leave a water spot. But as long as you dry it off, I don't think there is a problem with regular tap water, if all you're concerned about is the hardness of the water.
So is there another reason not use regular tap water?
Chlorine, other chemicals. If you want to use tap water, go ahead. But I'd use filtered tap water then. A lot of folks here (myself included) obsess at times over their HDTV purchase and don't want to damage or alter in any way their pq, and there is nothing worse than having that little smudge or water spot at the very corner of the tv (where most normal folks would never see it
) staring up at you. Distilled water is guaranteed not to have any issues if you use it correctly (dampened microfiber cloth dried off quickly).
There is a coating on the screen that, if damaged, will result in tears flowing from your eyes. Your warranty will not cover that damage, possibly your homeowner's insurance may. Why would anyone take the chance of going through that?
As Otto stated, there are chemicals in tap water that are corrosive and even abrasive. And don't forget fluoride. Heck, you can't put a fish in city tap water without damaging or killing it.
Walmart sells some very good and cheap tv cleaning wipes,the ones that come in the black package. They keep their moisture very well. Just give the pack a gentle squeeze to make sure you get a fresh pack. Usually though if I ever run out of wipes, i use my spray bottle of spring water with a drop or two of dishwashing liquid and prescription glasses cleaning cloth. Wipes are just so convenient and even if they dry out i have my bottle of solution.Oh yeah, when i was a kid about 9 i tried Windex on my crt and it ate my screen up with quite a few small pores the very first time. Glad i learned my lesson early,i'm 31 now.
I'm not running slides. Right now the picture just keeps getting better, there's nothing disturbing about images right now either. I'll wait for awhile and then take some down time to play with the AVS 709 and check out the WOW disk hubby picked up too. Don't you have the WOW disk?
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
