NHL Playoffs are better on "COOL" temp setting! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-17-2012, 08:47 PM - Thread Starter
leftyguitar1963's Avatar
Quoted: 127 Post(s)
Liked: 172
How many of us have been told to set our pdps to 'Warm 1 or2' for regular viewing? This makes all the difference for regular hd & blu-ray content, but for NHL Hockey action it makes the ICE look more beige than pristine white.
Try setting your temp setting to either "Cool 1 or 2" & the ice actually looks better & not dirty looking.
After the game simply return it to your regular 'warm' setting.....
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
leftyguitar1963 is offline
post #2 of 14 Old 05-18-2012, 12:10 AM
WiFi-Spy's Avatar
Quoted: 510 Post(s)
Liked: 950
This is an optical illusion, just like laundry detergent and toothpaste... They both tint whites slightly blue, which tricks our brain into thinking it is "whiter".
Tyler Pruitt - Technical Liaison - CalMAN
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3 of 14 Old 05-18-2012, 10:55 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 172
True, but the ice still looks better blue/white, than the muddy beige white of warm1/2.
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
post #4 of 14 Old 05-18-2012, 11:02 PM
PathofNeo's Avatar
Quoted: 79 Post(s)
Liked: 26
Well lefty... you gotta keep in mind that in real life that ice isn't bright/blue. It's only when you view an LCD in torch mode and your UT50 set to Warm2 side by side will you say "Oh man that the ice on that lcd looks way too blue and unnatural". In a game after a couple minutes of skating the ice turns dark and murky. Take a look at ice from your freezer and tell me how 'bright' it really is.
Also the bright white jerseys on the screen everywhere make the ice seem duller than it actually is. So your brain is tricked... in a sense you feel as if you getting 'duped' using Warm2. But it's really showing you reality.
But all that aside, do what you think is best.
PathofNeo is offline
post #5 of 14 Old 05-19-2012, 08:43 AM
TopShelf17's Avatar
I am one as well that sees colors more realistic in cool mode.
I have always preferred cool to warm.
It works for me too.
TopShelf17 is offline
post #6 of 14 Old 05-19-2012, 05:33 PM
rahzel's Avatar
Liked: 148
/opinion. To me, whites look better... white. If grayscale is calibrated properly, white should be white, not beige.
rahzel is offline
post #7 of 14 Old 05-19-2012, 08:39 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 172
I've got a budget panny(u54, limited settings to work with). I can't dial in grayscale, if @ all, to that of a higher budget pdp that has advanced cal settings..
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
post #8 of 14 Old 05-21-2012, 07:07 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
Greyscale can still be corrected, granted you need a meter and software and it is done in the service menu but you can make significant improvements with just cuts and drives.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #9 of 14 Old 05-24-2012, 08:10 PM
Killyamomz's Avatar
I'm having some odd issues with my set and Hockey. When the camera follows the players up and down the ice, it auto adjusts the brightness - I have triple checked my settings and made sure eco/energy saving/auto brightness settings are off.
The set I'm using is a Samsung PN51E550 - if anyone has a fix for this please let me know, it's bugging me. I'm currently using the "Standard" option which has the energy star logo next to it in the menu UI. I'm starting to think that the set forces auto brightness in this setting.
Killyamomz is offline
post #10 of 14 Old 05-25-2012, 10:08 PM - Thread Starter
Quoted: 127 Post(s)
Liked: 172
try custom or another setting, anything but STD & see if that rids u of the problem...........with that said, "GO KINGS GO!!!!" The Devils have had their fun, it's the KING's Time. We're NOT repeating '93.
Sony XBR-55A1E
Sony XBR-65X850C
Sony UBP-X800
post #11 of 14 Old 05-26-2012, 04:56 AM
coolcoyote's Avatar
Cool 1 or Normal are ok in my book. Warm 2 is way over my limit in pursuing the "natural look."
But, to each his/her own.
coolcoyote is online now
post #12 of 14 Old 07-07-2012, 09:07 AM
tre74's Avatar
Picture set to STANDARD and COOL with a few other tweaks. MOVIE mode with WARM 2 looks as though there is an amber back light in every scene and everybody has liver disease.
tre74 is offline
post #13 of 14 Old 07-07-2012, 09:40 AM
sonyfan's Avatar
"Standard" Mode is not good.
I've tried calibrating in Standard and nothing seems to work very well.
Use 'Movie' and turn the cell to all the way up and adjust the Contrast and Brightness to you liking.
sonyfan is offline
post #14 of 14 Old 07-07-2012, 09:52 AM
sonyfan's Avatar
Try watching 'Ice Road Truckers' on History chan HD.
White ice yes, dirty white yes.
Blue ice in water shots and early morning sunrise or sunsets.
sonyfan is offline
