The Official Panasonic UT50 Settings/Issues Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #271 of 1606 Old 11-19-2012, 11:15 AM
PeterLewis's Avatar
Quoted: 173 Post(s)
Liked: 124
Originally Posted by anikun07 View Post
SpectraCal has a new bundle with their new C3 colorimeter and software for $150. If anyone was interested in doing their own calibration this is definately a steal.
Thanks, looks good.
Also you can buy a colormunki display which is almost like the I display pro3 for $159 on amazon and then send in your upc code to xrite for a $35 rebate.
http://www.amazon.com/Xrite-CMUNDIS-ColorMunki-Display1/dp/B0055MBQOM/ref=sr_1_2?ie=UTF8&qid=1353352286&sr=8-2&keywords=colormunki+display
http://www.xritephoto.com/ph_product_overview.aspx?promoid=212&id=1513
So once you get your rebate,thats $124 out of pocket and you use the free HCFR software version 3.0.4 which supports the colormunki display.
Both alternatives are great.
Sony OLED XBR-65A1E| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #272 of 1606 Old 11-19-2012, 12:57 PM
pcgeek543's Avatar
HDMI content setting does nothing for cinema mode. It is used for all the other modes and with it set to graphics or photos it makes the color in custom look about the same as cinema,so why would you turn it off. You can set it to photos and switch between cinema and custom or game and the colors look almost identical with the exception of customs overall brighter picture.
pcgeek543 is offline
post #273 of 1606 Old 11-19-2012, 01:29 PM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
3:2 pulldown is what converts 24 fps to 60 fps, or Hz. I think HDMI graphic is really meant for PC input and was praised because it was said to leave the source unaltered but off, I think, has no bias of input signal. Also, many settings in he service menu are unknowns to most of us so if something get changed on accident, well what was the default? We don't know. Many of us don't want to be blamed for someone else's mistake so we leave it a mystery or give links on the topic.
Just a little tidbit 3:2 pulldown setting affects de-interlacing if it not set to "on". Have you run any de-interlacing checks ? For the 2011 sets at least the HDMI graphic setting was more accurate using mid-panel brightness, if left to auto the color saturation was off, whether either of these applies to the 2012 sets I don't know but just providing a little background on how those two setting preferences evolved. You have learned much in a short time "grasshopper " smile.gif
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #274 of 1606 Old 11-19-2012, 04:43 PM
Bukley's Avatar
Here is a question, what are the best settings for the Game Mode? The benefit is supposed to be the 3ms response time, but I was curious if the picture suffers in this mode.
Bukley is offline
post #275 of 1606 Old 11-19-2012, 06:04 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I haven't tried Game Mode but I think if you used any of the calibrated color temps and used the AVSHD 709 disc for brightness and contrast it should be fine.
anikun07 is offline
post #276 of 1606 Old 11-19-2012, 08:03 PM
Bukley's Avatar
I tried some recommended settings, but the brightness is overpowering, a lot of bloom around everything, didn't really notice a performance improvement on Halo 4, gonna stick with Custom.
Bukley is offline
post #277 of 1606 Old 11-19-2012, 08:30 PM
pcgeek543's Avatar
Game and custom are identical except for 24p being greyed out and a few others options. If you set everything in game mode the same as in custom the picture will be identical. If you are a gamer and especially a cod player anything but game mode is unacceptable as there is alot of input lag.
post #278 of 1606 Old 11-20-2012, 12:40 AM
damag0r's Avatar
The white subtitle problem is still kinda bugging me. I set sharpness between 0 and 5 just depending. I'm thinking of dropping the All Drive down to like EF and see how it is. I'm just afraid I'd throw off the colors if I mess with it, but if it brings them all down equally it shouldn't take them off, correct?
Edit: Anyway, I reduced the contrast from 84 to 80 and turned the sharpness up to 20, and it seems to be helping. So I'm just going to leave it like that for now... but I can tell I'm losing a tiny bit of detail by dropping the contrast. I also hate turning up the sharpness much at all because I know all it's adding is noise, but it does give the effect of giving more defined edges to stuff like text, and the noise it's adding is hiding the dithering and the blooming a bit. If you guys think reducing the All Drive might be better I'll do that instead though. Although I think I can live with it like this.
I also cannot sit any further back in this small room, which is why I held off on buying one of these for so long... the 42" ones are all sold out everywhere but I went ahead and got the 50" since it was cheap on sale and I really wanted something which took care of the sample-and-hold eye tracking type of blur.
Edit 2: lowering the contrast and increasing the sharpness has certainly helped a LOT... it's hiding a lot of the dithering and the blooming is much less pronounced. I'm quite happy at this point. But I'm not opposed to playing with the All Drive from the service menu if you guys think it might do a better job.
Edit 3: I'm not sure if it's the lowered contrast, or the increased sharpness... or both... but it's cleaning up most of the dithering noise and whatnot. I'm just going to leave it like this unless you guys have any better ideas. I'm using Anikun's service menu settings... Custom + Norrmal color temp.. and all of his other settings, but I've dropped contrast from 84 to 80 and increased the sharpness from 0 to 20. Again, I hate increasing the sharpness, but if it hides these other artifacts I'm fine with it. I'm typically one of those people that puts sharpness between 0 and 5 though.
Also if you can give me more info on the calman special I'd appreciate it . Last time I checked their site it was very expensive for just the "enthusiast" version alone, not even counting hardware from what I can tell. But if I can get enthusiast version + a meter $150 is totally worth it to me. and I'll order it immediately.
damag0r is offline
post #279 of 1606 Old 11-20-2012, 04:46 AM
estcstm3's Avatar
Hey all great thread. I have two questions.
1) What is the difference between the R-Cut and the R-DRV? Does it correspond to high and low R? I have been in the SM plenty of times but just to review. I have downloaded the SM from http://elektrotanya.com/?q=showresult as well.
R-CUT 80
G-CUT 80
B-CUT 80
R-DRV DF
G-DRV FF
B-DRV 7C
ALL-CUT 80
ALL-DRV FF
2) Since UT and the U share the same panel (GPF15DU) would these settings work for the 60U50? (amazon has them for 798, no shipping or tax...pretty hard to pass up thats right 60 inches)
estcstm3 is offline
post #280 of 1606 Old 11-20-2012, 05:27 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I would not recommend using WB for another TV because they it's a different panel. Many people think the U50 and UT50 are basically the same and they may be similar but they are different. To understand what white balance is and how it works this tutorial on grayscale should be read.
http://www.curtpalme.com/forum/viewtopic.php?t=10457
I recommend reading through this so you know what you're doing. You can blindly follow changes in values but you don't understand why you're doing it. After reading that link the calibration charts also make sense and you can understand the accuracy of the calibration on the set that it was done on.
This is the link the Calman 5 with their C3 meter. You don't get an enthusiast license but you don't really need it do calibrate this TV. The key benefits of a higher license with the UT50 is the PC Client and some different workflows. Calman 5 Basic will have basic and advanced workflows. With the UT50 all you need is 2 point white balance to calibrate the panel itself. I use my HTPC for disc playback because it can make corrections that aren't possible to make on the display and that's where the PC Client comes in handy. Also, if you ever plan on calibrating a colorimeter with an i1 Pro photospectrometer, then you need at least a Control license.
http://store.spectracal.com/consumer/meters/spectracal-c3-with-calman-5-home-tutorial.html
anikun07 is offline
post #281 of 1606 Old 11-20-2012, 12:41 PM
damag0r's Avatar
Thanks Anikun,
estcstm3: I'd get the UT version for the 2500 FFD, personally. But if you aren't sensitive to the sample-and-hold motion blurring then there's not much point I guess. the UT versions were only $100 more at BestBuy last I checked.
damag0r is offline
post #282 of 1606 Old 11-20-2012, 01:08 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Originally Posted by damag0r View Post
Thanks Anikun,
The UT50 also has the extra processing power of 3D which is available whether watching 2D or 3D.
anikun07 is offline
post #283 of 1606 Old 11-20-2012, 02:39 PM
estcstm3's Avatar
Thanks for the replies.....I would definitely jump on the 60UT50 if it was just 898 (100 more than the 60U50). I have been on an old Phillips LCD from 2006, actually manufactured in Belgium so you know its old....hahah and I dont really notice motion blur with sports or games so Im sure the 600mhz subfield will be fine for my eye. I pulled the trigger on the 60U50 and will use the W/B setting here as a guide and read the greyscale tutorial......
With any of the settings mentioned in this thread has anybody seen excessive IR or Burn in?
estcstm3 is offline
post #284 of 1606 Old 11-20-2012, 06:59 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I haven not had much IR, but I am fairly compulsive about the possibility and I don't watch TV so I never have tickers or station watermarks on the display, only Windows background set to change every minute and programs that are in the front.
anikun07 is offline
post #285 of 1606 Old 11-20-2012, 07:21 PM
Bukley's Avatar
I've only had one problem with IR, watching the presidential debates I had the word LIVE burned into my set, I ran the vertical scrubber which helped some, and it went away completely after a day or so. I have no problems with station logos, commercial breaks keep them from being a problem, I also do a lot of gaming, but keep my sessions to under an hour or so, had minimal IR that soon went away.
Bukley is offline
post #286 of 1606 Old 11-20-2012, 07:23 PM
Bukley's Avatar
After checking the gaming mode settings again I realized I had it set to WARM2 instead of NORMAL, once I changed this setting, the blooming effect was gone, and it matched Custom mode. Still can't tell a difference in response time to be honest.
Bukley is offline
post #287 of 1606 Old 11-20-2012, 07:28 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I will also add, because someone asked about the letterboxing blending into the bezel. I've watched 3 movies this week, none of which were 1.78:1 but two of the three I thought were and the third is 1.33 but slightly letterboxed on the top and bottom. With the lights off I can't tell.
anikun07 is offline
post #288 of 1606 Old 11-20-2012, 07:48 PM
Xavier Roque's Avatar
Hey since the settings page is not up can you tell me what it was before I have the same problem and would like to try what you did. Thanks
Xavier Roque is offline
post #289 of 1606 Old 11-20-2012, 11:56 PM
damag0r's Avatar
Just use Anikun's settings on the previous page. (including his service menu settings). I personally dropped his contrast from 84 to 80 though, because at 84 I was getting some blooming.
damag0r is offline
post #290 of 1606 Old 11-21-2012, 11:37 PM
pcgeek543's Avatar
My default wb for warm was very very close to Anikun's visually,i used his for warm and put in my default warm for normal and i can switch between normal and warm2 and there is not alot of difference. My default has a very slight pink in the white and the image is a little brighter. Anikun was your default like that with the slight pink in whites as alot of users report green? Makes me wonder if i should use default,both look great and with not much difference between the 2. Just out of curiosity could you pm me with your default warm wb settings as i'd like to compare them to mine.
post #291 of 1606 Old 11-22-2012, 04:21 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Warm WB Default on my TV
R-Cut: 80
G-Cut: 80
B-Cut: 80
R-Drive: F6
G-Drive: FF
B-Drive: 80
Alll Cut: 80
All Drive: FF
anikun07 is offline
post #292 of 1606 Old 11-23-2012, 07:59 PM
renzin403's Avatar
umm... this might be a stupid questions but i dont see or cant find PATHOFNEO custom settings?... Could someone please post them up. Thanks.
renzin403 is offline
post #293 of 1606 Old 11-23-2012, 09:14 PM
tnorman2's Avatar
"You have to access the service menu to accomplish that, " So how do you access the service menu?
tnorman2 is offline
post #294 of 1606 Old 11-23-2012, 09:53 PM
dreadiej2's Avatar
Same problem here, could someone be kind enough to post those settings again as they are not available in the first post?
dreadiej2 is offline
post #295 of 1606 Old 11-24-2012, 12:21 AM
iBrad's Avatar
Just download the Service Manual, it is decribed how to do it:
Type in the search box: panasonic ut50
When you mess around the settings, first backup all the original setting on a SD card, instructions in the manual also!
Enjoy.
iBrad is offline
post #296 of 1606 Old 11-24-2012, 06:03 AM
OGPI's Avatar
I recently purchased a 50ut50 and after some reading on the topic a couple pairs of the 4100gb also. For the life of me i cannot get either pair of these glasses to pair with the display and i am really irked since I've read of others having success with little hassle. So if you can share and/or link me to what magical procedure i have to follow or the root cause it will me much appreciated.
OGPI is offline
post #297 of 1606 Old 11-24-2012, 07:56 AM
Laughing Buddha's Avatar
OGPI- Have you checked the battery? The little button on the top of the glasses should light up green (ON) when you press it once and red (OFF) when you press it twice. If you hold that button down it should blink green & red and should sync with your TV.
RIKINKY17 likes this.
Laughing Buddha is offline
post #298 of 1606 Old 11-24-2012, 12:01 PM
OGPI's Avatar
I used the battery that was supplied with them and both pair do the same thing. When i turn them on they just flash, alternating between red and green and then they turn off. they go right into that cycle as soon as i hit the button. I know it would be crazy to have dying batteries in both boxes but this is Samsung we're talking about.
**UPDATE** Got em working. BT Module wasnt on all the way due the screw hole being drilled in the wrong spot. Re-installed with screw off and they sync up. You were kinda right bout the battery cause they only have round 3/4 the bar left and i just bought the glasses last night.
Thanks for the help. Didn't make a profile before now cause this place is usually so informative i hardly come up with a question you guys haven't already asked.
OGPI is offline
post #299 of 1606 Old 11-24-2012, 01:09 PM
damag0r's Avatar
damag0r is offline
post #300 of 1606 Old 11-26-2012, 03:04 AM
Oubadah's Avatar
Quoted: 34 Post(s)
Why does the NZ version of the UT50 have to have different wording and settings in the menus to the US?
For example, our Brightness etc. scales center on '0' while yours seem to center on '50', CATS is called "Eco Mode", we have no "HD/H Size" and where is RGB Range?
ridiculous.
Oubadah is offline
Panasonic Viera Tc P60ut50 Plasma Tv , Plasma Hdtv
