The purpose of this thread is to share settings and discuss issues about the 2012 UT50 line. There's an adjustable 2pt white balance in the service menu for those that wish to take it further. Doing it yourself? Having a pro to calibrate? Share your results here for the owners to see and discuss.
*** Settings Under Construction ***
*** Updated 9/30/12 - Pre/Post Calibration Reports by D-Nice ***
graphics setting is for "best on screen display" of connected equipment. basically setting it to graphics will turn off the auto function ,disabling the extra processing it takes for the t.v. to "think" what signal is coming in and providing the best picture.
Originally Posted by 9stooges /t/1412033/the-official-panasonic-ut50-settings-issues-thread#post_22229452
Hey Neo, are you using RichB's 42UT50 SM settings on a 50UT50?
I was but then pcgeek suggested in the discussion thread that I shouldn't use the 42" panel's settings on a 50" panel. I've been using his but I think it looked better with RichB's. I was just wondering if you've tried pcgeek's SM settings and what you thought?
Rich B's calibration was for a friend of his and they look too cool and blue to me and there is still a green tinge to skin tones. I found mine from a review of a 50" uk UT50 and they look perfect to me,for instance i was watching prison break on netflix at the time when making changes in the sm and at stock and with rich b's the skin tones and sky had a green tinge to them and then i tried the uk UT50 settings and skin tones looked perfect aswell as pretty much everything. I wouldn't consider rich b's because skin tones looked terrible and i don't know why anyone would set the contrast to 95.
I am trying to customize my settings as suggested by those here on this thread, but when I go to the advanced menu, I am unable to change/alter the Color Matrix, Black Level or the 24p Direct Input... These items are "grayed-out" and the selector just skips by them. Is there another setting that I need to change before those can be altered?
Originally Posted by Montavano /t/1412033/the-official-panasonic-ut50-settings-issues-thread/30#post_22251914
Hello...
Originally Posted by Montavano /t/1412033/the-official-panasonic-ut50-settings-issues-thread/0_100#post_22251914
Hello...
I recently purchased a Panasonic TC-P50UT50 (2 weeks ago) and I notice the word "MENU" is retained on my screen. Obviously I spent too much time adjusting the TV settings before the 100-hour break-in period. My question is, is there a way to reverse this? I've probably watched the TV for around 60-70 hours so far. Any help is appreciated.
Originally Posted by coolguyf /t/1412033/the-official-panasonic-ut50-settings-issues-thread/0_100#post_22257501
"I recently purchased a Panasonic TC-P50UT50 (2 weeks ago) and I notice the word "MENU" is retained on my screen. Obviously I spent too much time adjusting the TV settings before the 100-hour break-in period. My question is, is there a way to reverse this? I've probably watched the TV for around 60-70 hours so far. Any help is appreciated."
Anyone else notice 1080/24p content looks a blurry in 60hz mode? The Samsung D7000 plasma that I have doesn't handle 24p like that, much cleaner. I don't have motion smoothing turned on at all, and have tried it in Custom mode and Cinema mode. Is there another setting I could be missing? Or should I change something on my PS3?
Interested in knowing web browsing capabilites - can the UT series play flash video ?
Aware of the youtube app but can it play flash video outside of the youtube app - can play flash video from the browser ? Web site flash files ? (Flash files that some websites use to display certain media - do certain site actions)
Originally Posted by terrano /t/1412033/the-official-panasonic-ut50-settings-issues-thread/0_100#post_22268084
No, the UT50 models do not have a web browser at all in the Viera Connect internet apps.
There is a separate Youtube app, but it appears to only play the SD resolution/quality of an internet video even if the video has HD resolution support, but no way currently to select a different quality/resolution from the source video.
Only the ST50 and above models add a web browser internet app, but even those don't support adobe flash at all.
Plus the web browser has no way to go to a full page video mode, it can only show a smaller video window with the larger browser frame.
I was skimming through the official UT50 thread and saw something about setting the TV to "nonstandard" and then set the PS3 to "Full RGB." (Graphics Mode, Custom)
I am not exactly sure as why one would do this even though I tried it and it looks great.
Anyways, I have both a PS3 and an XBOX360 running into a receiver and out the same HDMI cable to the TV.
So when I set it to "nonstandard", the picture got noticeably lighter (grayish blacks) as it did on the PS3 before I changed it to full RGB.
I am guessing that now I will need to do the same for the 360.
However, the only equivalent was the "Reference Levels" area where you have something like Standard,Intermediate, And Expanded I think.
Is this the same as "Full RGB" or is this the same as "Deep Color Output" on the PS3? (And now I am not sure what to put this on, on the PS3)
When I put the 360 on Intermediate or Expanded it seems to restore the color/black level but then I do not know what is what because of no explanation.
This all throws me off because I could swear that the Spears and Munsil guys said on their thread to put the PS3 on "limited."
Cheers - think hold off for a bit - looks like still at guinea pig stage internet tv in the main - have the no flash problem with my ipad 2 - right royal pain.
Seen guy on youtube dissapointed his samsung would not play flash video on facebook - said sony the one togo for cause they have hooked up with google - and sony's play flash.
I just picked up the TC-P50UT50 and only had a few minutes to play with it before I had to run out the door. I noticed a lot of noise/graininess on the set. It didn't matter if it was Bluray over HDMI or DirecTV or Component or HDMI. I even removed all source inputs and just had the menu screen up and there appears to be considerable noise on the screen. The black areas outside of the menu look fine, but the menu itself seems to have some background noise. I can't notice it when I'm ten feet back, but up close I can definitely see it. Anyone else notice this?
Originally Posted by prdaley /t/1412033/the-official-panasonic-ut50-settings-issues-thread/30#post_22286545
I'm going to calibrate it sometime in the next few days, but I found it quite disconcerting that there would be noticeable noise/grain on the TV's menu itself. BTW this is the first plasma I've ever purchased and I don't know if there could be anything to this, but does it maybe need a break-in period? I thought the "warm up" issues with plasmas were pretty much a thing of the past.
Originally Posted by prdaley /t/1412033/the-official-panasonic-ut50-settings-issues-thread/0_100#post_22286545
Your description sounds like typical plasma dithering, its only noticeable up close to the screen - so thats normal with plasmas.
Watch it from several feet away at least.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
