The Official Panasonic UT50 Settings/Issues Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #811 of 1608 Old 02-19-2013, 06:07 AM
Temo000's Avatar
When I wall mounted my UT50 I didn't realize the space between the wall and the TV would be < 2 inches. So when it was finally on the wall we noticed the HDMI cable was tweaked at an 80 degree angle (while still plugged in, eeeek!). Now I'm thinking I might have damaged the HDMI cable and/or HDMI port on the set (cable is not easy to replace, its fished for about 20 feet in-wall)
What I'm seeing might be natural for this set but I want to be sure.
  • When I view a pure black screen within a few inches of the screen, I don't see a pure black image, I see basically screen noise (allbeit pretty faint). Of course when I move back to a normal viewing distance it's not noticible, however I'm sure this dancing black or screen noise would afffect sharpness and clarity... Can anyone confirm you can see a PURE black image? (or other colours too)
  • Whites aren't exactly brilliant on this set, they are fairly dull (I've tried all of the recommended settings). Is it possible to get pure white?
  • Buzzing on bright images, which I've read is normal for this set. But is this par for the course for ALL UT50s?
If anyone could help to answer these questions I'd forever be indebted! Thanks smile.gif
Temo000 is offline
post #812 of 1608 Old 02-19-2013, 06:32 AM
Rich Williams's Avatar
Originally Posted by RandyWalters View Post
Those 3 instances are not flicker, those look to be the infamous "hockey flashes" that were discussed here several months ago. Several of us saw the same issue on various other brands and models, as well as on LCD TVs and even DLP TVs so it wasn't just with our Plasmas. The issue is apparently within the games' broadcasts and shows up on all TVs to some extent or another.
Search this forum for "Hockey Flash" and you'll find posts about it.
Randy, thank you for the response. The flashes can make the games unwatchable when in increased frequency. There are times when what can be called a 'reverse flash' or a instant, mostly blacked out screen appears. They mix with the flashes that are seen in the video. When I host hockey fans to view games, they haven't seen such issues on their televisions (or at least to the point where they can recognize it). The 46" Sony KDL-W4100 that this TV replaced never exhibited these issues.
I'm borrowing this video from another Panasonic plasma owner but I have seen viewing issues such as this...
http://www.youtube.com/watch?v=ktlkxXNPkbg
Rich Williams is offline
post #813 of 1608 Old 02-19-2013, 08:28 AM
morphinapg's Avatar
Quoted: 1326 Post(s)
Liked: 827
Originally Posted by b0bbYboy View Post
but on light dark the blacks look really washed off.
I have cats because when im trying to sleep its too bright so i love how it dims when my lights are off
Why do you leave the TV on when you sleep? Seems like a waste of the TV's life to me.
The black levels: Dark crush the blacks. This means there is shadow detail (different levels of blackness in shadows) that simply gets reduced to black, with no detail. The only reason to use Dark black levels is if the source is outputting an irregularly light image.
Living Room: Sony XBR65X930D, Sony HTCT780, Base PS4, Philips BDP7501
Bedroom: LG OLED55C6P, Denon AVR-X1300W, PS4 Pro, Philips BDP7502, AV.io 4K
Check out my video game movie edits
morphinapg is online now
post #814 of 1608 Old 02-19-2013, 10:05 AM
JSpectre88's Avatar
Liked: 54
They aren't washed out. If what you're watching is supposed to look solid black, it will be. With those settings and CATS on, I don't even know how you can see anything. Also, Warm 2 isn't yellowish. That's just your brain tricking you into thinking a cooler temperature setting is always going to look "whiter". Believe me, I've been there too.
JSpectre88 is offline
post #815 of 1608 Old 02-19-2013, 10:28 AM
JSpectre88's Avatar
Liked: 54
I don't know about the HDMI cable, but my guess is they are pretty resilient, if the port still seems to function properly I'm sure it's fine too. I recommend using AVS709 or another calibration disk to set your brightness properly. A solid black image should be perfectly black with no dithering or noise, but it depends on the source you're using to judge it. If you don't want to use a calibration disk, a solid black slide would also work. Whites should appear bright and look normal, but only so long as they don't trigger the ABL. The ABL is a standard feature in all plasmas and dims the screen when the overall surface of the screen is too bright. Buzzing in my opinion is normal for all plasmas, but some would disagree. If it's not something you can live with, I would try your luck with an exchange or see if they are willing to repair it for you.
post #816 of 1608 Old 02-19-2013, 01:29 PM
cjwinding's Avatar
Hello. I apologize for the apparent newbie question: Just waiting on the delivery of my UT50 and seemingly overwhelmed with the amount of information on this site. I want to maximize the performance of the display but I don't know if that can be done out of the box or if there needs to be some level of burn-in. Since there is a definite MTBF with all sets I don't know that it's important for me to burn off a couple hundred hours of miscellaneous slides to get that done. I was thinking of picking up the Disney WOW disc for ~$20 and starting with some of the suggested settings in this forum. Should I wait until I have a minimum amount of hours before doing so? And, are there other advantages to prematurely aging the set with burn in slides? I haven't looked to deep yet but I am not even sure how you go about that. Thanks, in advance, for your expertise. I value your opinions.
cjwinding is offline
post #817 of 1608 Old 02-19-2013, 03:07 PM
JSpectre88's Avatar
Liked: 54
Since there are no D-Nice settings (AFAIK) for the UT50 I wouldn't bother running slides. Running slides won't have any added benefits, the set may be less susceptible to IR, but that's only due to the fact 100 hours has already passed. You need to wait until around 100 hours minimum for settings that won't shift easily. That doesn't mean you can't set them out of the box, it just means you will probably need to do it again after 100 hours. I don't know much about it personally but Disney WOW is a good choice for calibration, AVS709 is good also and you can get it here for free. As for break-in procedure, you can go ahead and just watch it normally. I suggest cinema mode with reduced contrast. Only watching full screen content for the first 100 hours is recommended, but a movie here and there shouldn't hurt. Just try to be mindful of leaving static images on the screen for too long, such as logos, bars, lettering, etc. Also, be aware that you may be able to get IR just from frequent use of the Menu.
post #818 of 1608 Old 02-19-2013, 03:43 PM
Jeff D's Avatar
Originally Posted by RugerRell View Post
Hi, I also just picked up a 55UT50, but I seem to be having a problem with the 3D washing out the colors. When I switch to the 3D mode the display seems like it cranks the some brightness setting up to much. I know it's trying to compensate for the active shutter glasses, but even with the glasses on, the blacks aren't as deep as 2D and the colors are a washed out. Does this happen with any of your guys UT50's? Is there a way to fix this, maybe in the service menu? Thanks for your help.
I think you may be seeing the same thing I've been talking about. I'm actually on the phone with panasonic right now trying to get to a level of support which can look into what I'm seeing.
When the set came out of the box, in standard mode, I noticed the picture was horrible. I can see this stuff from a distance because I work on CE AV products and I've been trained to notice this stuff. If someone were to get close to theTV, say 3 feet away or closer, they can see this "noise" too. This is most obvious on the menus, solid black color bar for the menu is more a grey which was comprised of flickering black, grey, blue, red and green tinted pixels. I did switch the display mode to cinema and the 2D picture is rock solid. But that's only true for 2D. If the set is switched to 3D (and cinema mode) the pixel noise comes back. This isn't a 3D frame sequential thing because a in image which is computer generated to be a single color has the same "noise" in the image. I can watch with one eye and see this noise (or movement) in solid colored regions of the screen. It looks like what one may experience with crappy composite video cables for displaying video from a DVD player or DVR.
The result of this noise is the picture is quality in clearly not the same as if I switch the mode back to 2D (with same 3D source). 2D again looks rock solid, 3D looks bad. I'm not yet ready to get into the service menu because I just got the thing out of the box last week.
Does that sound like what you're seeing?
Jeff D is offline
post #819 of 1608 Old 02-19-2013, 03:59 PM
Jeff D's Avatar
Originally Posted by Seerden6 View Post
I recently purchased a 55ut50 at Costco, brought it home and everything was great. I started to watch the various hockey games on the weekend and noticed this same flickering. I started to think I would have to return the set, but started to do some internet searches and found these same complaints going back several years. Most people think that it is just the nature of the strobes in the rinks and the flash photography? One guy I read about returned his set to BB and they just happened to be feeding in hockey and he saw it on every set!
I also observed this last night during the NBA all-star game. I was also watching plenty of other programing with ice, including a Top Gear episode where they were racing on ice and no flicker what so ever!
I would be interested to get the observations of other UT owners watching hockey.
-Rolf
I had been watching some hockey on this set too, and while I didn't notice the flashes that everyone else does I do see what appears to be momentary jerky motion. I can't rule out the DVR as the cause, but something wasn't right. I did see the same thing with a panning shot with another outdoor program. Panning is provides the most work for a video encoder so I wouldn't be surprised to learn it's a broadcast issue.
Jeff D is offline
post #820 of 1608 Old 02-19-2013, 04:06 PM
After giving a shot to 2 UT50's in nearly 2 weeks, I'm resigned to the fact that its a brick. I'm simply tired of the return experience but I'll have to reinvestigate. I'm watching the MTL/NYR game right now and during previews, it flickered 6 times within about 8 seconds during team highlights. This isn't an arena flashbulb issue or arena lighting issue. The UT50 is good at most things. At hockey, its brutal. 0 for 2.
post #821 of 1608 Old 02-19-2013, 04:17 PM
b0bbYboy's Avatar
I put my TV to 60-90 minutes on sleep so there is no wasting. Plus I'll be buying a new TV in 3-5 years. Anyways, your saying that Black level on dark makes the TV eliminate all gray-scales and just makes them dark?
ill turn dark levels to light cause altho I do agree with you, sometimes the picture looks better when black levels are in dark.
As far as CATS go I will prob turn it off cause its not letting me customize how much brightness I want under CATS
To each its own. Regardless, on the navigation menu it states that Colooler will give (Blueish) color hues and Warmer will give (Redder) color hues.
b0bbYboy is offline
post #822 of 1608 Old 02-19-2013, 04:46 PM
JSpectre88's Avatar
Liked: 54
True, but the most accurate setting is closer to the warmest temp than a cooler one. It can vary by TV, but on the U50/UT50 warm 2 is closest to 6500k. White will still look white at temperatures ranging from 5,000k-10,000k, it's your other colors that are going to be off. You can set your TV up any way you desire, but if you just leave it on warm 2 your eyes will adjust quickly and whites would look normal. Warm 1 isn't necessarily bad though, just trying to share my experiences regarding color temps.
post #823 of 1608 Old 02-19-2013, 04:53 PM
RugerRell's Avatar
Hi Jeff, It does a little. When you switch to 3D mode does your screen seem to wash out with blacks becoming greyish? I am also using the Samsung SSG-4100GB 3D Glasses, but I can't imagine the Panasonic ones make the image much darker.
RugerRell is offline
post #824 of 1608 Old 02-19-2013, 05:04 PM
b0bbYboy's Avatar
I agree. Funny cause Im actually trying "Warm 1" with a bit more "Color" and Black Levels: Light and CATS off.
Its funny how calibrating works :P
b0bbYboy is offline
post #825 of 1608 Old 02-19-2013, 05:07 PM
Jeff D's Avatar
Reuger, I'm with your assessment of the glasses, but they glasses are different tints which does make some difference, but it wouldn't be helpful. My picture has the same effect on 3D that I see on 2D when the display mode is set to "standard". It's just a bit different because of the frame-sequential video format. But I do not get good colors or blacks in 3D mode. I can notice this up to about 10 feet, my 9 year old say he can see it further back (my eyes aren't as good as they once were).
Jeff D is offline
post #826 of 1608 Old 02-19-2013, 05:10 PM
Jeff D's Avatar
Is there any way to configure the set to power up in the last used state? In other words if I have the tv ON and cut the power (with a power system component) when power is restored the tv returns to the ON state? My PZ800 does this, but I can't find a way to get the UT50 to do the same (difference price point likely the cause). Even the LG LCDs have this feature and I don't think it's an expensive feature to include, but maybe I'm wrong.
Jeff D is offline
post #827 of 1608 Old 02-19-2013, 05:23 PM
morphinapg's Avatar
Liked: 827
Personally, using the default Warm 2 Cinema mode, and the official Panasonic glasses, 3D cinema mode looks just like 2D cinema mode for me.
post #828 of 1608 Old 02-19-2013, 05:38 PM
RugerRell's Avatar
Thanks for your reply morphinapg. You wouldn't by chance have tried the Samsung SSG-4100GB 3D Glasses with your display have you? Also, do you notice that your display washes out the blacks when in 3D mode when you have your glasses off? Just wondering if this is normal. Thanks.
post #829 of 1608 Old 02-19-2013, 05:46 PM
morphinapg's Avatar
Liked: 827
I only have the Panasonic glasses (TY-ER3D4MU)
by washes out, do you mean crushing the blacks, or the opposite (lightening them)? Without the glasses, it looks to me like the image gets a cooler white balance, which makes the whole image look a bit washed out, but as for the blacks specifically, it doesn't look like the black levels change at all. They aren't crushed and they aren't lightened. It doesn't particularly look like the gamma is modified either from what I can tell, but I'm not 100% sure on that. The only difference I see is that the colors are just pushed more towards blue, which I believe is offset by the glasses.
post #830 of 1608 Old 02-19-2013, 05:52 PM
RugerRell's Avatar
It is lightening them. On my display when I switch to 3D mode the whole image is a lot brighter, which is making the blacks greyish. Even when I switch the black level to dark from light (which also crushes the blacks) the blacks still look greyish. It's a little weird. Are you running the latest firmware by chance morphinapg?
post #831 of 1608 Old 02-19-2013, 06:54 PM
bwar's Avatar
Come on...someone has to have an idea about my situation regarding my ut50 on page 27....no? frown.gif
bwar is offline
post #832 of 1608 Old 02-19-2013, 07:07 PM
JSpectre88's Avatar
Liked: 54
I heard about that defect on 2011 Panny's, but I didn't think it was a problem on 2012 models. I would get it replaced if it's at all noticeable with regular content.
post #833 of 1608 Old 02-19-2013, 07:12 PM
bwar's Avatar
Okay thank you kindly JSpectre 88! I have decided to exchange it. I'm sure I'm over reacting as it is barely (and I mean really looking for it) noticeable during regular viewing but I think it will just ease my mind...knowing me I'll be sitting there just watching for it to get worse.....
Cheers!
bwar is offline
post #834 of 1608 Old 02-19-2013, 09:12 PM
RugerRell's Avatar
Cheers!
Yeah, if it is distracting you definitely get it replaced. I don't seem to have that on my set. I also wanted to ask everyone else if there set cranks the brightness up when you switch to 3D mode? I am starting the wonder if I also got a bad set as morphinapg said his didn't do that.
post #835 of 1608 Old 02-20-2013, 12:25 AM
damag0r's Avatar
Note: Where I said "gain", I meant to say "drive".
So, I'm too lazy to read back everything I've missed in this thread...
But I'd just like to add some things from my previous posts from months ago.
Any minor image retention I gave my TV by torturing it is totally gone, I can't see it no matter what color slides I use... and it has been gone for a very long time. However when I watch station that has a high contrast logo up all the time for an extended period I often use the "zoom" setting to zoom in past it.
Also, I was using Anikun's service menu settings, but I started noticing things have been drifting back yellow/orange as now I have 1200 hours on the panel. Another thing is, I kept noticing blacks were looking magenta/red and not so black/grey with some sources. So, I spent the last couple of hours tuning the white balance by eye using my monitor as reference, and I'd be willing to gamble I have it quite close to ideal with a very low deltaE. I no longer see the reddish blacks anymore either. The monitor used as reference once upon a time calibrated with a colorimeter.
It's not perfect, but it's damned close and it looks great to me. If anyone cares I will list what my settings are.
I also ordered this: http://www.amazon.com/Xrite-EODIS3-i1Display-Pro/dp/B0055MBQOW
I think it should be interesting to see how close I was able to get it by eye once I have a chance to try out the colorimeter.
On custom with normal temp (using Anikun's original settings as a starting point):
The main things I did were dump Green gain from FF to EF, I also adjusted the cutoff slightly. I increased the blue gain/cut slightly, and reduced the red cut (but not the gain) by 3-5 notches. Skin tones look much better now and instead of yellowish/orange it's a bit pinkish at worst. Another interesting side effect is now that the All drive isn't at "FF", the "color" setting in the normal settings menu actually has a large impact. I had to turn it down a little because I could tell the colors were a bit overdriven/oversaturated once I made my white balance changes... and I seem to remember before I made these changes messing with the "Color" setting hardly did anything unless I moved it like 20 ticks... now I can tell a difference with ONE tick.
I'm sure I screwed something up since I don't have a meter yet, but still looks better by my own subjective measures. I think grassy scenes look slightly better if I switch back to Cinema with Warm2 which is still using Anikun's settings... but my by-eye calibrated Custom w/ Normal temp looks better for almost everything else.
Edit: Also, to the person saying they thought things were too yellowish/orangish... it isn't just you... and it isn't just your brain tricking you... This set really does tend to have a bias towards yellow/orange on warm2, especially in skin tones where it should be more pinkish than orange. I was able to clear this up by adjusting the white balance. Actually... at first I only dumped the green gain way down and the cut a bit... then adjusted the blue gain/cut up slightly (from Anikun's previously posted settings)... which made things pinkish... a little too pinkish... at which point I dropped the red CUT a few notches and it seems to be about the ideal level of pinkness for skin tones now.
I notice if I set it to "Warm 2" on custom which I didn't mess with, everything looks yellowish, but when I set to "normal" (the one I tweaked in the service menu) things look a little pinkish, which is how they should look on warm2 imo. Warm should == a little bit red/pink... at least in my mind... not orange/yellow.
Hope I didn't ramble on too much and hope this post was coherent... I'm pretty tired right now.
damag0r is offline
post #836 of 1608 Old 02-20-2013, 08:04 AM
chunon's Avatar
Quoted: 2503 Post(s)
Liked: 2233
You can not adjust greyscale by eye, if you you think you can you are fooling yourself
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #837 of 1608 Old 02-20-2013, 09:28 AM
damag0r's Avatar
We'll see when I get the colorimeter and have a chance to try it out. wink.gif
I don't doubt my greyscale is less than neutral, but I was using a well calibrated monitor as reference to adjust the white balance and I think I got pretty good results. The reds seem ever so slightly off, but not enough to bug me. The tangerine skin tones I had before were much worse.
damag0r is offline
post #838 of 1608 Old 02-20-2013, 11:30 AM
chunon's Avatar
Liked: 2233
I'll be interested to see but you did start with calibration settings derived using a meter correct ? You are alot braver than me blindly messing with things in the service menu is not a good practice in my experience especially those all cut and drive values definitely a no no according to the pros.
Sony 75XBR940E
post #839 of 1608 Old 02-20-2013, 11:36 AM
JSpectre88's Avatar
Liked: 54
The VT50 is actually closer to D65 at normal temp, but I'm not sure about the UT50. I suppose the accuracy of your settings would have to depend on that.
post #840 of 1608 Old 02-20-2013, 12:46 PM
damag0r's Avatar
Well I was originally using Anikun's settings, which seemed good enough... but after 1000 more hours of aging the panel seems to have become quite uncalibrated.
For reference I was using my Dell U2412M which is using the settings and ICC profile from TFT central. It's been verified to be very close with a meter, and might have been tweaked slightly. I think once I used TFTcentral's ICC profile on the U2412M it was so close when it was tested with a meter we just left it alone or only made very minor changes. Anyway.... I just displayed the same image on both screens and tried to get the UT50 to look as close as possible to the U2412M. My changes did take the reds off a little but everything else is so much closer. The colors were a bit oversaturated after my WB changes too, but simply taking the "color" setting down a few notches fixed this.
Also, why such a big "no no"? I have what all the original values were, so I am able to change it back anytime. Plus I didn't mess with my Cinema/Warm2 settings which are still at what Anikun posted. I only changed the Custom/Normal WB.
From what I've read this set is a lot different than the VT50 and "Warm 2" is closest, but it looked way too orange to me compared to my U2412M.
Edit: If anyone cares here are my probably horrible by eye settings with 1249 hours on the set (they look great to me though):
Normal Color Temp Using Custom Mode (Anikun07's original settings in parens):
R-Cut: 7C (7F) - dropping this seemed to help a lot with the "magenta" blacks
G-Cut :60 (6A)- seemed too high on my set at least w/ 1200+ hours on it
B-Cut: 60 (60) - changing this at all only seemed to makes things worse, so I instead increased the B-DRV
R-DRV: EF (EF) - no change - which is likely why I see some very slight skewing with the reds sometimes
G-DRV: EE (FF) - this FF seemed WAY too high on my set... at least with 1200+ hours on it
B-DRV: 9F (97)
All Cut: 7C (7F)
All Drv: EF (FF)
Contrast: +84 (same)
Brightness +56 (same)
Color: Anywhere from like 42 to 47 (I usually keep it at 45-48 because I like that slightly 'over-saturated' look, but it depends on the source content).- Anikun's was originally 48, but 48 definitely seems more "saturated" after I made the white balance changes in the service menu.
Tint: 0
Sharpness: anywhere between 0 and +15
HDMI: standard
content type: off
Everything else OFF
mobius likes this.
damag0r is offline
Panasonic Viera Tc P60ut50 Plasma Tv , Plasma Hdtv
