The Official Panasonic UT50 Settings/Issues Thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1561 of 1604 Old 06-20-2014, 03:04 PM
Liked: 0
I read on post 1528 these good looking settings (see bottom) only i got the european model (tx p50ut50e) with diffrent level scales.
Contrast only go's to 60, brightness is also lower and colour of 48 is possible.
Maybe a dumb question, how do i convert these values in to european standards?
R G B R G B are these white lvl settings?
Thanks in advance!
R-Cut 70 (-16 clicks from default)
G-Cut 67 (-25 clicks from default)
B-Cut 6E (-18 clicks from default)
R-Drv F4 (-11 clicks from default)
G-Drv FF (Unchanged)
B-Drv 97 (+23 clicks from default)
All-Cut 70 (Automatically changes)
All-Drv FF (Unchanged, but would automatically change)
Contrast: 88
Brightness: 48 (Based on Target Y fL)
Color: 48
joostnl is offline
post #1562 of 1604 Old 08-09-2014, 08:51 PM
Jawzey's Avatar
Hey all,
My Panasonic TV remote for my 42UT50 is not working. I've replaced the batteries and everything, but it is still not responsive. None of the buttons work and I have to turn the TV on manually. Any suggestions? Thanks!
Jawzey is offline
post #1563 of 1604 Old 08-10-2014, 09:37 PM
Latinoheat's Avatar
Quoted: 1111 Post(s)
Liked: 882
Originally Posted by Jawzey View Post
Hey all,
Buy a universal remote, they are much better and can control all your devices.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #1564 of 1604 Old 08-27-2014, 11:17 AM
perfy's Avatar
Apologies if this has already been discussed in this thread, but does anyone have ideal settings for the Playstation 4 with a UT50?
perfy is offline
post #1565 of 1604 Old 08-27-2014, 11:25 AM
morphinapg's Avatar
Quoted: 569 Post(s)
Liked: 317
I believe the PS4 sets everything pretty optimally automatically. Only thing I'd check is if Super White (which is xvYCC color) is enabled for better colors on Blu-rays.
morphinapg is online now
post #1566 of 1604 Old 09-02-2014, 07:29 PM
Moegames's Avatar
Originally Posted by dfran1 View Post
Quote: Originally Posted by Muadib2012
Hello
I used to have problems seeing the 3D effects, I tough it was th TV itself or something in my eyes because even in the movie theater I almost dont see that 3D effect but, then on TV, On the "3D adjustment" I changed the "3D Depth" to "-1", and now I really see the 3D effect, it was really a big, big, big change. Does somebody knows if it affects the picture quality? what it really means? a problem in the eyes? does everybody else will be affected? its because I m too close to the TV (6 feet)?
Thanks in advance,
Hi,
In my findings and OCD of 3D,
when you go negative, images that pop out at you do not pop out as much and the more negative the less pop out of the tv we get.
Now the opposite to go positive, when one adjusts in the + positive direction the more pop (images come out farther).
Now in my findings (from what I have owned, and or tested) plasma has less cross talk (please do not go looking for it cause once you see it you always will!)
Now my wife could not watch 3D at all at home until I purchased a Mede8er "MED600X3D", with this unit I can adjust the 3D, and also use the tv 3D that you are, to eliminate crosstalk down to %10 (Imax 3D is 1% crosstalk).
What crosstalk is to me, any portion of the image either being the farthest, the pop (out in your face), or anywhere in between when one sees a ghost outline of an object (being anything, from background trees, people, or objects popping out of the screen).
So like I was saying my wife could not watch any 3D at all without getting headaches or feeling ill until I purchased that Mede8er and adjusted both the Mede8er 3D adjustment and the TV 3D adjustment and Now she can watch all 3D movies with me, without the mede8er I could only adjust crosstalk to about ~30% (meaning ~70% of the picture was crosstalk free) and my Sony LED 3D is just full of crosstalk no matter what.
I have a friend and his wife can not watch 3D at home so far no matter what (tho she has not tried my set up yet), but it seems everyone sees all this slightly different (3D varies from person to person)
But if you like it at -1 or whatever you like it at then watch it at that and you will absolutely cause no harm to the TV, the only harm you can do is to yourself or the ones with you watching that if any can see crosstalk it may or may not make them sick! I sit ~5-6 feet away also.
I hope this helps, and everything in this is my own opinion and nothing more.
happy 3D viewing !!!!!!
3D movies on my PC connected to my UT Plasma looks way better using my 7970 graphics card...3D just seems more crisp, clear and that nasty 3D effect is almost non existent when watching 3D movies on my PC compared to Comcast HD 3D Cable or say 3D Bluray player....since i have my PC setup to not use my Panasonic's rendering but rather my AMD HD 7970 Ghz 3GB Graphics Card has made watching 3D movies sharp and clear with no dizzy headache effect that i "sometimes" get using a Bluray player or HD Comcast Cable 3D movies,etc
I suppose its sorta like how when using a PC with your big screen...using a software video player with advanced settings like say MPC-HC which is Media Player Home Cinema Classic is better than even a higher end stand alone bluray player ..more info here http://mpc-hc.org/ ..its free but it has so much more advanced options to tweak,etc and of course many choices of codecs,etc, rendering techniques ,etc that uses your PC's graphics card to render rather than using your TV's display processor....
Moegames is offline
post #1567 of 1604 Old 09-02-2014, 07:31 PM
Moegames's Avatar
Hello
Thanks in advance,
Hi,
3D movies on my PC connected to my UT Plasma looks way better using my 7970 graphics card...3D just seems more crisp, clear and that nasty 3D effect is almost non existent when watching 3D movies on my PC compared to Comcast HD 3D Cable or say 3D Bluray player....since i have my PC setup to not use my Panasonic TV's processor rendering to render my movies including 3D movies but rather I choose to use my AMD HD 7970 Ghz 3GB Graphics Card has made watching 3D movies sharp and clear with no dizzy headache effect that i "sometimes" get using a Bluray player or HD Comcast Cable 3D movies,etc
I suppose its sorta like how when using a PC with your big screen...using a software video player with advanced settings like say MPC-HC which is Media Player Home Cinema Classic is better than even a higher end stand alone bluray player ..more info here http://mpc-hc.org/ ..its free but i suggest getting Klite Package which includes all the extra codecs and rendering software along with MPC-HC ..get it here http://www.codecguide.com/download_kl.htm but it has so much more advanced options to tweak,etc and of course many choices of codecs,etc, rendering techniques ,etc that uses your PC's graphics card to render using AMD's high quality hardware accelerator rendering engine along with MPC-HC rather than using your TV's display processor....it just makes 3D playback way better ..at least for me.
Moegames is offline
post #1568 of 1604 Old 09-02-2014, 07:55 PM
Moegames's Avatar
Originally Posted by jywc55 View Post
I've noticed a similar phenomenon. Horizontal darkened bars stretching out from brighter objects. Mainly noticed on Windows desktop. I thought it might have something to do with auto brightness, although I thought that "feature" is supposed adjust the entire screen...
Originally Posted by anikun07 View Post
I think it's considered line bleed, where there's a horizontal line across part of the screen and it affects the brightness of the rest of the screen within the width of the line. The automatic brightness adjustment is just a stupid setting. It's too bad that can't be disabled.
My dad's very high end Panasonic Plasma has line bleed...it varies from tv to tv how pronounce it is...my UT 55inch when i first got the TV had very very noticible line bleed....i remember how a dvd i have of Mike Tyson knockouts you could see the boxing ring ropes bleed through the boxers as they boxed...or when i use my PC and certain lines going horizontal would bleed through other objects if the objects where in its way....sorta like semi-transparent lines going through objects on screen...you can see this a lot using a PC on a Plasma TV...but G10 had zero line bleed...but my UT55 had it really noticible...but over time it has faded a great deal and its barely noticible now...i recently noticed this bcause i had gottne use to the line bleed over time anyways but recently it hit me..its not as pronounced as it once was so i put in that same Mike Tyson knockouts video and low and behold...i could no longer see the line bleed of the ropes going throught he boxers as they boxed in the center of the ring like how i could before when i first got the tv.
Another thing i noticed is the heat coming off the screen of my UT55 was hot when i first got the tv but over time the heat dissipated and now its room temperature when i put my hand on my screen...before it was super warm...now i dont feel no heat.
Honestly i just think these TV's just needs time to get broken in...and not all Plasma's are the same anyways....but a lot of Plasma's have this common problem of line bleed but for me..its almost all gone now..i still see it here and there but its no where near as strong as it was before when i first got this tv.....sorta reminds me my tv was like a teen with raging hormones but as the tv aged it relaxed and is now layed back lol
I got use to the line bleed anyways....it was never that annoying..just at first...same with spot marks on all white screens where i would see yellow blobs or pinkish blobs...this got really bad for a while but i adjusted vs voltage...but i just happened to put the voltage back to default voltage and the blogs were all gone...those also went away with time.
Moegames is offline
post #1569 of 1604 Old 09-02-2014, 09:58 PM
morphinapg's Avatar
Quoted: 569 Post(s)
Liked: 317
The line bleed in my TV doesn't appear to have changed at all. It's most prominent when you have perfectly horizontal lines in the image, which isn't all that common.
post #1570 of 1604 Old 09-03-2014, 04:57 PM
dfran1's Avatar
Quoted: 68 Post(s)
Liked: 40
I am going to look into this Thank You!!
will it work with a ATI Radeon HD 5770 1024 MB?
dfran1 is offline
post #1571 of 1604 Old 10-07-2014, 04:14 PM
Liked: 0
Can someone please tell me the name of IC101 and IC501? I really need it, thanks!
Felona is offline
post #1572 of 1604 Old 12-16-2014, 11:09 AM
reverendo's Avatar
Quoted: 26 Post(s)
Liked: 2
I'd like to thank for the settings on #1528 . They really worked for me.
Since I have no way of working through this whole thread would somebody that has been around here for enough time tell me if there is a fix to the buzzing issue. I know that I'm quite sensitive to audio, but the buzzing is pretty loud sitting 7-8 feet away from the set. My wife also notices it and it's not subtle.
Thanks in advance
Best regards
Andre
reverendo is offline
post #1573 of 1604 Old 12-27-2014, 12:22 AM
therealjustin's Avatar
Thanks in advance
Best regards
Andre
I don't think it is possible to get rid of the buzzing completely, but I cut the noise by half be using a bit of electrical tape. The only way to find out what is making the noise is to remove the back panel. It sounds terrifying but it is very easy as the set can remain upright on its stand. All you need is a screwdriver. Once the screws are removed the metal back will pop off. Plug the set back in, power it on and listen.
The buzzing on my set was coming from the upper right(when looking from the rear) circuit board. I carefully put a rolled up piece of tape in between the two offending parts to stop them from oscillating.
On a separate note, has anyone calibrated their set over the 3000 hour mark? I feel like Anikun's settings are a bit off now that the panel has some age.
reverendo likes this.
Cisco 8742HDC - 7.2.0_5 ODN | Panasonic UT50 | Panasonic P46U1
therealjustin is offline
post #1574 of 1604 Old 12-27-2014, 05:49 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I haven't yet, but it's on my list of things to do.:-)
anikun07 is offline
post #1575 of 1604 Old 12-27-2014, 03:39 PM
That is great to hear!
Have you noticed any changes in either black level or color? The blacks seem more gray than ever on mine and the color seems to be a bit too warm now.
post #1576 of 1604 Old 12-29-2014, 09:27 AM
reverendo's Avatar
Quoted: 26 Post(s)
Liked: 2
thanks.
unfortunately my TV is on a wallmount, so it's not that practical. I'll probably have to wait until it really gets on my nerves again in order to use that energy to take it down and have a look at it.
thanks again.
post #1577 of 1604 Old 01-30-2015, 04:27 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I just finished a 2 point calibration. My display has over 1900 hours on it. Below are pictures from the calibration.
The Delta E values were slightly elevated.
These were the previous settings on my display.
The new calibration had the Delta E values all under 3.
The Delta E values for color were pretty good, too. Only green was just a little bit over 3.
These are the new settings I used.
I also used the changes for 2D to update my 3D settings. I still use the Cool WB to keep a D65 3D calibration. Here are the updated Cool settings.
Cool for 3D
R Cut 7F
G Cut 6E
B Cut 5E
R Drive DB
G Drive FF
B Drive A4
The caveat to all my calibrations are that my colorimeter is as calibrated as when I last did a calibration. I used an i-1 Display Pro colorimeter, I don't have access to a spectophotometer to calibrate the colorimeter, so I hope this yields better results. Maybe one day I'll own an i1 Pro.
anikun07 is offline
post #1578 of 1604 Old 03-30-2015, 06:58 PM
gregthec's Avatar
Anyone have calibrated settings for the TC-P50UT50 settings for all modes
Hi Folks,
Does anyone have complete listing of calibrated settings for the Panasonic TC-P50UT50 for all the modes (Custom, Vivid, Standard, etc) and for both HDMI and Component inputs, and do these settings live in one place? I find some settings here and some there but I'm getting a little tripped up trying to reconcile settings for the different modes. I don't have the knowledge or equipment to calibrate things myself so I defer to the experts.
Thanks so much,
Greg
gregthec is offline
post #1579 of 1604 Old 03-31-2015, 06:11 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Calibration is separate from picture mode. The picture mode displays "characteristics" for its picture type, but it's based off the calibration. For true color reproduction and the best gamma for the UT50, I will only use cinema/movie mode and that's what my calibrations are needed on. I use warm 2 for regular viewing and ice repurposed cool 2 for 3D viewing. I don't use any other color mode because they just alter the calibration.
gregthec likes this.
anikun07 is offline
post #1580 of 1604 Old 03-31-2015, 08:58 AM
gregthec's Avatar
Thanks. I have seen settings wher people adjusted settings for the different modes. It looks like a lot of folks are using the Custom setting. I'm guessing there are "idealized" setting for the other modes (cinema, sports, vivid, etc) as well and I was hoping that there was some sort of compendium of agreed upon, best settings for each mode on this TV. Thanks!
gregthec is offline
post #1581 of 1604 Old 04-14-2015, 05:40 AM
Liked: 0
Since yesterday the HDMI2 of my 42ut50 does not recognize anything and HDMI1 sometimes fail showing a pink screen flickering. Has anyone experienced this?
L Lawliet is offline
post #1582 of 1604 Old 08-11-2015, 10:12 AM
Liked: 0
My 50ut50 has died with the LED blinking 8 times.
Any suggestions? Should I toss it? Try to sell it as is? Try to have it repaired?
Picked up a Vizio e55 to try as a replacment, but the flashlighting is terrible, I loved my pany picture...
Ikiru is offline
post #1583 of 1604 Old 08-11-2015, 10:29 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I think it's up to you if you think you can fix it or find a repair shop. I did a quick search and found a repair/diagnostic manual for your problem. It looks like it may be an SS board that needs to be replaced. I don't know what that is, just that the manual refers to it. There's also a possibility the A board may be bad, again I don't know what that component does. And there's a slight chance the panel is defective. I don't know much about TV repair and part availability. This is just what 5 minutes turned up.
It also said there could be a loose connector.
anikun07 is offline
post #1584 of 1604 Old 08-11-2015, 02:14 PM
jnnt29's Avatar
Quoted: 119 Post(s)
Liked: 132
My buddy's UT 50 had the same thing happen and he repaired it for $50 himself. It looked to be the one of the boards fried and he did a search on the internet and found out which board it was and removed and sent it to a guy on ebay and he repaired and send it back. All good after that.
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #1585 of 1604 Old 08-12-2015, 06:04 AM
Liked: 0
Thanks, I've seen some of those on ebay. Didn't know if they were trustworthy though. I might give it a try.
Ikiru is offline
post #1586 of 1604 Old 08-12-2015, 05:36 PM
toohip's Avatar
I've fixed many SS boards. Usually you need to replace 2 FETS on heat sinks and possibly a surface mount resistor. I've only seen the resistor blown once. You also need to replace the mounting screws. The new one's have a lock washer so it doesn't happen again.
This repair kit comes with a IC but ive never had a problem with that chip.
Repair kit with video.
http://www.shopjimmy.com/panasonic-t...repair-kit.htm
mldardy likes this.
toohip is offline
post #1587 of 1604 Old 11-05-2015, 09:20 AM
ProfD's Avatar
Quoted: 25 Post(s)
Oh I just found this thread... I have a Panasonic TC-P50UT50. I bought it at the end of it's model year.
Last night the HDMI ports stopped working while I was using it. I reset it today and the HDMI ports still don't work.
Is it the HDMI board that is broken? Is that easy to fix? Am I better off just buying a new TV? thanks!
ProfD is offline
post #1588 of 1604 Old 11-05-2015, 10:02 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
First try a different cable. If you use a port saver try a different one. Sometimes the stress affects the pin connection. What is the TV connected to on that port?
anikun07 is offline
post #1589 of 1604 Old 11-05-2015, 10:15 AM
ProfD's Avatar
Quoted: 25 Post(s)
Oh I did all of that. I tried a different cable, I tried connected the cable to my cable box and separately to my PS4. I tried both HDMI ports, using all combinations of cable box and PS4. I reset the TV according to some instructions that I found online.
It was really strange because the HDMI connection to the TV hadn't been touched in years but it just stopped working in the middle of using the TV last night.
ProfD is offline
post #1590 of 1604 Old 11-06-2015, 06:09 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Are both HDMI ports not working?
Sent from my Nexus 6 using Tapatalk
anikun07 is offline
Panasonic Viera Tc P60ut50 Plasma Tv , Plasma Hdtv
