The Official Panasonic UT50 Settings/Issues Thread - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1591 of 1606 Old 11-06-2015, 06:14 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Also, check the input names in the TV settings for your HDMI ports. If any input says something like "not used" then you need to change it, otherwise it will be deactivated.
Sent from my Nexus 6 using Tapatalk
anikun07 is offline
post #1592 of 1606 Old 11-06-2015, 08:06 AM
ProfD's Avatar
Quoted: 25 Post(s)
Originally Posted by anikun07 View Post
Are both HDMI ports not working?
Yes both do not work.
No it doesn't say that. Also it happened that they stopped working in the middle of use... so I don't know how that setting would have changed in the middle of use.
ProfD is offline
post #1593 of 1606 Old 05-06-2016, 06:47 AM
JediFonger's Avatar
Quoted: 59 Post(s)
hey guys got myself a TC-P50U50 a few weeks ago. the manual was no help on the picture settings.
does anyone have clear definitions of what each of the settings do on the picture menu?
thanks!
to the edge of eternity and depth of infinity, stupidity knows no bound.
JediFonger is offline
post #1594 of 1606 Old 05-06-2016, 07:03 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Did you get there right manual? There are a couple, I don't recall having and confusion over the descriptions, but it's been s few years. Most settings are recommended to be disabled anyway.
anikun07 is offline
post #1595 of 1606 Old 05-07-2016, 05:54 PM
LexSombra's Avatar
Hi!
My UT50 is showing a vertical line, about one pixel wide...
Have any of you had this problem or something like it?
Maybe my TV is dying :/
The image is still perfect though, no problems at all.
The line appears when the TV is showing some specific colors.
Sometimes it isn't noticiable, depending on the background, but sometimes, on blue brackgrounds, for example, it's clearly visible...
Maybe only 2 of the 3 RGB colors are working for this column of pixels?
LexSombra is offline
post #1596 of 1606 Old 05-10-2016, 09:15 AM
morphinapg's Avatar
Quoted: 1234 Post(s)
Liked: 761
I have a theory that the vertical line anti image retention thing on this set can actually cause a burned in vertical line pattern, due to the way the screen brightens/darkens at certain positions of the vertical lines. I often used the vertical lines if I had some image retention, or if I was going to leave the screen paused while I went to the bathroom or whatever, and now I have this pattern of burned in vertical bars. Only noticeable against solid colors for the most part (most noticeable in a solid grey) but it's there. It's like each bar burned in as a gradient from dark to light, which against each other still show enough contrast to be visible.
Has anybody else used the vertical bars a lot with their TV to try to prevent IR? If so, have you noticed anything similar to what I notice?
morphinapg is offline
post #1597 of 1606 Old 05-12-2016, 04:51 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Mine now has the Blinks of Death when attempting to turn on.
SanchoPanza is offline
post #1598 of 1606 Old 07-11-2016, 08:35 AM
JediFonger's Avatar
Quoted: 59 Post(s)
is it 8 blinks? if so, that's an easy fix from $20 if you have soldering gun to $60-ish if you can work a phillips screw driver.
post #1599 of 1606 Old 07-25-2016, 08:20 PM
swantzilla's Avatar
Quoted: 26 Post(s)
IHAQ, How do you access the internet web browser? I looked in the setup and I do not see a way to access it. Thank you for reading.
"A Monsters Work is Never Done"
swantzilla is offline
post #1600 of 1606 Old 09-23-2016, 08:12 PM
therealjustin's Avatar
I rarely watch movies from an SD card, but after trying last night I noticed that the service menu calibration settings don't seem to work.
When playing content through HDMI 1 or 2 Anikun's settings are used(and still look brilliant I must say) but it seems to use the default settings for playback through the SD slot. Black levels are noticeably gray compared to using HDMI and there is a slight green cast. Is there any way to implement the settings for every input?
Cisco 8742HDC - 7.2.0_5 ODN | Panasonic UT50 | Panasonic P46U1
therealjustin is offline
post #1601 of 1606 Old 09-26-2016, 08:45 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I've never tried using an SD card. I would think if there is no way to change the pictures settings or color temp, then there probably isn't a way to adjust it. Have you tried to see if it does the same with USB storage? I recently began playing back video on my blu ray player from USB storage, but of course that's an HDMI input.
anikun07 is offline
post #1602 of 1606 Old 11-13-2016, 12:10 PM
Liked: 0
Sorry for the noob question, I've had the TC-P50U50 for about a year now, but never thought to calibrate it. I've never done that before.
I was looking at PathofNeos post on his setting, how do I go about getting my settings that way? Is there a calibrate disc I need to use or a certain area I go into the settings that has all those bars and graphs?
Again sorry for the noob question, this is pretty new for me. Would like to get the best out of this tv for picture quality.
Unknown450 is offline
post #1603 of 1606 Old 04-24-2017, 06:25 AM
Liked: 0
UK Help
Hi
I'm looking for good UK settings for my TX-P50UT50B. I did have great settings but pressed the dreaded "n" button last night and everything returned to factory settings.
I did write down the settings I got somewhere on the internet from several years ago but now I can find neither .
I'm just looking for good standard settings for watching everyday TV but most settings on here are non UK. The UK version has no numbers so is set from "clicks" either from left or right.
Any help please
tartan67 is offline
post #1604 of 1606 Old 04-30-2017, 04:07 PM
morphinapg's Avatar
Liked: 761
I can't say for sure, because I know the blacks were always raised in 3D mode, but I feel like they've gotten brighter and brighter over time to the point where 3D is really washed out and ugly now. Does anybody else have this problem?
I'm looking to upgrade to an LG C6 for better 3D soon, but I still wondered if mine was a typical experience.
Sent from my A0001 using Tapatalk
Living Room: Sony XBR65X930D, Sony HTCT780, Base PS4, Philips BDP7501
Bedroom: LG OLED55C6P, Denon AVR-X1300W, PS4 Pro, AV.io 4K
Check out my video game movie edits
post #1605 of 1606 Old 08-16-2017, 08:57 AM
faksnima's Avatar
Is it worth upgrading a P55UT50 to the TCL 55P607? Or should I wait on a decent OLED TV to come down in price? My Xbox One was accidentally turned on and left with a static image of an image of the console. I've gone through 4 days of IR reduction (white image, black image, scrolling white/black images, color spirals, etc...) and I cannot seem to rid the set of all of the IR. It's driving me nuts.
faksnima is offline
post #1606 of 1606 Old 08-16-2017, 03:25 PM
jnnt29's Avatar
Quoted: 120 Post(s)
Liked: 133
The hard part is trying not to see the IR. I had the same thing happen with my Panny VT60 and I couldn't un-see it. Every time I watch the TV my eye kept going to the IR. If the IR isn't that bad and you can live with it then hold out. But if the IR is too much to take the TCL may get you through until the OLEDs come down in price. My UT50 is still running strong as a secondary TV and the VT60 had a bad panel not long after the IR issue and was replaced two years ago with a Samsung. Just my two cents, good luck with your decision.
JT
My set up
Marantz SR-7008, Emotiva XPA-3
Sony UBP-X800 Ultra 4K Blu Ray Player, Harmony Ultimate Remote
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
Panasonic Viera Tc P60ut50 Plasma Tv , Plasma Hdtv
