Oldest Question in the Book - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-27-2012, 06:13 PM - Thread Starter
DeletedUserPost's Avatar
What was the technical hurdle to scaling panel sizes down?
DeletedUserPost is offline
post #2 of 7 Old 05-27-2012, 11:21 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
I think you need to first explain what post #1 means
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 7 Old 05-27-2012, 11:50 PM - Thread Starter
Plasma Display Panels are unavailable in the smaller sizes you can purchase an LCD/LED in. How come Plasma Panels aren't made smaller than 32/37 inches? There must be a technical reason?
post #4 of 7 Old 05-28-2012, 05:52 AM
JazzGuyy's Avatar
Quoted: 290 Post(s)
Liked: 268
As I understand it, plasma cells cannot be shrunk below a certain size. A smaller screen size could be made but it would not be high definition because it would have to contain fewer pixel cells.
JazzGuyy is offline
post #5 of 7 Old 05-28-2012, 06:58 AM
Collusion's Avatar
Small plasma cells are less efficient which ultimately leads to lower brightness or/and higher power consumption. This is because the emission happens close to the container's walls and not in the center of the plasma cells as it should.
Collusion is offline
post #6 of 7 Old 05-28-2012, 10:31 AM
maygit's Avatar
As i understand, the pixels themselves are also less stable which causes sub-pixel misfires.
maygit is offline
post #7 of 7 Old 05-28-2012, 11:57 AM
sage11x's Avatar
Quoted: 754 Post(s)
Liked: 812
It's because anything below 50" is completely and utterly a waste... Even for your kitchen. Go big or go home.
Oh, but just don't go too big because they only make plasmas in 65".
What 70" LCD?? I've never heard of any such thing!!
:P 8)
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
