Plasma tv recommendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-31-2012, 10:34 AM - Thread Starter
IDRick's Avatar
Liked: 24
B-day and Father's Day are coming, and I'm requesting a HDTV for the man cave...
1. How far away will you be from the display when watching it? 4 to 5 feet
2. What TV will it be replacing? 5 yr old, 22 inch, 720p, LG tv
3. What will you be watching on it? 1/4 tv shows, 1/4 movies, 1/4 sports, 1/4 gaming from PC
4. Will a computer be connected to use the display as a monitor? If so, what percent of the time? up to 1/4 for PC gaming
5. Will you be getting a Blu-ray player to watch movies and will you be getting any HD service from cable/sat, or will you just be watching SD programming, and an upscaling SD DVD player? HD service from cable, OTA
6. Are you looking for the best in class display, the best bargain display, or best bang for the buck in the middle display? best bargain with decent PQ
7. Are you interested in seeing 3D with the new 3DTVs? If not, what about next year since TVs are usually kept for many years so consider that? Yes would consider if in my price range
8. What is the room lighting situation? (i.e. can you control the lighting? Can you use light blocking blinds, etc to control it?)
basement room with small window, can be curtained.
9. What is your budget range? $500 to 750
10. Will people be watching at multiple viewing angles or just usually one person sitting directly in the center? single person, directly in center
11. When will most viewing be done on the display (i.e. Daytime or after sunset)? Most viewing in evening
IDRick is offline
post #2 of 5 Old 05-31-2012, 04:39 PM
Jawzey's Avatar
I'm not too sure that there even is a plasma set out there that would fit your viewing distance without being too obnoxiously big. That said, I believe the smallest Plasma in the USA is 42". I just got my Panasonic 42UT50 yesterday, and I'm loving the PQ! This is a great set and I'd highly recommend it, especially since it fits in your price range. I got mine from Paul'sTV if you are wondering, they MIGHT have a few left, you should call the main line for Paul's and ask them, though.
Jawzey is offline
post #3 of 5 Old 06-01-2012, 07:42 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
The TC-P42UT50 is the only 1080p Plasma in the 42" size and is by far the best choice in this size range (be it Plasma or LCD), especially considering how abnormally close you'll be sitting. All the other 42" Plasmas are 768p and would not look as good that close.
Be advised - the 42" UT50 was discontinued a few months ago and i think Paul's is the only retailer that has any left so if you want to get the only 42" TV worth having, grab one quick.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 5 Old 06-01-2012, 07:52 PM
Jawzey's Avatar
Too late. My Paul'sTV told me I grabbed the very last 42UT50 the company had in stock, they literally have NONE other. I'm really lucky I grabbed this thing before it was too late. Sorry bout that OP.
Jawzey is offline
post #5 of 5 Old 06-03-2012, 09:56 AM - Thread Starter
IDRick's Avatar
Liked: 24
Sorry for not replying sooner... I did see the recommendation on 6/1 but they were already gone when I called... My tv location is close to my computer and it is the only location that does not get daylight reflection from my window. This TV is used to watch NFL so it's got to fit my location or be an LCD.
IDRick is offline
