is it necessary to break in a panasonic u50 before gaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-08-2012, 03:20 PM - Thread Starter
jameslieb1's Avatar
im getting on tomoro
jameslieb1 is offline
post #2 of 12 Old 06-08-2012, 05:46 PM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
In a word, yes. Get at least 100 hours on the set before gaming, especially if the games have bright HUD's.
QuiGonJosh is offline
post #3 of 12 Old 06-08-2012, 09:16 PM
gregzoll's Avatar
Liked: 33
No, not necessary with today's sets. You will be fine to start playing games on it with no problems, and no, you do not have to wait a hundred hours before starting the games up on it. Enjoy your new set.
gregzoll is offline
post #4 of 12 Old 06-08-2012, 10:13 PM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
I hope that clears it up for you. In a word, yes, but no. Not necessary.
squeakybirnbaum is offline
post #5 of 12 Old 06-09-2012, 02:47 AM
mektarus's Avatar
That seems like a bit of a cheeky answer. wink.gif I'm curious about this as well, as I have a U50 on order and it will be my first plasma (and I'm an avid gamer). Anyone else care to weigh in?
mektarus is offline
post #6 of 12 Old 06-09-2012, 02:56 AM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
I gamed on my UT50 from the start and I still have some IR from a HUD. It's slowly fading away, but if I look real close for it, I can still see it. If I had just waited a week before gaming, it probably wouldn't have happened. So I say just take a week or so off from gaming or if you can, turn off the HUD's in the games you do play.
post #7 of 12 Old 06-09-2012, 04:05 AM
iBrad's Avatar
Yes, break in first 24+ hours with pixeljogger continuous loop:
http://www.avsforum.com/t/1406663/pixel-jogger-breakin-improves-pq-plasma-lcd-led-tv-the-only-way
Then before playing/watching tv each time, play pixel jogger 5-10 min. to warm up the display first and then after every hour or pauses, play pixel jogger 5 min. etc...
iBrad is offline
post #8 of 12 Old 06-09-2012, 01:58 PM
cv1981's Avatar
I started gaming on my U50 right away, although every half an hour or so I take a break and use the screen wash thing.
cv1981 is offline
post #9 of 12 Old 06-10-2012, 10:53 PM
kris achar's Avatar
Hi,wheather you break in you plasma or not,use your plasma carefully,since new plasma gets IR very easily...
Here is a quote taken from the master break-in/IR Thread II
Originally Posted by talltitan View Post
Samsung 51D550 owner here with what appears to be some bad IR from the Mass Effect 3 multilayer consumable item HUD. The set had a good 600 hrs plus on it before I ever played the game and the IR has been there for over 6 weeks since.
Settings where in game mode with the cell at 18, contrast at 85, brightness 42, 16:9 orbiter on at 4.4.1 setting.
In the six week period that I played the multilayer I couldn't have played any more than 30 hrs tops of the game, with no gaming session lasting longer than three hours. When I first got the set I tried to stress it pretty hard by playing no telling how many hours of Skyrim and a friend and I actually sat and played the hole Gears of War 3 campaign split screen together in one long night just a couple of days after buying the set with the only after effects being the normal IR that fades in a hour or so.
The IR is not really visible at all during normal viewing, the only time I can see it is against solid colored images most predominantly completely white backgrounds.
I have since ran the image swipe that is in the menu section for burn in on the set for probably 24 hrs, Zoyds personal washer for 24 hrs, and ran the break in slides for a good 12 hrs, and blasted it with a complete white screen in dynamic for a good 12 hours and then the normal full screen viewing that I watch plus other games and can't really tell that it has faded much or at all.
Outside of the one issue the set has been really good against retaining any images for no longer than a hour and even that retention was so light you really couldn't find it unless you went up to the set and looked for it.
I really like the set good picture and all but between this heavy IR which I hope will go away and the brightness pops that I had with set when I first got it, which where fixed from the USB update I got from Samsung the set has been little to problematic in my opinion
Any one here had IR like described above that took months to go away? Will unplugging the set when I am at work help?
God Is With You !
kris achar is offline
post #10 of 12 Old 06-10-2012, 11:08 PM
mektarus's Avatar
Man, the more I read about IR and burn-in the more worried I get about buying a plasma. My U50 hasn't shipped yet and I'm thinking seriously about cancelling my order. frown.gif
mektarus is offline
post #11 of 12 Old 06-11-2012, 02:28 AM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
Don't! The PQ, especially on this years Panny's, are amazing. Just be careful with station logos and keep gaming to short sessions, giving breaks every half hour for the first few weeks.
post #12 of 12 Old 06-11-2012, 03:52 PM
mektarus's Avatar
Well, I just got $100 price adjustment from Amazon. biggrin.gif So I'll definitely give it a try (especially since I have a 30 day free return period). I think I'll have to tell the family that no one watches tv unless I'm in the room. wink.gif
mektarus is offline
