Dents behind the bezel of a brand new Panasonic plasma. Should I be worried? (Pics) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 36 Old 06-09-2012, 01:20 PM - Thread Starter
plasma-black's Avatar
I just got my new 50" ST50 from Paul's TV a few days ago. The TV and all the accessories & documentation seemed perfectly brand new and in great shape when I unboxed everything. But today I noticed that the top of metal casing behind the bezel is a little wavy. In fact there's one area that I would call a good old fashioned dent. The indentations are only noticeable when the light hits them just right but you can see them pretty well in these pictures. **Another curious thing is that a few of the screws in the back of the set were loose enough for me to unscrew with my fingers.
Is this something I should be concerned about? Would this just be a general quality control issue that happened in the manufacturing process?
I also thought of the possibility that Paul's may have sent me a refurbished set. Thinking this, I went into the service menu to check how many hours are on the display. It showed around 60 hours used which is exactly how long I've been running D-Nice's slides.
So what do you guys think? I have no plans to return the set because of this but I'm just curious what other people would do in this situation.
Thanks!!
(Also, before anyone says I should have inspected the set while the delivery guy was here.... My condo is on the 8th floor of my building and the delivery company's policy was that they only deliver to the ground floor..no elevators, etc. I would have had to unbox everything on the side of a busy street in this case. I'm sure they wouldn't have waited for me to do this anyway.)
359
359
700
plasma-black is offline
post #2 of 36 Old 06-09-2012, 02:15 PM
Jawzey's Avatar
Well, take this into account. No one will ever see, that, except for you. If you put it up on the wall then for sure no one will see that. What I would do, however, is call PaulsTV. Tell them about your situation, and tell them how you were not able to inspect it on the busy floor level. Ask them what they can do about it to make you (the customer) happy. Just make sure you sound very unhappy or they won't try to please you.
Jawzey is offline
post #3 of 36 Old 06-09-2012, 03:45 PM - Thread Starter
Jawzey, I'm hearing you. The last thing I want to do is return the set, though. I think I could probably massage the dents out myself but I'd have to remove the cover. I'm just wondering how these dents and ripples got there. And why were some of the screws loose?? I'm assuming a human assembles these at the factory. It's just a weird thing to me. rolleyes.gif
Anybody else want to chime in?
post #4 of 36 Old 06-09-2012, 03:50 PM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
you just paid a lot of money for a new set, not a used one or a damaged one. Personally, I would call the retailer and get it exchanged.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #5 of 36 Old 06-09-2012, 04:07 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 498 Post(s)
Liked: 766
It looks like something damaged the set somehow before you got it - it's not likely that the assembly plant would have packed that TV with such an obvious dent in the top where it's clearly visible. I would compare the serial number on the TV's sticker to the sticker on the box and see if they match. I'm wondering if they removed that TV from the box to use as a store display then somehow dropped something on it, then quietly put it back in the box and stashed it back in the warehouse to keep from getting in trouble.....
I'd find out if the driver is supposed to wait 30 seconds while you inspect the TV for damage, and i'd also insist on a no-charge replacement. It takes literally 10 seconds to pop the upper half of the box off which exposes the whole upper 2/3rds of the set and allows for easy inspection for physical damage - we've done it at curbside before and even once on the back of the truck before unloading the TV.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 36 Old 06-09-2012, 04:22 PM - Thread Starter
Thanks for the reply Randy.
I just checked the serial numbers and the number on the set does match the number on the box. This situation is strange because everything in the box seemed perfectly factory sealed and brand new to me. The plastic wrap and stickers around the bezel were factory fresh as well. I also checked the hours used on the set in the service menu and the hours listed matched the hours I've had it running. I think I will go ahead and call Paul's and explain the situation and see what they say.
post #7 of 36 Old 06-09-2012, 05:02 PM - Thread Starter
I just got off the phone with Pau's TV. I just shot straight with them and explained the situation. I was a little surprised at the customer service agent's attitude. He actually talked down to me about the situation which I wasn't expecting at all because they have been great to me until now.
Anyway, he asked me to take all sorts of pictures of the TV and the box and they would file a claim with the delivery company. I told him it doesn't look like the damage happened during delivery, though, but I guess that must not matter. We'll see what happens next!!
post #8 of 36 Old 06-09-2012, 09:38 PM
Jawzey's Avatar
Did you order it from their site or from a store? If you ordered it from one of their stores I would advise calling that number, not the direct number to Pauls. Best of luck to you though! I recently got a 42UT50 and I wouldn't be happy either, but then again no one sees it. But then again, you paid big money for this set so this is no bueno.
Jawzey is offline
post #9 of 36 Old 06-09-2012, 10:25 PM - Thread Starter
That's a good idea about calling the store instead. There was a manager in one of their stores in California that originally helped me with this order. I almost hate to call him, though. Long story, but there was a problem involving the price and an online promo code when I bought the TV. We were going back and forth for a few days before everything got straightened out. And now there's this problem with the dents.
Honestly, when I noticed these indentations I just wanted to pretend like I didn't see them because I know it's usually such a pain to go through a return process....unless you're dealing with Amazon. I started to buy from Amazon for this very same reason but Paul's price was over $100 cheaper. Something to think about next time I guess.
post #10 of 36 Old 06-09-2012, 11:58 PM
Jawzey's Avatar
Don't feel intimidated. Just give them a call and tell them what happened. Tell them you want a local Paul's that is near you to come and swap the TV out with a different one. If there is a Paul's near you then they should be able to do it. If there isn't, and you don't want to deal with a return process, just keep the set and ask them for some sort of IOU or store credit, since a return is too much of a hassle to go through.
Jawzey is offline
post #11 of 36 Old 06-10-2012, 03:21 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
This won't help you now, but this is why I buy everything through best buy. If the price is off they will price match and if something is damaged they have the best customer service as far as returns.
Best of luck to you, I hope it comes out in your favor.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #12 of 36 Old 06-11-2012, 12:28 PM
Killyamomz's Avatar
Return it, don't risk it.
This could be an issue in the long run.
I too received my Panny just a few days ago and could not inspect it because...I was at work.
I would return it, get a refund, call up amazon have them price match pauls tv and get the set through amazon. I have returned 2 sets that have had issues and yes it's a hassle having to box everything back up but you're either getting your money back or exchanging for the same or different set. So far amazon has been solid about returns, refunds or exchanges.
Off topic question though - you mentioned running D-Nice's slides on your set....is it worth running the slides for 100hrs?
Killyamomz is offline
post #13 of 36 Old 06-11-2012, 04:16 PM - Thread Starter
I think you're right about returning it. What ever caused these dents must have been a pretty hard impact because that metal seems pretty sturdy. I'm also hearing you about your Amazon advice. I probably should have just followed my first instinct and bought from them from the beginning.
As far as D-Nice's slides go... Everything I've read said that the set would have a better overall picture if you allow the slides to prep the panel for the 100 hours and then calibrate using his settings. D-Nice and others made a pretty compelling argument in favor of it so I gave it shot. One thing they say is that the display has a certain amount of color shift during those 100 hours so that's why it's important to calibrate after that time.
Believe it or not, I could actually see a difference in the color of the slides towards the end of the process. I'm in the graphics and printing industry so I guess my eye is trained to see that sort of thing. The green seemed to start off as a grass green but ended up brighter and more fluorescent. The red also started out a deeper red and ended up being lighter and brighter.
I will say that the picture quality looked outstanding afterwards with D-Nice's settings. The set just finished the slides last night so I haven't had a lot of time to really check it out yet. The only thing I changed so far was I set the color temperature to Normal instead of Warm2 like he has. The Warm2 setting gave everything a yellowish tint that I didn't like.
Hope that helps.
post #14 of 36 Old 06-11-2012, 05:20 PM
rogo's Avatar
Quoted: 1586 Post(s)
Liked: 1787
Agreed on the wishing you luck.
As for retailers, I think putting Costco and Amazon in the same pantheon as Best Buy is more than fair.
Costco will take anything back for 90 days. Amazon will take anything back for (I believe) 30. Neither gives you grief about it either.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #15 of 36 Old 06-11-2012, 06:26 PM
EAGLEFAN67's Avatar
Liked: 31
Don't massage them out...don't remove the cover...you'll void your warranty.
I say go for a new one...or request a full refund and pick it up.
EAGLEFAN67 is offline
post #16 of 36 Old 06-12-2012, 02:52 AM
fatuglyguy's Avatar
Quoted: 277 Post(s)
Liked: 606
I would exchange it, but I'd hate the hassle. I've seen warping in some cheap bezel plastic, but since this is the rear metal casing it's a bigger deal IMO. Something had to have happened to the TV before it got to you, even it works fine.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Pro-Ject Debut Carbon DC Esprit + Tube Box S|Sonos Connect|Furman Elite-15 PFi
fatuglyguy is offline
post #17 of 36 Old 06-12-2012, 05:19 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I love Amazon too, but for electronics, I have a best buy right in town so it's easy for me to got there, no shipping, just drive 5 minutes.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #18 of 36 Old 06-12-2012, 11:00 AM
mohanman's Avatar
Quoted: 40 Post(s)
Liked: 33
Good luck with Pauls TV. I bought a VT30 there, and had picture quality issues. They won't do anything, they'll pass around your phone call, never call you back, and then finally give you another number and so fourth. Best of luck, hope it works out for you, but in future, I wouldn't buy from there again.
mohanman is offline
post #19 of 36 Old 06-12-2012, 12:57 PM
hidefpaul's Avatar
Quoted: 124 Post(s)
Liked: 79
+1
Paul
5.1 Home Theatre
Pioneer 60" Kuro
Integra DHC 80.3 Pre Amp
Parasound Halo A51 5 Ch Amp
Speakers : Elac's FS-247's (L,C,R SR, SL)
Sub: Velodyne SPLR1000
hidefpaul is offline
post #20 of 36 Old 06-12-2012, 01:18 PM
Mac13's Avatar
I would exchange as well. Good luck!
On another note, where are D-Nice's settings posted? Does he have them for all the 2012 Panasonic lines?
Mac13 is offline
post #21 of 36 Old 06-14-2012, 12:40 PM - Thread Starter
Mac13, You probably know this by now...but D-Nice's settings can be found at "high def junkies dot com". Some advice...Make sure you follow the steps exactly. **Also make sure the photo viewer itself is set to be in Custom picture mode. You can find this by pressing Menu on the remote while you're in the Media Player photo viewer.
(I think some people thought that the TV had to be in Custom mode in the main picture menu only. D-Nice's setting won't be any good if you don't change the photo viewer picture mode to Custom.)
post #22 of 36 Old 06-14-2012, 12:49 PM - Thread Starter
A quick update to my situation...
Paul's TV agreed to exchange the TV at no cost to me. The replacement is already on the way. They first offered to just give me some money off on the set I have now but I wasn't interested. I didn't even ask the dollar amount they had in mind. I told them I would just feel more comfortable with a new set since there's no way to know when/where/how this damage took place.
Thanks to everyone for your advice and input! The ST50 truly is a great TV and I'd highly recommend it to anyone. Just make sure you inspect in closely the second it gets to you...no matter what!
post #23 of 36 Old 06-14-2012, 04:06 PM
Dierkdr's Avatar
Liked: 54
....Paul's TV agreed to exchange the TV at no cost to me....They first offered to just give me some money off on the set I have now but I wasn't interested. I didn't even ask the dollar amount ...
Sounds like this is working itself out as it should - and think it was nice that Paul's gave you a pair of options.
Even though I agree with the other comments that an Exchange is a better solution than Cash Back, I don't think it was out-of-bounds for Paul's to offer a partial refund on the set: had it been a large enough amount, might have proved an interesting option.
At the same time, probably would have insisted upon a Free Extended Warranty - IN Addition to whatever refund they offered - just for peace of mind. And, of course, there is a good chance they would have balked at that combination!
Hope your replacement panel works out well!
Dierkdr is offline
post #24 of 36 Old 06-16-2012, 09:55 AM
Splicer010's Avatar
Liked: 39
I woould've taken the partial refund if it were me...
Splicer010 is offline
post #25 of 36 Old 06-16-2012, 10:03 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I've done that on appliances that have damage on the hidden panels, but damage on the center point of a room that has very sensitive componenets makes me a little uneasy.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #26 of 36 Old 06-17-2012, 05:46 PM
Semp1's Avatar
Quoted: 12 Post(s)
That's completely normal with Panasonic plasmas. I don't know why but it is. Google VT30 dent. Matter of fact i posted about the rear of mine along with others last December on AVS, so yes its Ugly and unpleasnt to look at but normal. My VT30 had little lumpy parts on the rear. Granted some are worse than others and mine isn't as noticable but the dents are normal. I don't understand why. Same thing with Panasonic using screws that are too long for the rear of the VT30 top. They clearly don't care too much about the rear of the panels.
65VT60+55GT50+Onkyo TX-NR727+Denon AVR-1913+OPPO bdp-103+OPPO bdp-83=Heaven
Semp1 is offline
post #27 of 36 Old 06-17-2012, 06:56 PM
"Don't PM Me Bro"
Quoted: 498 Post(s)
Liked: 766
It's not completely normal, i've seen the backs of dozens of Panasonics and none of em have lumps or dents or baseball bat impressions along the top. And i don't see what a lumpy rear cover on a few VT30s has to do with mystery damage along the top of the OP's ST50.
Randy
post #28 of 36 Old 06-18-2012, 10:04 AM
bhchan's Avatar
I recently got a tv from Amazon (not this make/model) that also had a similar dent on the top of the set, to the point where the screen looked somewhat warped at that point. Luckily I noticed it while the delivery folks were unpacking. In my noobness, I asked the delivery folks to pack it and take it back. Amazon took care of things, though I was miffed I didn't get to enjoy my tv for another 5 days. What I should have done was test if it turned on, and kept the tv while Amazon shipped the replacement.
Sorry to hear about PaulTV's lack of service.
Surprised someone got great service at Best Buy... they're also folks I usually have problems with, at least in the past, except for their Pacific Sales section.
One Sub to rumble them all. One Sub to shake them. One Sub to humble them all, and in the darkness break them.
bhchan is offline
post #29 of 36 Old 06-18-2012, 12:30 PM
Semp1's Avatar
Quoted: 12 Post(s)
Not all sets experience the issue. And not all are as drastic. I would've exchanged to for his exact problem. But the fact remains that many Panasonics come with weird lumps and dents in the rear. Which by any ones definition makes it normal.
Semp1 is offline
post #30 of 36 Old 06-18-2012, 07:43 PM
jasonelmore's Avatar
I do warranty repair on tv's occasionally, and i can tell you this.
If you ever have to have that TV repaired, they are gonna send a repair guy out there. That repair guy will inspect the TV for damage before attempting his repair. If he notices that dent, that could be a problem and may stop you from getting free warranty repair. Also, taking off the cover to smooth those dents will void your warranty. Something you do not want to do.
I suggest either call the manufacturer, and have these dents well documented, save all conversations you have with them and put them up for safe keeping. Also call Pauls, or where-ever you bought it, and ask for a gift certificate or some cash back for compensation. otherwise......
Take the TV Set back, and get a new one, as long as your within 30 days of the purchase date, the retailer should take it back no questions asked.
jasonelmore is offline
