size or quality? e550 vs gt50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-11-2012, 11:42 AM - Thread Starter
camper kings's Avatar
Alright I know that the GT50 is a better tv then the e550. However I can choose to get 64inch e550 or the 60 inch gt50. (its a points thing through work). Would you sacrifice size or quality? Just wanting some opinions here. Thanks!
camper kings is offline
post #2 of 9 Old 06-11-2012, 11:59 AM - Thread Starter
Found a lot about this topic here and the consensus seems to weigh in the size favor however GT50 seems to be a lot better TV then the e550? I am sitting about 10 feet away.
post #3 of 9 Old 06-11-2012, 12:14 PM
Killyamomz's Avatar
Both sets have their flaws for sure.
I owned the Samsung PN51E550 and returned it due to auto brightness adjustments during hockey, random flickering during sports and annoying buzz. I wanted to like the Samsung because overall the sports looked pretty darn good except for the Hockey issues. So after returning the Samsung, I went with the Panny GT50 and received it last Friday, the bezel is so much nicer looking compared to the Samsung, 4 HDMI slots instead of 3, 3 USB slots, SD card, WiFi and 3D (no glasses though). I have only had the set a mere 2 1/2 days and so far out of the box, blu ray movies are very nice looking, with a good amount of tweaking options but the HD sports looked grainy and washed out, I was using the standard picture mode; some folks reached out and gave me some tips so I will be putting it to the test against tonight's cup finals match.
In my opinion, go with Quality.
Killyamomz is offline
post #4 of 9 Old 06-11-2012, 02:31 PM
Joxer's Avatar
Thats not really a far comparison.
Since the E550 is Samsung's lower end model and the GT50 is a higher end Panasonic model.
The Panasonic UT50 models are directly comparable feature-wise to the E550.
The GT50 is more like the higher end Samsung E7000 models.
Joxer is offline
post #5 of 9 Old 06-11-2012, 02:35 PM - Thread Starter
I am not trying to compare the 2 TV's what I am saying is I can get the 64 inch E550 for the same as the 60 inch GT50. So should I get the bigger one or is the GT that much better where I should get the 60 inch?
post #6 of 9 Old 06-11-2012, 03:51 PM
Ace1965's Avatar
Pick Size unless your option is a crappy tv. The E550 will be perfect, I think! Enjoy
Ace1965 is offline
post #7 of 9 Old 06-11-2012, 05:38 PM
Jtm79's Avatar
If you watch mostly hd and 3d in dark room then take Sammy, but if you are in bright room take Panny.
Jtm79 is offline
post #8 of 9 Old 06-11-2012, 08:20 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
Quality over size any day. What's the point of having a bigger screen if you can see every flaw. I would go for the GT
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #9 of 9 Old 06-11-2012, 09:29 PM
Jtm79's Avatar
Exactly what flaws E550 has? Im sure it is pretty similar to more expensive sammys which rivals panasonics. Only flaw is that this doesnt have ar-filter, but in a dark room thats not an issue.
Jtm79 is offline
