65 inch tv stands with mounts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-13-2012, 09:52 PM - Thread Starter
BlouZbee's Avatar
Hello all, i apologize if this isnt the best place for this question.
the wife gave me the green light to upgrade. i know which 65 inch PDP i want but i cant find a stand for it. the top shelf is for the center speaker so there needs to be at least 8 inchs from the bottom of the screen to the top shelf. without going into detail this is the way it NEEDS to be done and if i cant work it out its a deal breaker:( ive been goggling for 3 days now and still nothing.)
anyone else with similar requirements and what did you guys do?
thx
-matt
BlouZbee is offline
post #2 of 9 Old 06-13-2012, 10:09 PM
jdevenberg's Avatar
I just got a Cheetah Mounts Tilting TV wall mount from Amazon and installed it over a simple entertainment stand today. It was only like $25 and had excellent reviews and was super easy to put up, I did the whole thing by myself and all I needed was a drill, a Philips head screwdriver, and a ratchet and 1/2" socket (since my cheap drill didn't have enough torque to drive the mounting bolts all the way into my studs). It also came with a decent 10' HDMI cable and a magnetic level to help make sure everything is straight. I am very pleased with it so far. I do recommend getting a 90 degree HDMI elbow though, cause with a standard HDMI cable, you can't really use the mounts tilt.
jdevenberg is offline
post #3 of 9 Old 06-14-2012, 04:10 AM - Thread Starter
BlouZbee's Avatar
Thx for the response. let me clarify....
im looking for a stand WITH integrated mount that supports a 65 inch plasma AND allows for clearance for a center channel speaker below the TV. i have no wall to mount to and a center channel that can NOT have something over top(like a middle shelf) i was hoping other large screen owners had similar needs so i could reference their solutions. it seems once you hit 65inch screens options fall apart due to panel size.
-matt
BlouZbee is offline
post #4 of 9 Old 07-01-2012, 05:51 PM
Del Cosmos's Avatar
I'm also looking for a stand. You might be able to pull off a "Freestanding" TV mount, and a separate low profile shelf.
See:
http://www.amazon.com/Arena-9972-Freestanding-Panel-40-Inch/dp/B002M8SV2C/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1341188712&sr=1-2-catcorr&keywords=freestanding+tv
Too rich for my blood - but in line with your budget.
Del Cosmos is offline
post #5 of 9 Old 07-01-2012, 08:01 PM
pod13's Avatar
I've mounted my 65" VT50 to the Stolmen posts from Ikea using C-brackets and a wall mount. The center channel sits on a Stolmen shelf above the TV. This doesn't have another shelf above the center but the posts do extend above the center to the ceiling.
Poles and Shelf
http://www.ikea.com/us/en/catalog/categories/departments/bedroom/19087/
TPK-5 Truss Kit
http://www.standsandmounts.com/chieftpkpoleandtrusskitsfortpstpmandtppmountstpk.aspx
Wall Mount
http://www.standsandmounts.com/premiermountsentertainmentseries50-80inflatpanelmountlpfm5080.aspx
pod13 is offline
post #6 of 9 Old 07-01-2012, 09:30 PM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
This is the one I have. Works great, and is on sale now too:
http://www.walmart.com/ip/Home-Trends-3-in-1-Flat-Panel-TV-Console-With-Swinging-Floater/11987914
It can easily handle a 65" Panasonic, and my center speaker sits on the top shelf.
bhazard is offline
post #7 of 9 Old 07-02-2012, 08:13 AM
Del Cosmos's Avatar
What size center bhazard?
post #8 of 9 Old 07-02-2012, 11:40 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 55
7" tall.
Don't expect to have a 12" tall center speaker on the top shelf. You should be able to stick it into the middle shelf with no issue however.
bhazard is offline
post #9 of 9 Old 07-02-2012, 12:58 PM
Del Cosmos's Avatar
I'm in a similar situation, yet I'm trying to place the center channel on top of the unit (below the tv). 8" Center
