Samsung buzzing...any recommendations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-18-2012, 07:52 PM - Thread Starter
guinsdan's Avatar
I have a Samsung PN63B590T5FXZA and there is a loud buzzing sound from the lower left (looking at it from the front). A tech came out three times and they can't figure it out. It's right near the plug, and they replaced the board and ps.
It is louder when it renders bright images (especially a white screen), and if I put pressure on the spot it dampens the sound.
I tried searching and I saw older SS plasma's that needed the following:
Install a felt cushion, Samsung part number is: AA63-60122L. The cushion will fill the gap to provide insulation between the FPC cables and rear panel.
guinsdan is offline
post #2 of 3 Old 06-19-2012, 09:26 AM
BillP's Avatar
Quoted: 260 Post(s)
Liked: 201
Samsung plasmas are known to have buzzing issues. All plasmas buzz, but usually you cannot hear it at normal viewing distances. Loud, annoying buzzing is a defective display. I would return it for another if possible (you don't state whether this is a new purchase).
BillP is offline
post #3 of 3 Old 06-19-2012, 03:23 PM - Thread Starter
guinsdan's Avatar
I cannot return it, it is over two years old.
guinsdan is offline
Samsung , Plasma Hdtv , Displays
