Looking for quick confirmation that this will work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2012, 11:44 AM - Thread Starter
blakeyj08's Avatar
Hi everyone,
I've googled and searched these forums, and think that this will work, but just wanted to make sure I'm understanding correctly.
I have a Wii, a Panasonic Viera P50ST30, and a Denon receiver.
Since the Denon receiver doesn't have any analog inputs, I'm planning on hooking the Wii up directly to the TV, then using an optical audio cable to hook up the TV to the receiver. Will this give me the Wii audio through my receiver/speakers?
Thanks for the help!
Edit: What I need to know is if the tv will pass the audio that it gets from the Wii through the digital audio output jack.
blakeyj08 is offline
post #2 of 3 Old 06-20-2012, 02:27 PM
Hail2theSkins's Avatar
Hi, I currently have my ST30 hooked up this way, and it works fine. It makes it easy because you don't have to switch inputs on the receiver and the tv, just the TV.
blakeyj08 likes this.
Hail2theSkins is offline
post #3 of 3 Old 06-20-2012, 03:08 PM - Thread Starter
blakeyj08's Avatar
Awesome, thanks.
