LG 60PM6700 vs Panasonic TC-P65ST50 - Best for 24fps and PC monitor? Viera Connect Netflix issues? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-26-2012, 10:47 PM - Thread Starter
HTtom's Avatar
UPDATE: Now looking at the LG 60PA6500 instead of the 60PM6700 as I don't need 3D, Smart TV or the fourth HDMI input. The 65" is a little bigger, which is nice, but I'm curious about the difference in motion blur (if any) and picture quality for 24fps 1080p Blu-Ray playback. That's the deciding factor -- more than the price difference.
LG 60PA6500
The two hairs I'd like to split are:
1) 24fps Blu-Ray playback: Is one set superior to the other?
2) Motion blur: They're both plasmas, but which will provide the smoothest motion from a 1080p Blu-Ray source?
UPDATE: We're getting a small monitor for internet. It's now down to the better set for Blu-Rays. Previous question about internet no longer applies.
And according to a review on Amazon, the apps are connected through Panasonic's servers instead of directly to Netflix. True or not true? Is there a way to connect directly?
http://www.amazon.com/review/R3VVUIOKHP32GK
--If it does, I have my Blu-Ray player's streaming as a back-up. This is a minor technical question that won't impact the purchase.
If it makes a difference, our current viewing distance is 8' and we could back it up to 9'. Thanks.
ETA: mysq wanted to compare these sets in May:
http://www.avsforum.com/t/1409618/advice-please-60-panny-st50-or-lg-60pa6500-or-lg-60pm6700
HTtom is offline
post #2 of 2 Old 06-27-2012, 10:56 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
Whats your percentage of PC use, bluray, cable etc and how is the room lighting, controlled, uncontrolled. I usually lean Panasonics way just a personal preference but with some more info you can get some good input here.
65C6 OLED/65 A1E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
Panasonic Viera Tc P65st50 Plasma Tv , Lg 60pm6700 Plasma Hdtv
