Panasonic TC-P42X5 for gaming??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-29-2012, 07:47 AM - Thread Starter
Digex's Avatar
AVS help me out, does anyone know anything about this TV and its input lag with PS3 game console? I want this TV strictly for gaming at 720P in my game room. I already own a Sony Bravia for the HT and it has terrible input lag for a 50".
http://shop.panasonic.com/shop/model/TC-P42X5
Digex is offline
post #2 of 4 Old 08-09-2012, 08:32 AM - Thread Starter
Digex's Avatar
I guess nobody knows???
Digex is offline
post #3 of 4 Old 08-09-2012, 12:11 PM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
I think i may be one of the 2 on this site that actually owns a 42" X5. tongue.gif I've disussed already about this particular set quite a few times but
in different random threads, but overall for gaming i think many gamers may in fact be satisfyed by the 2 frames/32ms response. However, that's on the wii via component.
Using an HDMI adapter(Scale free & no lag added) there's some 'slightt' lag added in comparison. I tried out my PS3 on it via HDMI with Rayman Origins, Batman : AC and Mega Man 9 and i think it's safe to say that it's slightly over the 32ms range.
For me that personally doesn't cut it.
Try it out and see for yourself. Make sure to do the following for the lowest possible lag
Connect HDMI/Componenet directly into TV.
Turn off Video noise reduction
Turn off Color management - (adds more lag when turned 'on')
Set Color Matrix to 'HD' - (Even if the content is SD setting it to 'SD' causes more lag)
And you're good to go. I've gotta say though, game mode produces one hell of a fine picture picture for gaming. The brightest plasma
i've seen yet, the color gamut is absolutely fantastic, you'll beable to achieve some wonderfuly rich and vibrant colors, the blacks are pretty solid while the motion being pretty good
isn't 'quite' as good as some of the 600hz LG sets, close, but some slight blurring is still evident. But it's miles better than any LED or LCD.
Keep in mind, you wont beable to resolve 1280x720 for PS3/XBOX games considering the 50" plus 42" are both 1024x768. Still looks good though when the shaprness is set properly.
I tend to stick it in 74 for PS3 games. Try it out and see if you like it! I'm going to return mine and go for panny's 50I want to properly resolve 720p for Wii U games, and get 1080p for Bluray, plus i NEED
lower input lag and better blacks which is why the S30 or ST30 for me is a must. You may be pretty impressed by the X3 in the lag department, i'm pretty anal and demanding
however and i need the best. XP"
WaveBoy is offline
post #4 of 4 Old 08-11-2012, 01:41 PM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Also when it comes to movies i find last years LG 720p PT350
to be the better set. There's 'nothing' funky going on. The picture is noise free, it looks super clean,
the motion is top notch for a plasma and it produces a nice bright image. The only downside i could possibly
find are the black levels, but at the same time the X5's aren't exactly 'that' much better.
The X5 suffers from quite a bit of noise with some sort of wierd integrated edge enhancement. Don't plan on watching
movies with anything but 'cinema' since the other modes look awful and will produce so much noise in the skin
to the point where people get this wierd artifical clay faced effect. The LG also has better gamma control, where
as the X5 is ever so slightly on the milky side lacking a bit of that punch. And again, the LG is superb in the motion
department, while the panasonic still has a bit of noticable blur.
If the LG had better blacks i'd give the PQ a 10/10 for film 1024x768 resolution aside. But for gaming, however the LG dissapoints because of it's
horrible input lag. The panaosnic also offers a much brighter image, a far better color gamut and the
ability to display black 4:3 bars on the side of the screen. I'll never go LG again, but that's because their
plasmas are known to be the worst input lag offenders! XP
WaveBoy is offline
Panasonic Tc P42s2 42 Inch 1080p Plasma Hdtv , Plasma Hdtv , Lcd Hdtv , Panasonic Viera Tc P50s30 50 Inch Plasma Hdtv , Panasonic Viera Tc P42st30 42 Inch 1080p 3d Plasma Hdtv , Lg 50pt350 50 Inch 720p 600 Hz Plasma Hdtv , Panasonic 42 Inch Class X5 Self Illuminating Plasma Tv Tc P42x5 Television Fast Shipping
