Panasonic gt50 vs samsung plasma pn60e8000 or 7000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 07-01-2012, 04:04 PM - Thread Starter
scofal's Avatar
Hi,
I'm looking to buy a plasma tv for 1080 viewing and also for 3d.
I read a lot of reviews online and they typically give the nod to Panasonic.
So my wife and I went down to best buy today to take a look at them in their magnolia room.
No matter what Bly ray they put in, my wife and I both thought the Samsung's picture was night and day, more vibrant and sharper looking.
Could it be that the the Panasonic wasn't calibrated correctly?
Honestly my current tv has a max resolution of 1080i and the Panasonic reminded me of that, where the Samsung looked crisp and bright.
Reading all the reviews, am I not seeing something?
To me the panasonic picture wasn't even close to the Samsung 8000.
It may be a little more money but it even looked better then the vt50 ( which had a concert on but they didn't out anything else on that one)
Thanks for any help that you can offer, I really want to buy a tv this week and want to get the best picture quality as I can. But I don't want the setup at best buy to dictate my buying decision if it doesn't really reflect the actual quality.
scofal is offline
post #2 of 23 Old 07-01-2012, 04:34 PM
jav1's Avatar
Quoted: 23 Post(s)
Let me try and help a bit here. I've had both the E8000 and VT50 (gt50 PQ is almost identical) in home. Ddin't have them side by side but in my opinion there are trade-offs to both. And it really depends on what matters most to you. I found the VT50 to have much better black levels and shadow detail, without question you can see more detail in dark scenes with the VT50, where the E8000 crushes black. On the downside if you don't feed the VT50 an excellent source it is not that great at improving signals. This is an area that the Samsung really shines in. It does an outstanding job at removing noise and presenting clear sharp images with all sources and especially typical compressed HD cable. I found the VT50 to sometimes really struggle with HD cable sources. While at times the image can look outstanding, it can also quickly become soft and a bit blurry. I also experienced problems with motion on the VT50, again at times excellent but on vertical pans would see choppiness and occasional flicker. As for color representation they are both strong, because of the VT50 deeper blacks, colors seem a bit deeper and more saturated on the VT50. If your set will be in a bright room, the VT50 seems to go a bit brighter. If I were a big-time movie watcher of blu-ray or other high quality source, the VT50 would be the way to go. If you watch mostly HD cable, maybe more shows and sports than movies, the Samsung should do fine. There are other factors to consider if you read through the dedicated threads, such as DSE, buzzing, vertical lines, IR, etc. No set is perfect, hope this helps. Best of luck.
David_B likes this.
jav1 is offline
post #3 of 23 Old 07-01-2012, 05:53 PM - Thread Starter
scofal's Avatar
Thanks for all the information.
scofal is offline
post #4 of 23 Old 07-01-2012, 06:51 PM
Joxer's Avatar
The stores don't really calibrate the models, so who knows what the Panasonic was set at.
At least it needs to be put into THX mode, but it probably was in Standard mode in the store (very dim in comparison)
Joxer is offline
post #5 of 23 Old 07-01-2012, 10:20 PM - Thread Starter
scofal's Avatar
yeah it seems much dimmer than the Samsung. They probably had it on the standard mode.
I went back and looked again, considering the importance of the black level, I purchased the GT50 (the VT50 is a bit out of my price range).
Does anyone know the average price I should pay for someone to professionally calibrate a TV?
scofal is offline
post #6 of 23 Old 07-01-2012, 11:06 PM
melio111's Avatar
I own a GT50 and from what I gathered many seem to believe it doesn't need calibrated or just don't feel they need to. I use either THX Cinema and Custom. If you go to CNET and look at the review posted, the reviewer posted his calibrated settings, which I think does look a tad better than THX imo.
melio111 is offline
post #7 of 23 Old 07-01-2012, 11:14 PM
ComputerTech0903's Avatar
I'm not sure what size you got, but the 60" GT50 is $2,000 + tax at Best Buy while $1,900 at Amazon I'm assuming that's around a $250 difference in price.
Also, the GT50 and ST50 are identical TVs subtracting the THX mode, so if you got a 60" ST50 you'd pay $1,600 at Amazon which is around a $550 difference from 60" GT50 at Best Buy.
And make sure to check with your credit card companies but a few of them I think American Express and another one like Visa or something offer free extended warranties on electronics purchased with your credit card. Keep an eye out for that too.
ComputerTech0903 is offline
post #8 of 23 Old 07-02-2012, 05:20 AM - Thread Starter
scofal's Avatar
I paid $1,899 at best buy for the 60" GT50
The guy in best buy said I have 30 days to check at the tv and I could return it if I'm not happy so I figured that was good. ( I can swap it out)? Plus I had some reward zone coupons I was able to use.
I did look at amazon and when I looked they were $1,947 or something like that so the best buy deal was better ( amazon may have dropped their price since)
I just thought it was easier to schedule a big delivery with an actual person at a store.
I thought about the ST50 but for a couple hundred more I get the THX mode which should help if I don't get it professionally calibrated right away and the dual core processor, I know it's for the apps and I may never use the apps but I like to know I'm covered incase I do.
Thanks for the suggestion.
scofal is offline
post #9 of 23 Old 07-02-2012, 06:41 AM
gizzygone's Avatar
Quoted: 67 Post(s)
I'm curious to see how you like your GT50 after your first few hours. I too purchased one yesterday, given all the praise, but now I'm tempted to take it off the wall and swap it out for the Samsung.
gizzygone is offline
post #10 of 23 Old 07-02-2012, 01:19 PM
sonyfan's Avatar
Great post jav1
The Samsung's do have superior picture processing power.
They make the processors for ALL the Apple ipads and phones so
it makes since that tech is used in their panel's also.
The movie fit mode 1 and 2 work wonders when I don't want black bars
and want to go full screen and it's still wide screen
and only clips a bit off the top and bottom.
Even with downloaded AVI files playing off a 'data dvd' look fantastic!
sonyfan is offline
post #11 of 23 Old 07-02-2012, 02:32 PM
Ace1965's Avatar
Ace1965 is offline
post #12 of 23 Old 07-03-2012, 06:56 AM
DanBook Pro's Avatar
I just pulled the trigger on a 64E7000. It should arrive on July 6th. Due to all of the burn-in issues with panasonic and my unbelievable lucky streak with Samsung, I couldn't justify jumping makes.
I really love the look of the GT/VT but i'm too much of a gamer to coddle the panasonic and treat her right. My C8000 and D7000 both kept up very well with my gaming habits and I hope the E7000 is up to the task as well.
Best Buy had a reasonable promotion where they threw in a Samsung Soundbar for free. I already have a surround sound system so the Soundbar will be returned for a $200 credit once I take delivery and am happy that the E isn't a loud buzzer.
I will post my results once i get the TV all set up on Friday.
DanBook Pro is offline
post #13 of 23 Old 07-03-2012, 12:25 PM
popnfresh98's Avatar
Please do follow up once you get it. I'm also considering a 60e7000 or 6500. I currently have a VT25 which I'm sick to death of babying. I don't play games according to my schedule since buying this TV.. I play according to the TV. Keep rotating games, no session longer than 2hrs, run some other content for awhile etc etc otherwise huge amounts of visible image retention.
Sorry for the little rambling there, but after seeing the cnet accidental IR test I'm a little hopeful on the samsung this year as I'm a big gamer as well.
Please do update us =)
popnfresh98 is offline
post #14 of 23 Old 08-23-2012, 07:50 PM
armand9601's Avatar
Any other thoughts on the Samsung 64E7000? Hoping to buy this weekend but I'm starting to wonder if the Panasonic GT50 is the way to go...
armand9601 is offline
post #15 of 23 Old 08-23-2012, 08:30 PM
strong island 1's Avatar
I'm really confused as well. I have the 60e7000 but thinking of swapping for the vt50. I think I would rather have the better black levels and shadow detail.
strong island 1 is offline
post #16 of 23 Old 08-23-2012, 08:36 PM
if you pick the samsung tablet with the bundle at best buy with the e7000 it has the peel remote which is actually pretty cool and you can control all your devices and the tv. You can control your dvr menus also. The tablet has an IR blaster built in so theres no delay like a wifi remote, it also found me some shows that I didn't know were on. I don't use it a lot but it's kind of cool.
post #17 of 23 Old 08-23-2012, 08:38 PM
I also get a pretty annoying buzz from the 60e7000. I can definitely hear it from my viewing distance. It's wierd though because my dad can't hear it. It's pretty annoying though.
post #18 of 23 Old 08-23-2012, 11:02 PM
BlueKhaki's Avatar
You have 30 days (60 if you're RZ silver) to return the TV or price match it, including amazon. You can call them up and ask for a return exchange if you decided to switch it out for a samsung (although you shouldn't in my opinion) and they'll schedule the guys to go back out with the new one and take away the old one, and refund you back if its less expensive.
I keep all the good Panasonics in THX Bright Room mode playing Avatar at my store, with the lights above the TV it needs to be in that mode to look good. But for the most part, any of the TVs that aren't in Magnolia have to be in Dynamic or Vivid because of the intense lights, so the pictures on them looks like crap.
A word of advice, once you get to Silver Status for Reward Zone (Spend $2500 in one year), go back in the store and set up your free calibration. Most people don't realize you get one free after you get to RZ Silver, and it improves the picture tremendously.
BlueKhaki is offline
post #19 of 23 Old 08-24-2012, 12:57 PM
Ya I just exchanged my 60e7000 for the 55" vt50. They delivered the Samsung free and are also coming to get it when they bring the vt on Monday which I think is great because I just did the exchange just now. Shopping at Best buy is a great experience and is worth the extra money. I also was able to get them to price match Amazon for the vt50 which gave me another $100 off. the Samsungs are the same price everywhere so price matching doesn't help with them. They didn't even ask a single question about why I wanted to swap.
post #20 of 23 Old 08-24-2012, 06:16 PM
BlueKhaki's Avatar
Samsung and Sony TVs (the good ones anyway) are all UMRP (unilateral pricing) and cannot be marked down anywhere. So Best Buy has them for the same price as amazon, etc.
post #21 of 23 Old 08-24-2012, 09:51 PM
ya thats why I was saying price matching doesn't matter with samsung this year.
post #22 of 23 Old 08-29-2012, 07:21 PM
armand9601's Avatar
Well my E7000 was delivered yesterday & all I can say is wow! Haven't calibrated it yet but out of the box it's amazing... Only issue I'm having is my wife suggested bringing it back & getting the 64"!
post #23 of 23 Old 08-29-2012, 07:59 PM
Audiodork's Avatar
Liked: 37
Hello,
I have had a TC-P60GT50 for around a month now and have not even had a trace of IR let alone burn in.. I have actually had 2 of them due to BB stripping two screws on the pedestal of the first 60GT50. (1st one July, 2012, 2nd April 2012 Build Date) While I simply asked for two screws, it went from a new Pedestal being brought over to bringing out a whole new TV. As I had gone through 150 hours, I really did not want to go through break in again. As for the break in, all it really consisted of was keeping it to 1.78:1 source material and not using torch modes. In truth, upon finding out I was getting a replacement 60GT50, I did try video games, 3D Movies et al and did not even have a trace of IR.
Comparative to the number who have purchased a VT/GT/ST/UT Series, I think my experience is quite normal. Like with most things . those who have experienced IR have certainly been more outspoken. However, it seems a number of those affected were using vivid and or had the brightness and contrast cranked during the first couple hundred hours. In truth, I specifically purchased the TV from Best Buy to purchase their PSP as it is one of the very few that does cover burn in. I am now seriously considering getting my money back on the PSP as I honestly do not think IR/burn in is going to be an issue.
It really is a shame as these 2012 Panasonic Plasmas are truly special. I still do not understand how or why the 60GT50 ended up with IR or Burn in while the 55VT50 ended up clearing up in regards to the Cnet Article as they have the identical panel. In addition, after reading almost all of the VT/GT/ST Owners Threads, the numbers are relatively small of those who have experienced IR or Burn In.
It is great that the 2012 Samsungs seemed to have had hardly either, but I do think the 2012 Panasonic issue has been somewhat blown out of proportion. Also, I got ridiculously lucky and ended up paying $1750 for my TC-P60GT50 as there was a free Panasonic 3D BDP Promotion at the time of purchase. Due to the Night Manager inexplicably changing the price from $1899 to $1750 and charging $149.99 for the BDP whereas the price should have remained $1899 and the BDP would have zeroed out. Regardless, due to this, I was able to return the BDP and put the $160 (after taxes) towards the 4 year PSP. Even better, the PSP went down to $329 from $499, It is only because of this that I might keep the PSP.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
Samsung Pn60e8000 60 Inch Ultra Slim Plasma 3d Hdtv
