Vertical white stripe on Plasma. LG techs made my set worse! - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2012, 07:11 AM - Thread Starter
Matt_Stevens's Avatar
Liked: 48
Okay, so I have a massive amount of green dithering on my set. I was hoping it could be tweaked out. A technician showed up and said it could, but needed to schedule a time to come back as it would be time consuming.
A week later, two different techs show up with a brand new display panel. Huh?
I told them that would NOT fix the problem (a problem they saw within seconds of my showing them).
Well, they insisted and it ddn't change a thing. So they said they needed to come back in a week with the main board and power supply. rolleyes.gif
That night, THIS appeared...
343
I can get rid of it by turning the set off and then back on a few minutes later, but it always comes back. Sometimes within seconds. Sometimes within fifteen minutes or so.
It is BRIGHT and causes immediate image retention. It seems to show up when there are bright objects that appear on the screen.
If I use a FLASH Drive that has break-in images and put that on a slide show, it does not return and the image retention goes away. But as soon as I go back to the DVR or Blu-Ray, BINGO, it comes back.
AND there is a big piece of dirt between the glass and the panel. Wasn't there before.
So what is going on with my TV?
The service company's mailbox is full. Cannot leave a message. No answer.
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
Old 07-02-2012, 10:45 AM - Thread Starter
Liked: 48
UPDATE: Talked to LG today and they are submitting my case for a replacement. Will know after the holiday.
60PZ950 LG by the way.
Old 07-04-2012, 08:41 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Just curious. How long have you had the set?
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 07-04-2012, 01:04 PM - Thread Starter
Liked: 48
Since April of this year or thereabouts. Might be early May.
Old 07-04-2012, 04:23 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
With that kind of issue, if it were me and the TV was less the 90 days old, I'd ask for a new set from the get go.
Ian
mailiang is offline
Old 07-07-2012, 10:53 AM - Thread Starter
Liked: 48
LG has now stated they will send me a new set. Waiting for more details.
Old 07-07-2012, 09:58 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Ian
mailiang is offline
