Samsung PN51D490 Plus Seagate 3TB Desktop USB 3.0 Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-02-2012, 05:46 PM - Thread Starter
Hawk75's Avatar
Basically I'm trying to get my TV to see my brand new external HDD.
It's USB 3.0 but backwards compatible to 2.0, and when I plug it in all it does is light up. I normally use thumb drives, but decided that I would rather be able to browse my movies instead of just watching one at a time, but I am currently unable to do that. The drive is formatted to NTFS, which I know works because some of my thumb drives are as well.
Has anybody else had this problem with a Samsung TV, and if so how did you fix it. I would just use my Xbox 360 or PS3, but they only support FAT32, and that will not work because some files will be bigger then the allowed limit.
Hawk
Hawk75 is offline
post #2 of 8 Old 07-04-2012, 10:18 AM - Thread Starter
Hawk75's Avatar
Anybody know anything that will help?
Hawk
Hawk75 is offline
post #3 of 8 Old 07-04-2012, 08:19 PM - Thread Starter
Hawk75's Avatar
Does anybody know of a HDD that will at least work then? Surely I can not be the only person that plus a HDD into their TV to watch movies?
Hawk
Hawk75 is offline
post #4 of 8 Old 07-05-2012, 04:30 PM
adone36's Avatar
Liked: 37
Have you prepared the drive? You have to create a partition and format it. With 3 TB your pc cannot see a 3tb partition unless you use the software that comes with the drive to create a GPT partition (std pc partition is MBR)
Tony
adone36 is offline
post #5 of 8 Old 07-05-2012, 07:27 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
The 3tb drives have a sector size of 4kb the tv may only recognize 512b sectors. I think you will have to use a 2tb or smaller drive that use the older 512b sector format.. After that it's a crapshoot as to which one will work.
There's a samsung forum at cnet and they are aware of this as Segate forums, may be some help there.
whipit is offline
post #6 of 8 Old 07-05-2012, 09:09 PM - Thread Starter
Hawk75's Avatar
My pc formatted it just fine before I used it, I have a smaller one that is just USB powered but it disconnects about 5 minutes plugging it up. I don't know whats going on but it sucks that the only reason I bought it was so that I could hook it up to my tv.
Hawk
Hawk75 is offline
post #7 of 8 Old 07-06-2012, 04:56 AM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
Probably not enough power in the usb port to keep it powered up properly. I have a segate 2tb drive similar to yours and have it hooked up to my PC and just stream content through dlna over wifi which works fine for the most part.
whipit is offline
post #8 of 8 Old 07-06-2012, 11:02 AM - Thread Starter
Hawk75's Avatar
My TV does not have Wifi, or else I would, I'm thinking about adding in a 5v power boaster into the USB cable, to see if it will work. I've got an OLD 80 GB that seemed to work fine, so I might just get an IDE 1TB drive and put in it.
Hawk
Hawk75 is offline
Samsung Pn51d490 51 Inch 3d 600hz Plasma Hdtv 3d Kit , Samsung Pn51d490 51 Inch 720p 600hz 3d Plasma Hdtv Black
