Best LG PA4500 settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-16-2012, 02:33 AM - Thread Starter
lob99's Avatar
Hi, i've bought a Lg pa4500 and i need help to get the best settings. I'm not an expert in tv, so if anyone has this plasma(or is an expert) and can help me to calibrate it or tell me which is his calibration, i would appreciate. If anyone has lg PM4700 i think the calibration could be good too for my plasma.
Well ,thanks a lot for the help!
lob99 is offline
post #2 of 15 Old 07-17-2012, 08:47 AM - Thread Starter
lob99's Avatar
Hi, anyone can help me??
Thanks a lot
lob99 is offline
post #3 of 15 Old 07-17-2012, 10:34 AM
Jepay123's Avatar
+1 on this thread.
Jepay123 is offline
post #4 of 15 Old 07-24-2012, 03:18 AM
stams83's Avatar
Hi, i'm new to this forum and this is my first post..
I used some settings i found from the 50/60PA6500 thread and with the help of AVIA i came up with these simple settings :
Aspect Ratio: 16:9
Energy Saving: Off
Picture Mode: Expert 1
Contrast: 87
Brightness:49
H. Sharp: 10
V. Sharp: 10
Color: 42
Tint: 0
Expert control
Dynamic Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Color Gamut: Wide
Edge Enhancement: Off
Color Temp: Medium
Method: 2 Point
Pattern: Outer
Points: High
Red: 14
Green: -12
Blue: -10
Hope i helped you wink.gif Greetings from Greece
lob99 likes this.
stams83 is offline
post #5 of 15 Old 07-25-2012, 02:29 AM - Thread Starter
lob99's Avatar
Thanks Stams83. I´ll prove your configuration!!! One more question, can you check which is the firm you have in your lg?
Thanks a lot!
lob99 is offline
post #6 of 15 Old 07-26-2012, 01:29 AM
stams83's Avatar
My firmware is 03.25.12 which i updated from the lg official site.
lob99 likes this.
stams83 is offline
post #7 of 15 Old 08-02-2012, 02:49 PM
wallydog's Avatar
I bought one Monday , I have found good results for OTA and HDMI with Roku using the following settings .
TV
Contrast 80
Brightness 55
H sharpness 8
V sharpness 10
Color 40
Tint 0
Expert control
Color temp Medium
Method 2 points
Points low
Red -11
Green-14
Blue -12
Luminance 15
Roku
Contrast 78
Brightness 65
H sharpness 15
V sharpness 10
Color 40
Tint
The same changes in Expert control as the TV .
Also I leave the Energy saving off
the other Expert settings I left stock .
I found these settings more to my taste than the ones listed on this Forum .
wallydog is offline
post #8 of 15 Old 08-03-2012, 01:20 PM
wallijonn's Avatar
No "Wizard II" in that set?
wallijonn is offline
post #9 of 15 Old 08-03-2012, 03:24 PM
wallydog's Avatar
Yes there is Wizard ll , I found it pushed red . I corected it with Expert settings .
I used the Wizard as a base line .
wallydog is offline
post #10 of 15 Old 09-24-2012, 04:40 AM
stams83's Avatar
hey guys, cnet just posted full calibration settings for 42PA4500
check them
Picture menu:
Energy Saving: Off
Picture Mode: Expert [1 or 2]
Contrast: 90
Brightness: 54
Sharpness: 8
Color: 50
Tint: 0
--Expert control menu--
Gamma: High
Black level: Low
Film Mode: Off [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
Expert Pattern: Off [grayed out]
Color Filter:: Off
Color Temperature: Warm
Method: 2-points
Pattern: Outer
Points: [High]
Red: -4
Green: 1
Blue: 6
Points: [Low]
Red: 4
Green: 4
Blue: 11
Method: 20-point IRE
0: [3,2,-7]
5 [0,-7,0]
10 [0,2,-5]
15 [2,5,-7]
20 [1,-3,-1]
25 [1,3,-6]
30 [0,0,-5]
35 [8,0,0]
40 [14,1,0]
45 [4,3,-3]
50 [0,0,0]
55 [0,0,-2]
60 [0,0,0]
65 [-8,0,-1]
70 [0,0,0]
75 [-2,4,0]
80 [0,5,5]
85 [-5,2,2]
90 [0,0,2]
95 [-6,1,0]
100 [-1,0,-13]
--Color management System submenu--
Red: [Saturation -5. Tint -29, Luminance 0]
Green: [Saturation -5. Tint 0, Luminance 0]
Blue: [Saturation -2. Tint -2, Luminance -9]
Cyan: [Saturation -3. Tint 2, Luminance 0]
Magenta: [Saturation 0. Tint 0, Luminance -2]
Yellow: [Saturation -10. Tint -27, Luminance 3]
stams83 is offline
post #11 of 15 Old 09-24-2012, 08:39 AM
wallydog's Avatar
stams83
The 2 point and 20 point settings did improve my gray scale .For the 2 pt low red I used 4 , 40 was way off .
But I like gamma at medium and color temp at medium .
I have also lowered contrast to 83 .
And with this grayscale I have a lower color settings 38 to 40 instead of the 50 posted .
I am using this with OTA broadcast .
wallydog is offline
post #12 of 15 Old 09-24-2012, 03:06 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
My 42pa 4500 looks really good with basically everything Except real bright screens.It looks washed out brightwhtes.Even turning down the contrast doesn't get rid of it. can't figure out how to get rid of it so I'm returning it.If it wasn't for that this tv would be steal at $400.
Vic12345 is offline
post #13 of 15 Old 11-03-2012, 05:30 AM
stams83's Avatar
Well guys after not liking the settings from cnet (the grayscale was a mess), i ended up to these settings.
Aspect Ratio: 16:9
Energy Saving: Off
Picture Mode: standard
Contrast: 88
Brightness:54
Sharpness:8
Color: 46
Tint: 0
colour temperature : w18
--advanced control menu--
Gamma: High
Black level: Low
Edge Enhancer: Off
Still the whites are on the blue side, but it gives an appropriate grayscale.
if anyone has the 20point grayscale calibration please post.
stams83 is offline
post #14 of 15 Old 11-06-2014, 06:20 AM
Liked: 0
this is been really old post, can anyone plz provide working settings? many thanks
sdhameshia is offline
post #15 of 15 Old 11-08-2014, 06:47 AM
wallydog's Avatar
Use the settings in this thread as a guide , being an old thread is not an issue if you have this model .
Sent from my TF300T using Tapatalk
wallydog is offline
