Shocked at Panasonic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-26-2012, 10:34 AM - Thread Starter
jiwright's Avatar
Well a long time fan of Panasonic Plasmas here, in fact I am on my third the TCP55VT30. Loved every aspect of it until I tried to play my PAL disks. After a long time twice with customer service I was told that these models as well as future models cannot accept a PAL signal. I have been watching PAL movies for more than 10 years on my Plasma TVs and simply cannot believe this, it is absolutely ridiculous . Every TV I know can accept a PAL signal, what is Panasonic thinking? Anyone know of any kind of work around?
Jeff
jiwright is offline
post #2 of 4 Old 07-26-2012, 11:56 AM
drfreeman60's Avatar
Liked: 52
If every TV you have owned would play PAL signals, I would say you have been quite lucky.
I have owned digita TV's since the late 90's (CRT's) as well as LCD's and Plasma since the early part of the previous decade and have never had a digital set with the ability to decode a PAL signal. None of the Blu-Ray or DVD players that I have owned had the ability to playback PAL.
David
David Freeman
drfreeman60 is offline
post #3 of 4 Old 07-26-2012, 12:09 PM
slb
slb's Avatar
One option would be to invest in a video processor such as the DVDO Edge, which can convert and upscale a PAL signal to 1080p/60. This would make things somewhat future proof if/when you change displays.
slb is offline
post #4 of 4 Old 07-26-2012, 12:33 PM - Thread Starter
jiwright's Avatar
Thanks for the suggestion! I have a large PAL library that I have collected over the years, and am still building . I will look into the edge,
Thanks again.
jiwright is offline
