Did a HDMI calibration in the service menu - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-28-2012, 12:37 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
I did the HDMI calibration and now my brightness level is maxed out at 100 and i need to put gamma on +3 to see all the levels on avs hd 709,and my contrast is at 72,arent brightness level at 100 too high?i used this site too do the calibration.have i done something wrong?
http://www.avforums.com/forums/16077276-post331.html
LG B6 55 inch-Panasonic TX-P55VT60Y-Klipsch RF-62 Mk1-Onkyo TX-NR616-Samsung UBD-K8500-Sony BDP-S6500-Pioneer BDP-120-Xbox 360 250GB-X Box One 500GB
shield1280 is online now
post #2 of 13 Old 07-28-2012, 12:39 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
But white looks realy white now
post #3 of 13 Old 07-28-2012, 04:11 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Yes, you must have done something wrong. A few questions:
1) What model Samsung do you have? (I assume it is a Samsung.)
2) Why did you feel it was necessary to perform Janos' ADC calibration?
3) What were your ADC Result (2nd_R_L, 2nd_G_L, 2nd_B_L, 2nd_R_H. 2nd_G_H, 2nd_B_H) and WB (Brightness, Contrast, Offset and Gain) values before performing the calibration?
4) What are your ADC Result and WB values after performing the calibration?
Larry
LarryInRI is offline
post #4 of 13 Old 07-28-2012, 06:17 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
1)Samsung ps51d535
2)Becaus i wasent happy with my pic quality,and when i did it it was much better.
3)2nd _R_L 134,2nd_G _L134,2nd_B_L 134,2nd_R_H49,2nd_G_H49,2nd_B_H49.WB unchanged. Contrast 90,brightness 58.the rest at deafults.
4)ADC Result 2nd _R_L75,2nd_G_L75,2nd_B_L75,2nd_R_H124,2nd_G_H124,2nd_B_H124.WB values unchanged.
After my contrast was set at 80 and brightness too 58 with avshd 709.i had too chang the hdmi black from low too normal,then the brightness was set right.
post #5 of 13 Old 07-28-2012, 06:31 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
It looks like you used the wrong pattern. Manually try reversing the numbers -- make the L values124 and the H values 75.
AND read this thread: http://www.avsforum.com/t/777497/samsung-calibration-failure
Larry
post #6 of 13 Old 07-28-2012, 06:45 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
Larry
After i change the L values to 124 and H values to 75,i can turn on the hdmi black low,then my contrast was set to 85 and brightness to 67.
post #7 of 13 Old 07-28-2012, 08:04 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Shield,
Read this post by zoyd and try his patterns.
http://www.avsforum.com/t/1333561/samsung-d7000-d8000-settings-calibration-thread/2190#post_21627792
EDIT: What type of source are you using that requires the black level to be set to Low? The only one that I'm aware of is the Directv HR24-500 receiver.
Larry
post #8 of 13 Old 07-29-2012, 05:20 AM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
Shield,
Larry
After what i hav read online,people say that hdmi black should be set to low,and a few people says normal.i have all connected to my onkyo 608 receiver.
post #9 of 13 Old 07-29-2012, 06:01 AM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
If i set the hdmi black to low the black get grey black when i set it to normal then i get better blacks.and from what i understand low is 16- 235 and normal is 0-255
post #10 of 13 Old 07-29-2012, 10:12 AM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
I need to put gamma at +2 on hdmi black low then i get a brightness at 59,if i dont turn up gamma i get brightness at 74 on hdmi black low,if i use normal then i then i get brightness at 36 whic i think look great better blacks offcours,but i doubt it could be right anyway and the same on low brightness at 74,i think mayby bright at 59 and gamma could be right,i done this with avshd 709.my contrast on low will be 83,on normal its 90.
post #11 of 13 Old 07-29-2012, 02:39 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
You received your answer over at AVforums.com. The black level should be set at Normal.
I suggest that you manually put your ADC values back to their factory settings and leave them there.
Larry
post #12 of 13 Old 07-29-2012, 03:12 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
Larry
Ok i will do that,thx for the help:)
post #13 of 13 Old 07-29-2012, 03:40 PM - Thread Starter
shield1280's Avatar
Quoted: 388 Post(s)
Liked: 79
I put the ADC values back and did a new round with avshd,contrast 95 and the brightness is now at 32,can that be right?then i set hdmi black to normal.
