Would you buy a 50 in GT 50 or a 55 ST 50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-30-2012, 11:59 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
Is there that big a difference?
RicFlair is offline
post #2 of 13 Old 07-31-2012, 08:52 AM
Tazishere's Avatar
Two different needs are being addressed. Size is usually more important. Even up close, a 55" screen gives a larger representation of the source material. I don't think it's possible to compare size to features.
Tazishere is offline
post #3 of 13 Old 07-31-2012, 10:17 AM
Frankie1588's Avatar
I would definitely get a 55" ST50. That's a no brainer to me!
Frankie1588 is offline
post #4 of 13 Old 07-31-2012, 11:00 AM
PlasmaPZ80U's Avatar
Quoted: 2193 Post(s)
Liked: 659
since both sets have great PQ and are highly recommended, go for the bigger one
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #5 of 13 Old 07-31-2012, 01:49 PM
BriscoCountyJr's Avatar
Quoted: 34 Post(s)
Liked: 43
Another vote for the 55ST50 unless you value the style of the GT more than the extra size of the same price ST model.
BriscoCountyJr is offline
post #6 of 13 Old 07-31-2012, 01:51 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 519 Post(s)
Liked: 775
No.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 13 Old 07-31-2012, 02:39 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
Go with the 55ST50. I've had one since June and it is one fine display and, for me, zero problems. And they are $250 off at Best Buy (should check to be sure, price drop began 7/22).
subavision212 is offline
post #8 of 13 Old 07-31-2012, 02:45 PM
weedeater's Avatar
What are you looking for? Obviously, if size is your deciding factor then go with the 55.
The GT gives you a different look (style) and dual processor (faster apps). And one more each of HDMI and USB. And some more predefined modes.
But as to PQ, you would probably not be able to tell them apart.
weedeater is offline
post #9 of 13 Old 07-31-2012, 03:23 PM
oztech's Avatar
Liked: 101
If you don't need the 4HDMI inputs and 3 will suffice get the ST no substitute for cubic inches except more of them.
oztech is offline
post #10 of 13 Old 07-31-2012, 11:24 PM
fallengt's Avatar
The ST50 doesn't have 10-points greyscales & full CMS controls. Is it correct ?
If it was true I would go for the VT50
fallengt is offline
post #11 of 13 Old 08-01-2012, 07:09 AM
oztech's Avatar
Liked: 101
From what has been said about the picture from all the sets so far go with the ST if you want a difference most will see and thats probably side by side get a VT.
oztech is offline
post #12 of 13 Old 08-01-2012, 08:17 AM
Audiodork's Avatar
Liked: 37
Hello,
While I am a 60GT50 owner, I too would go with the 55ST50 if having to choose between a 50 inch and a 55 inch Panel. I really think you will be quite happy with the 55ST50 with the major difference being cosmetic between the 2.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
post #13 of 13 Old 08-01-2012, 08:25 AM
wlcohen's Avatar
I always for the larger set when pictures are similar
wlcohen is offline
