Orbiter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-31-2012, 12:50 PM - Thread Starter
swampfoxpro's Avatar
Hi, my 65st50 is in the mail. Arriving any day now.
I was reading the threads on IR.
Does anyone use the orbiter? (i think its called that)
Isn't this used to prevent IR?.
swampfoxpro is offline
post #2 of 3 Old 07-31-2012, 02:51 PM
BriscoCountyJr's Avatar
Quoted: 33 Post(s)
Liked: 42
The picture orbiter just slowly shifts the picture around a few pixels, so it might smear any IR image from a bright logo a bit, not much else it can do.
Probably better to just use the screen wipe feature regularly (15min every few days or so as needed)
BriscoCountyJr is offline
post #3 of 3 Old 07-31-2012, 04:09 PM
sonyfan's Avatar
With Samsung pixel orbiter you can't enable it unless you use 16:9 or 'wide fit' mode,
which applies some overscan to give the pixel orbiter enough room to shift the image around a bit.
Cropping the image is a no no.
sonyfan is offline
