ST50 Mapping 1:1 (1080p) to pc and then problem with tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-01-2012, 04:06 AM - Thread Starter
djsolidsnake86's Avatar
Hi to all, i bought a 50st50, and for map it with my graphic card to 1080p 1:1 in hdmi i must disable from panasonic settings the overscan 16:9 and the pixel orbiter
the problem is that when i switch to see digital tv, i must re-enable those two setting because in digital tv there are black borders without overscan 16:9
my question is: is not possible create different profiles for hdmi and for digital tv for overscan 16:9 and pixel orbiter? or i must re-set all this 2 setting everytime?
i wrote to panasonic for have a answer, maybe a firmware could add this important feauture, however is strange that now seem impossible to make full profiles..
djsolidsnake86 is offline
post #2 of 6 Old 08-01-2012, 05:08 PM - Thread Starter
no one has this problem?
post #3 of 6 Old 08-01-2012, 10:55 PM
SleepyBum's Avatar
I'm interested in this TV and using it with a PC and I have a question I think you can answer.
Will this TV accept other PC resolutions via HDMI and display them properly? Can you send a 640x480, 800x600, 1024x768 resolution signal from the PC to the TV and have it display properly? Do you have JUST/FULL mode controls to stretch 4:3 to 16:9. Also do these res have that overscan problem you stated before?
Also are you sending the TV a 60Hz signal at 1920x1080? Do you have some kind of control center software for your video card (Catalyst for ATI, nVidia control panel)?
SleepyBum is offline
post #4 of 6 Old 08-03-2012, 03:35 AM - Thread Starter
yes, via hdmi it support all resolution and you can map it 1:1 but you must disable overscan 16:9 and pixel orbiter in the panasonic settings
post #5 of 6 Old 08-03-2012, 10:30 AM
Michael2000's Avatar
Liked: 27
What TV source are you using (Directv, Dish, Comcast, etc.)? I have heard differing opinions about whether overscan is needed with TV.
Michael
Michael2000 is offline
post #6 of 6 Old 08-03-2012, 10:38 AM - Thread Starter
dvb-t italy
