Help! Line running down the middle of LG plasma - AVS Forum | Home Theater Discussions And Reviews
Old 08-14-2012, 09:55 PM - Thread Starter
bajaed's Avatar
Just noticed a perfectly straight line running down the middle of my LG 60PS60. Any ideas on what the problem is and if it can be repaired?
bajaed is offline
Old 08-14-2012, 09:58 PM - Thread Starter
bajaed's Avatar
BTW, it does this on all active inputs.
bajaed is offline
Old 08-16-2012, 05:29 AM
EG3
EG3's Avatar
It sounds like a defective plasma panel. It can be fixed however, it would require a new screen which is not cost effective unless it is under warranty. If you have no warranty left, it is time for a new TV.
EG3 is offline
Old 08-23-2012, 08:41 AM - Thread Starter
bajaed's Avatar
Not sure what is going on but the line went away after a couple of days. Is it still likely the panel is bad and will eventually die?
bajaed is offline
Old 08-23-2012, 08:50 AM
EG3
EG3's Avatar
If the line was only a pixel or two wide, then yes, it is a problem with the panel.
Glad to hear that it went away.
EG3 is offline
Old 08-23-2012, 09:40 AM - Thread Starter
bajaed's Avatar
Yes it was very thin. Like someone put a perfectly straight thin chalk line right down the middle.
bajaed is offline
