ST50 v.s the UT50 What is the $300 differences? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-15-2012, 11:06 AM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
Where is the ST superior at that cost?
RicFlair is offline
post #2 of 13 Old 08-15-2012, 11:13 AM
chunon's Avatar
Quoted: 2494 Post(s)
Liked: 2231
This question has been asked a thousand times here, the search feature is your friend. But I'll answer basically AR filter, custom controls and an extra input. If your room is light controlled it is probably a wash.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #3 of 13 Old 08-15-2012, 12:03 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
really? so the blacks on the UT are that of the ST?
RicFlair is offline
post #4 of 13 Old 08-15-2012, 12:08 PM
yaomizzle's Avatar
Liked: 27
The St uses the same panel they used on the VT last year (infinite black panel pro I believe)
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #5 of 13 Old 08-15-2012, 12:39 PM
chunon's Avatar
Liked: 2231
Pretty darn close from what I have read, the advantage for the ST would be in a brighter environment, the black level holds up much better. The entire line from U to VT has outstanding blacks this year.
Sony 75XBR940E
chunon is offline
post #6 of 13 Old 08-15-2012, 12:40 PM
chunon's Avatar
Liked: 2231
Thats incorrect all the panels are new this year and designed from the ground up in fact the ST blacks exceed the VT blacks from last year.
Sony 75XBR940E
chunon is offline
post #7 of 13 Old 08-15-2012, 12:55 PM
rahzel's Avatar
Liked: 148
You're confusing the filter with the panel. It uses the same filter as the VT30, but the panel is new as chunon said. The UT has no filter, the ST/GT have the infinite black pro filter and the VT has the infinite black ultra filter. All of the panels are new and have the increased brightness and better black levels (among other things).
You can calibrate grayscale on the UT50, but you have to do it in the service menu. The ST50 has them in the user menu, plus it has a gamma slider which is really useful.
rahzel is offline
post #8 of 13 Old 08-15-2012, 02:56 PM
BriscoCountyJr's Avatar
Quoted: 36 Post(s)
Liked: 48
Other differences that the ST50 has that the UT50 lacks:
A third HDMI input, rotating pedestal stand (for the 50" model), a simple web browser app in the Viera Connect internet apps.
BriscoCountyJr is offline
post #9 of 13 Old 08-15-2012, 02:59 PM
chunon's Avatar
Liked: 2231
Sony 75XBR940E
chunon is offline
post #10 of 13 Old 08-15-2012, 06:19 PM - Thread Starter
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 71
The 2 HDMII hurts the UT50
Are there HDMI extenders made?
RicFlair is offline
post #11 of 13 Old 08-15-2012, 06:43 PM
andy sullivan's Avatar
Quoted: 773 Post(s)
Liked: 406
One other difference would be if you want a 65". ST only.
andy sullivan is offline
post #12 of 13 Old 08-17-2012, 12:55 AM
Quoted: 36 Post(s)
Liked: 48
Do you mean switchers? Yes there are many models of HDMI switchers such as 4 in and 1 out for example.
Monoprice has a good 4 port HDMI switcher that also can output separately the digital audio to optical or coax to an older non-HDMI receiver.
post #13 of 13 Old 08-17-2012, 10:34 AM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
regarding extra HDMI inputs if you have an AVR you really only need 1-2 HDMI inputs on the TV itself... for example I have a Sony HT-SS380 and it has three HDMI inputs on the receiver/amp and a single HDMI output to connect to a HDMI input on the TV
I can then use three sources via the receiver/amp and use the remaining HDMI inputs on the TV for other devices... and if you have a AVR with 4-5 HDMI inputs, you really only need a single HDMI input on the TV.
the only issue with this setup would be if you need separate settings per source device (but that is rarely the case on well made HDMI equipped source devices)
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
