Breaking in and calborating Panasonic 55st50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-15-2012, 04:07 PM - Thread Starter
Viperlx's Avatar
Hi All,
So I just got my tv and it's plugged in now. I am anal about my picture quality and I would like to get this right the first time. I know many will say get a professional to calibrate my tv but I want to see how far I can get myself. For the for 150+hrs on the TV, should I run a breakin DVD? Is so, where can I find one? Also, can anyone recommend a good calibration cd? I noticed AVS FD 709 and might give it a try.
Viperlx is offline
post #2 of 12 Old 08-15-2012, 04:25 PM
chunon's Avatar
Quoted: 2039 Post(s)
Liked: 1787
Originally Posted by Viperlx View Post
Hi All,
AVS709 is good disk and can be downloaded for free, Disney WOW gets high marks also but is not free. I personally don't believe in the break in stuff, just keep your settings conservative watch varied content the first 100 to 150 hours you should be fine. Your set will improve alot in that time. After about 200 hours you should be able to dial in some pretty good settings. Good luck
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 12 Old 08-15-2012, 05:03 PM
oztech's Avatar
Liked: 101
I agree I adjusted using S&M disc and D-Nice settings without slides and watched TV thats what I bought it for and I still think it has the best picture
that I have ever owned .
i
oztech is offline
post #4 of 12 Old 08-16-2012, 07:04 AM - Thread Starter
Viperlx's Avatar
thanks guys. I am going to run a breakin video over the weekend since I will be out of town. It won't hurt to accelerate the process a bit.
Viperlx is offline
post #5 of 12 Old 08-16-2012, 07:13 AM
RicFlair's Avatar
Quoted: 488 Post(s)
Liked: 70
i
So you didn't do break in ?
RicFlair is offline
post #6 of 12 Old 08-16-2012, 07:21 AM
oztech's Avatar
Liked: 101
That is correct I opened up the carton set up the TV in custom mode with D-Nice's no slide settings and put in a Spears & Munsil set up disc and tweaked it a little and watched TV .
Stayed up the next night and did color bar settings for OTA and Uverse and have been watching an outstanding picture ever since with no issues.
I should add as with all my electronics I let them acclimate to room temperature and warm up which is usually an hour before final tweaking.
oztech is offline
post #7 of 12 Old 08-16-2012, 07:30 AM
chunon's Avatar
Liked: 1787
As OzTech states it is not required, I have never done it on any of the plasmas I have owned. Now if you are trying to use Dnices post breakin settings then yes you should age the panel with his slides to get the best results.
65C6 OLED
post #8 of 12 Old 08-16-2012, 04:08 PM - Thread Starter
Viperlx's Avatar
when you say "age". do you mean the first 100hrs of breakin or 1 hour warmup?
Viperlx is offline
post #9 of 12 Old 08-16-2012, 04:16 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
He meant 100 or so hours:)
whipit is offline
post #10 of 12 Old 08-16-2012, 04:44 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Hi All,
you can use the AVSHD709 disc right away to do a basic calibration, just be sure to recheck everything after the first 100-150 hours or so
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #11 of 12 Old 08-16-2012, 04:48 PM
Liked: 562
I am not one to believe in copying settings (and most calibrators pro or not don't recommend it either), so I don't think using D-Nice's settings is a good idea. I'd either do a simple disc only calibration myself, hire a pro, or get a meter/software and do a full calibration myself. If fact, I do my own calibrations with a C6 colorimeter and CalMAN software and will be getting a used i1Pro spectro to profile it with soon.
post #12 of 12 Old 08-16-2012, 07:32 PM
oztech's Avatar
Liked: 101
He has two sets of settings one using slides with breakin and the other set as is and run it ,as for tweaking I personally like the set to be on an hour whether it be Plasma,LCD or CRT.
oztech is offline
Panasonic Viera Tc P55st50 55 Inch Plasma Tv
