Best picture settings for a Samsung PN43E450 (Gaming) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-17-2012, 09:58 PM - Thread Starter
Eyo1's Avatar
So, i have been using this tv for a while I only really play xbox on it but I cant seem to find the right picture settings to make it look really good. I have tried dynamic but it has weird pixalted edges around letters and the colors arnt great, and I have tried the other ones to. So if someone could tell me what picture mode and settings are the best for gaming I would be very happy smile.gif
EDIT- How do people get there cell light up to 20? Mine only goes to 10 I would really love it to go that high so if you know why please tell me that on your post.
Eyo1 is offline
post #2 of 7 Old 08-18-2012, 07:20 PM - Thread Starter
Eyo1's Avatar
Please reply I need to know soon!
Eyo1 is offline
post #3 of 7 Old 08-20-2012, 02:26 PM
tommyv2's Avatar
The Xbox 360 will never look sharp because the GUI isn't 1080p - a few of the games are, but only a few. You got a PS3 to test with? The OS on that is 1080p and is used by many as a benchmark for sharpness and clarity. The games are a whole other story, of course.
=Tommy v2=
tommyv2 is offline
post #4 of 7 Old 08-20-2012, 02:39 PM
yaomizzle's Avatar
Liked: 26
All cell light does is brighten the image up which is rarely a good thing for people that want accurate good looking colors...having it calibrated will get you the best avaibile picture
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #5 of 7 Old 08-20-2012, 03:15 PM
sonyfan's Avatar
It's better to keep it at 20 and adjust Brightness and Contrast.
There was a post from a tech who works for Samsung
stating that the Cell Light is bogus and should be at max = 20 because it's a carry over
from their LCD/LED sets menu, and Samsung did not want to change the menu for the plasmas.
He also said the Sharpness is bogus and should be turned off = 0.
I was skeptical but after a few weeks of dialing it down from 20 to 10 then 5 to 0
I understand he was right that it adds artifacts.
Look close at the screen at flat edges at an angle then adjust Sharpness up and down.
You will see it adds adds contrast = ringing (stair steps) to the edges.
0 Sharpness does take a little getting used to so give it time.
sonyfan is offline
post #6 of 7 Old 08-20-2012, 07:47 PM - Thread Starter
Eyo1's Avatar
Thanks for all of your good responses:D ,Could someone give me some good picture settings to work with? And could someone tell me whats a better picture mode for gaming Standard, dynamic or movie for gaming.
EDIT- My cell light does not go up to 20 the max is 10 frown.gif could someone tell me why?
Eyo1 is offline
post #7 of 7 Old 08-20-2012, 09:55 PM
sonyfan's Avatar
E450.
I only use Movie Mode.
Shadow detail is finally looking normal.
Mode - Movie
Cell Light 20
Sharpness 0
Size - Screen Fit
Brightness 50 daytime / 40 for evening and 35 to 30 for a dark room
Contrast 100 daytime / 97 for evening and 95 to 90 for a dark room
Color 51
R/G Tint 50/50
Color Space - Native
Gamma -1 for night (0 for daytime
Dynamic Contrast - off
Black Tone - Darkest
Flesh Tone - 0
Color Tone - Warm1
Digital Noise Filter - Off
sonyfan is offline
Samsung Pn43e450 43 Inch Class Plasma 450 Series Hdtv
