panasonic 50pz700u - screen issue...what is it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-18-2012, 05:06 AM - Thread Starter
ajs800's Avatar
My hardly used panasonic 50pz700u started showing some strange artifacts recently and I don't have a clue what it might be. It appears to be similar to a loose input connection, but i've attempted to connect everything direct using different inputs with no change. I am trying to determine if it will be worth fixing or is it a major repair and not worth it? Below are some pics of what I'm experiencing.... basically light vertical lines with dark images and more of a silhouette of an image along with the vertical lines.
ajs800 is offline
post #2 of 5 Old 08-20-2012, 09:54 AM - Thread Starter
ajs800's Avatar
I know this Plasma is old by today's standards, but does anyone have any idea what the issue is and/or know of a place to research it before calling out a tech to evaluate? Thanks;)
ajs800 is offline
post #3 of 5 Old 08-21-2012, 07:27 AM
tomwil's Avatar
Liked: 26
You may want to look at these Panasonic documents, which may help narrow your problem.
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #4 of 5 Old 08-21-2012, 12:52 PM - Thread Starter
ajs800's Avatar
I'll check it out. THanks!
ajs800 is offline
post #5 of 5 Old 08-22-2012, 11:16 AM - Thread Starter
ajs800's Avatar
It doesn't seem that it's the actual panel. However, being that the lines do not appear when menu screens are present and when the channel is static (no input) makes me think it's the main/processing board or the input board...is there an easy way to confirm this?
ajs800 is offline
