replacing 46inch hx800.....gt50 or e8000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-22-2012, 08:19 AM - Thread Starter
NathanRix's Avatar
so my hx800 led is more than likely getting replaced rather than fixed, so I'm stuck on 3 TVs. Either I go with the newer hx850 led in the same size or I go plasma, and get either the gt50 or e8000. The reason I chose those is based on size, I can get away with a 50 or 51inch but anything bigger and my 52inch speakers will block them from certain angles which is why the vt50 is not on my list since the smallest is 55, unless I rework my speakers somehow that one won't work, all comments are appreciated
NathanRix is offline
post #2 of 4 Old 08-22-2012, 08:29 AM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Unless you're not happy with LCD technology on your Sony then go for a Plasma, otherwise just get the new HX850.
HLdan is offline
post #3 of 4 Old 08-22-2012, 08:43 PM - Thread Starter
NathanRix's Avatar
So which plasma then
post #4 of 4 Old 08-22-2012, 08:46 PM - Thread Starter
NathanRix's Avatar
