Apple TV Screen Saver as Break-in for Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-27-2012, 07:20 AM - Thread Starter
rzanwu36's Avatar
The Apple TV has a screen saver that consists of different slides scrolling upwards on the screen. They don't cover the whole screen and the screen also "flips" horizontally every so often. The Apple TV is only 720p though and I would be breaking in the Panasonic 60ST50. Does that resolution matter for break-in?
Or would I be better suited with something else?
rzanwu36 is offline
post #2 of 3 Old 08-27-2012, 10:06 AM
grambo's Avatar
When I get my UT50, I'm just planning on looping 16:9 content for 100 hours or so with contrast turned down a bit. I'll probably use BBC Planet Earth or Life episodes as they have a mix of colour and are not dominated by dark scenes (so the panel should be hit relatively evenly).
grambo is offline
post #3 of 3 Old 08-28-2012, 07:40 AM
tommyv2's Avatar
You can't beat the slides. Using any other connected device puts you at the risk of them freezing, shutting off, etc. Slides on a flash drive/SD card are your best bet and you'll know you're getting the best possible break-in with pretty much zero risk.
=Tommy v2=
tommyv2 is offline
Plasma Hdtv , Panasonic Viera Tc P60ut50 Plasma Tv , Apple Tv Md199ll A
