55GT50 or 60GT50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-27-2012, 07:30 PM - Thread Starter
AirBoyzT's Avatar
So I am planning on turning the loft of my cape cod into a home theater area. Right now I am planning on getting some Klipsch Tower Speakers with a center channel and subwoofer.
My delimma is where my sectional currently is placed, I would be sitting about 13 feet from the television. I can move the couch closer and get about 9 feet from where the television is going to be. I guess now I just don't know if 55 inch is going to be too small and should I go with the 60 inch. I believe I am going to go with the GT50 and do plan on getting it calibrated. Also should I move my couch closer?
AirBoyzT is offline
post #2 of 13 Old 08-27-2012, 09:03 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
55" is way too small. 65" would be best but if that's not in your budget I highly recommend 60".
I sit about 8-9 ft from my 60GT50 and I think that a 65" would look even better (they shrink). I did have the 55VT50 and it was missing the "awe" that a larger screen provides.
sheshechic is offline
post #3 of 13 Old 08-27-2012, 09:33 PM - Thread Starter
AirBoyzT's Avatar
yea afraid the 65 is a little outside my budget.....I'm pushing it with the 60 inch GT....Guess I will go 60 inch and hopefully wont be dissapointed.
AirBoyzT is offline
post #4 of 13 Old 08-27-2012, 09:37 PM - Thread Starter
AirBoyzT's Avatar
I mean I could afford a Sharp 70 inch LED lol....but I'm pretty sure that would be a downgrade
AirBoyzT is offline
post #5 of 13 Old 08-27-2012, 11:09 PM
sheshechic's Avatar
Quoted: 114 Post(s)
Liked: 167
Right.
I don't think you'll be disappointed with the 60GT50. .
post #6 of 13 Old 08-28-2012, 07:03 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
Since you plan on getting the display calibrated is there any reason why you can't get an ST50 instead and go with the larger 65" screen size? Or do you need the few extra features that the GT50 provides bad enough to settle for a smaller screen size? Or did you plan to get your THX modes calibrated?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 13 Old 08-28-2012, 11:25 AM - Thread Starter
AirBoyzT's Avatar
I would go with the 60st50 but I have to go through best buy since I'm using a best buy credit card. I will check the price of the 65st50, but am sure it will be out of my price range.
AirBoyzT is offline
post #8 of 13 Old 08-28-2012, 11:50 AM
dominica's Avatar
Quoted: 128 Post(s)
Liked: 131
I am not sure what is the current prices are at Best Buy. Go to the store and they will match Amazons prices on the ST/GT for you and they have 36 months no interest for any TV over $899 if you use your best buy card. Just pay it way before the 36 months and keep within your budget. Good luck
dominica is offline
post #9 of 13 Old 08-28-2012, 09:18 PM - Thread Starter
AirBoyzT's Avatar
Ended up going with a 55st50....re-arranged room and it is a win/win because we have more space. Question, calibrating it will it make it brighter? I haven't set it up yet. Just wondering.
AirBoyzT is offline
post #10 of 13 Old 08-29-2012, 09:25 AM
Tazishere's Avatar
Here is a link to the ST calibration that I found:
http://www.bing.com/images/search?q=Panasonic+GT50+Calibration&view=detail&id=5EE71F79D21B5CAE82C547CF486A8810B16F099E&first=1
You can find other calibrations on this forum too.
cooln3ss likes this.
Tazishere is offline
post #11 of 13 Old 09-02-2012, 07:59 AM
Ejs71's Avatar
Quoted: 38 Post(s)
Just bought the 60GT50. Couldn't be happier.. I believe you can never get too big a TV, especially when it's plasma. I have a my 60" mounted over a fireplace, andgled down. I wish I could go 65" but the mantel is in the way. I even went "phantom center" so I didn't have to sacrifice any tv space for the center channel. I sit about 16' from the tv.
I'm using the THX setting, and it's phenominal for movies, but not sure about sports..
Ejs71 is offline
post #12 of 13 Old 10-08-2012, 11:04 PM
Jrunr's Avatar
Quoted: 75 Post(s)
Well, you have had some time... how are the sports? lol Have you watched any good HD football on this thing yet?
Jrunr is offline
post #13 of 13 Old 10-22-2012, 08:08 PM
size14d's Avatar
Quoted: 27 Post(s)
I don't think you can go too big. Love my 60" GT50.
size14d is offline
Panasonic Viera Tc P55gt50 55 Inch Plasma Tv , Panasonic Viera Tc P60gt50 60 Inch Plasma Tv , Plasma Hdtv , Sharp
