TC-P50UT50 Black levels - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-30-2012, 02:26 PM - Thread Starter
armenian01's Avatar
I'm purchasing a tc-p50ut50 from bestbuy next week, I would like to know the difference in black levels for the UT50 when compared to the panasonic g10 plasma, I was aware of the rising blacks issue on the 2010 panasonic plasmas. I know the UT50s blacks will be better than a G10s blacks with 500 hours in because of its rising blacks. Are the blacks on the UT50 better than the blacks of the G10 when the G10 was in its prime?
armenian01 is offline
post #2 of 4 Old 08-30-2012, 04:08 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Yes, the blacks are WAY better than even a new G10.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 4 Old 08-30-2012, 06:54 PM
homerging's Avatar
Quoted: 31 Post(s)
Wouldn't the P50ST50's black levels appear deeper than the P50UT50's as it has a better glare filter?
homerging is offline
post #4 of 4 Old 08-30-2012, 08:56 PM - Thread Starter
armenian01's Avatar
not according to PathofNeo, maybe a very bright room, dont think its worth the extra money so i'm going for the UT50
Panasonic Viera Tc P50ut50 50 Inch Plasma Tv
