Bias lighting for 64 inch Samsung Plasma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-01-2012, 08:08 AM - Thread Starter
ed3120's Avatar
ed3120 is offline
post #2 of 6 Old 09-01-2012, 02:48 PM
Dierkdr's Avatar
Liked: 54
We simply use a small - maybe 15" - supposedly "daylight" tube lamp behind our 60" set - and I actually have a couple of bent metal "reflectors" ovher that, partially to help direct the light & partially to REDUCE the amount of light that is visible.
Dierkdr is offline
post #3 of 6 Old 09-02-2012, 06:47 AM
leela222's Avatar
I have the LED strip kit from barlighting.com Mutliple colors and wireless remote. LOVE, LOVE LOVE it! I also have the LED disk kit for the tv cabinet.
leela222 is offline
post #4 of 6 Old 09-03-2012, 06:04 PM
Tazishere's Avatar
I use six undercounter soft-white flourescents that I got for <$15.00 each from Menards. I used 2" velcro "sticky-back" to attach them. I have them connected in series, and I use a foot-switch to turn it on and off. It works well.
Tazishere is offline
post #5 of 6 Old 09-03-2012, 07:30 PM
rahzel's Avatar
Liked: 148
Bias lighting should be as close to 6500K as possible, otherwise the light will affect the color of the set.
Ideal Lume is what most people use.
rahzel is offline
post #6 of 6 Old 09-09-2012, 10:57 AM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
'D65 Video Bias Lighting- Fundamental Theory And Practice'
http://www.avsforum.com/avs-vb/showthread.php?t=1162578
GeorgeAB is offline
