Text blurs every 60 seconds on Panny TC-P50U50 - AVS Forum | Home Theater Discussions And Reviews
Old 09-01-2012, 03:15 PM - Thread Starter
betelgeuse4721's Avatar
I just bought a 50 inch Panasonic plasma (TC-P50U50).
It works great and all, but whenever I connect my PC to it via HDMI, whatever text is on the screen (usually on some web page) blurs slightly, then focuses back to normal every 60 seconds exactly.
I tried this on my parent's 50 inch Pioneer and the problem disappears,
I called Panasonic and they have no idea.
When my Xbox is connected to it via the same HDMI and port, there is none of this.
Thoughts/ideas/suggestions?
-Brady
betelgeuse4721 is offline
Old 09-01-2012, 05:30 PM
fastl's Avatar
Quoted: 22 Post(s)
It sounds like there is scaling (interpolation) occuring on the TV, resulting in the blur. Unless your PC is outputting the native resolution of the TV display panel and the TV is capable of 1:1 pixel mapping, the PC is always going to look a little soft. The scaling engine of the Pioneer is probably better than the Panasonic. I've never been impressed with their scaling quality.
fastl is offline
Old 09-01-2012, 09:54 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Is there some kind of 'Pixel Orbiter' or other anti-burn-in app running inside the TV? A lot of Plasmas screw around with the picture like that to prevent IR.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 09-08-2012, 03:31 AM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 746 Post(s)
Liked: 660
Can you borrow a different computer and try it. This could possibly be a HDMI issue between the units.
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is offline
Old 09-08-2012, 07:59 AM
Super Moderator
DrDon's Avatar
Quoted: 872 Post(s)
Liked: 1732
First of all, you have to make your topic title more specific. On this forum, members routinely ignore generic "can someone help me" titles. The more info you can put in a title, the better.
It also helps to place your post in the proper section.
I've taken care of both for you.
-Doc
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
Old 09-08-2012, 12:33 PM
iBrad's Avatar
Yes, Pixel Orbiter is the cause of this blur effects!
iBrad is offline
Old 09-08-2012, 03:54 PM - Thread Starter
Excellent feedback guys, and thanks for editing my title.
On another forum, someone noticed that the instruction manual of my specific Panasonic TV mentioned that "HDMI is not optimized for PC use on this model."
This could explain the blurring, and it me be that pixel orbiting. At least I have an idea now!!!
Old 09-08-2012, 06:09 PM
Goo
Goo's Avatar
Just a random thought, but check to make sure your computer is outputting a progressive signal and not interlaced.
So if you check your display properties it should be set to 1920x1080p not 1080i.
Goo is offline
Panasonic Viera Tc P50u50 Plasma Tv
