Is oversaturated whites normal on plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 09-02-2012, 02:55 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
The blacks are dark black but the whites are oversaturated.I tried every adjustment but nothing seems to change it.Any ideas what this is?
Vic12345 is offline
post #2 of 19 Old 09-02-2012, 03:49 PM
oztech's Avatar
Liked: 101
How did you set it up ?
oztech is offline
post #3 of 19 Old 09-02-2012, 04:44 PM
PlasmaPZ80U's Avatar
Quoted: 2236 Post(s)
Liked: 685
lower contrast
also, whites and blacks don't have saturation, only colors do... so, I think you mean whites are too bright or gamma is too bright (near whites)
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #4 of 19 Old 09-02-2012, 04:52 PM
Seegs108's Avatar
Quoted: 4967 Post(s)
Liked: 2485
Yeah, you can't have oversaturated whites. You probably mean white crushing or clipping. Try playing around with your contrast and brightness settings.
Seegs108 is online now
post #5 of 19 Old 09-02-2012, 05:16 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
The only way that reduces it is turning contrast down lower than 50 which is a bit dark which kinda sucks.
Vic12345 is offline
post #6 of 19 Old 09-03-2012, 07:27 AM
Liked: 685
try adjusting gamma
post #7 of 19 Old 09-03-2012, 03:14 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Thanks but gamma adjustment does not help the overblown whites on this tv.ive also got a loss of detail in the darks(black crush)
Vic12345 is offline
post #8 of 19 Old 09-03-2012, 03:27 PM
Dierkdr's Avatar
Liked: 54
Try posting a request for help / advice under an owners thread for the Manufacturer / Model that you own.
Get a copy of the AVS HD709 disk, and view the short videos on calibrating / adjusting a HDTV.
Recall that there is not only a Preferred Sequence to follow (ie: First Adjust THIS, Then Adjust THAT...), but also some advice that you might have to go back & re-check the early settings, as they can be impacted by the later ones.
Viewing environment / preferences may also play a role, but have read a number of posts from owners who have stated that they felt Post-Calibration settings were a bit "dim," UNTIL they had time to grow accustomed to them.
Dierkdr is offline
post #9 of 19 Old 09-04-2012, 10:52 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
\_/
Vic12345 is offline
post #10 of 19 Old 09-17-2012, 03:04 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I have a lg 42pa4500.
The darkest blacks are very black but the whitest,of whites are quite over bright/saturated and can't really get rid of the white problem without turning the contrast down way too far.
Is this normal for a budget plasma?????
Vic12345 is offline
post #11 of 19 Old 09-17-2012, 03:23 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
did you change temp from cool to warm?
curious that the whites are too bright.
that sounds like an LCD.
must be the temp of the white.
Loving D65
CalWldLif is offline
post #12 of 19 Old 09-17-2012, 03:24 PM
wallydog's Avatar
No this is not normal .I have the same model .
Go into Settings > Options > Mode setting , make sure it is set to Home Use and not Store Demo .
Also under Settings > Picture it is not set to Vivid .
Hope I helped .
wallydog is offline
post #13 of 19 Old 09-17-2012, 05:57 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
It reminds me of how a CRT would look when the picture tube is gone(if you turn the contrast way up it would look oversaturated on brights and whites).Theres sometimes noticeable bright outlining the edge of -example baseball player football player too.im referring to the very brightest whites on the screen.
I've tried every contrast and brightness setting and the BRIGHTEST whites are always at least a little oversaturated.I don't remember this on the d630 or lk520,although maybe I just did not notice.
I just want to know if Plasmas have this tendency(this is the first plasma ive bought)I'm trying to decide whether to try another pa4500 or get my money back or am I nitpicking too much? It was$400 plus tax.
Vic12345 is offline
post #14 of 19 Old 09-17-2012, 06:42 PM
wallydog's Avatar
If you post a complete list of your settings someone may be able to help you online .
If you bought it locally ask to have someone come and take a look at it , before you take it back for another plasma of the same or different model .
And again no it is not normal for all plasmas low or high end to look that way .
If you are sure in your settings and dont like it send it back and get a LCD if you think you do not like the picture from a Plasma.
wallydog is offline
post #15 of 19 Old 09-17-2012, 09:04 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Lg 42pa4500 through cable vision through Pvr cable box through hdmi 16x9 ,native setting
Energy saving off
Expert1
Contrast 55
Brightness 65
Hsharp 20
Vsharp20
Color60
Tint g3
Dynamic contrast off
Gamma medium
Black level low
Film mode off
Gamma medium
Color gamut wide
Edge enhancer off
color temperature warm
2point
Low R-14 g-7 b11
High r 4 g-6 b-30
20 point
100: r 0 g -4 b -20
95: 0 -4 -5
-4 -4 -5
3 -4 -5
0 -4 -5
-11 -4 -5
5 -4 -5
5 -4 -5
5 -4 -5
5 -12 5
5 7 -5
5 5 -5
5 2 -5
5 3 1
-22 -7 -20
-8 1 -5
-22 -13 -6
-10 1 -15
-9 -3 -5
-14-9 -8
-29 -4 -5
I don't have a DVD player with a hdmi outlet so I calibrated it through component ,but I watch tv through cable box through hdmi.After calibration it looked too green in the dark areas for tv -so I toned the greens down in 2 point and 20point .I know hdmi and component look different by I tried it anyway.I do notice every little imperfection unfortunately sometimes I admit.
Vic12345 is offline
post #16 of 19 Old 09-18-2012, 04:51 AM
Scottthehat's Avatar
How did you do the 2pt and 20pt, the only way is with a meter,
sharp lcd 42"samsung ps59d550 plasma,onkyo 875/606,sherrwood 945 avr,sony md/cd/ps3,toshiba hd dvd/bluray,panasonic blu-ray,wharfdale front/center/15" sub+2 12",eltax liberty rears x2(7.1),jamo 12" fronts + rears,sky hd,teac td, spyder 4tvhd + chromapure calibration stuff. nikon d700/d300 + pro glas
Scottthehat is offline
post #17 of 19 Old 09-18-2012, 05:47 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I used an iPad which is close to 6500k with grays bars and video essentials DVD with gray bars and tried to get them to look the same on the tv.first the 2 point then the 20 point.
I notice level 5 adjusts the color of the black bars.The color of the bars are greenish or reddish purple depending on channel and the brightness control.The lcds seemed easier to calibrate than this plasma.
Vic12345 is offline
post #18 of 19 Old 09-18-2012, 06:49 AM
wallydog's Avatar
I only used the 2 point method and eye balled it using the inner patterns or gray screens . and am very happy with the grays .
Here are my settings , all eye balled. HDMI Roku
Energy savings - off
Expert 1
Contrast 83
Brightness 60
H sharp 12
V sharp 8
Color 42
Tint 0
Noise reduction off
Black level low
Color gamut standard
Edge enhancer off
Color temp medium
Method 2 Point
High
Red -14 Green -12 Blue -8
Low
Red -14 Green -14 Blue -10
In color management I made adjustments to Saturation only
Red -12 Green -6 Blue -4 Cyan -3 Magenta -8 Yellow -2
These settings are very similar to the OTA TV settings I use although I set britness to 53 - 55 .
I am very happy with these settings , and the whites seem normal . I like lower color settings I feel It gives a more natural look to the picture .
I used a color bar I found on Netflix to do the Saturation settings .
The outline problem with football games may be caused by your sharpness settings being too high.
wallydog is offline
post #19 of 19 Old 09-18-2012, 01:13 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
seems like a high contrast setting.A bit torch mode.Depends how bright the room is too.Mine is never overly bright.I have had sharpness 40 and it looks good but brings out every wrinkle on a person.
I tried to match iPad color bars Up with tv channels color bars adjusting color managements luminance tint saturation and ended up with some real bad outlines around people so I just set everything back to 0 except the red is too purple so adjusted tint.
Vic12345 is offline
