wall mounting panasonic tc-p54s1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-06-2012, 08:47 PM - Thread Starter
ldhiii's Avatar
I am mounting my panasonic tc-p54s1 on the wall and can't figure out which holes on the back of the tv I am supposed to attach the bracket to? I have searched this forum and google but have found no answers. There are 4 screws on the back spaced about 12 inches vertically and 19 3/4 inches horizontally apart. Are these the right screws to take out and attach my bracket to? The only other screws are towards the bottom where the current pedestal stand is attached. Thanks.
ldhiii is offline
post #2 of 2 Old 09-07-2012, 04:42 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
On my 54G10 there's 4 large head plastic phillips head screws that you can take out and inside are metal inserts for your mounting screws. There's nothing else on the back like them so that should be it. Make sure your screws aren't too long so you don't go through the panel or a board. I'd gently insert the screws without the mount and make sure they go below the installed height if the mount were there, if not use spacers/washers or shorter bolts. G/L
whipit is offline
Panasonic Viera S1 Series Tc P54s1 54 Inch 1080p Plasma Hdtv
