I think I lost a part to my LG Plasma Pedestal, or I have no idea what I'm doing. Help please! - AVS Forum | Home Theater Discussions And Reviews
Old 09-06-2012, 09:07 PM - Thread Starter
Godinster's Avatar
So I've got a bit of an issue. My previous two apartments allowed TVs to be mounted but the current one does not. I'll be moving again in six months but in the mean time, I'd like to use my LG 50" plasma TV [LG50PK250]. I have not used the pedestal for the TV yet and my TV knowledge is lacking but I just unpacked everything and I can't seem to figure out how the hell to mount the TV on the pedestal.
The TV needs a flat piece that I'm guessing goes into the pedestal for support but clearly the round pedestal doesn't just "go in" to the TV but looks like it needs said added piece. Am I missing something here? I don't recall throwing anything out when I bought the TV but it was over a year ago and I went straight into mounting it after purchasing it.
http://imgur.com/xbx4l
http://i.imgur.com/tQmyH.jpg
The first picture is one I found on eBay, looks identical to my pedestal. If I am indeed missing a piece, where would the best place be to purchase one without spending an arm and a leg? I'm in Canada so eBay options are limited and/or extremely pricey for shipping.
tl;dr - I don't know what the **** I'm doing and/or I lost a piece to my pedestal.
Godinster is offline
Old 09-07-2012, 08:57 AM
lorenzo1000's Avatar
Check out the manual on line:
http://www.lg.com/us/support-product/lg-50PK250#
Lorenzo
lorenzo1000 is offline
Old 09-07-2012, 10:16 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
If you still have the box, check the Styrofoam for the plate.
sheshechic is offline
Old 09-07-2012, 11:03 AM - Thread Starter
Godinster's Avatar
Unfortunately I don't still have the box.
Old 09-07-2012, 06:04 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Dang. I'd try contacting Panasonic then. Or if you can make or get a template, or get the specifications, a metal shop can make one for you at probably less than $20.
Old 09-07-2012, 06:24 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
You're recommendation for what to do is spot on, the company you told him to call is not. The OP has an LG not a Panny. biggrin.gif
HLdan is offline
Old 09-07-2012, 06:35 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Oops. *blush*
Old 09-07-2012, 07:46 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
It does look like you need an upright plate that attaches to the base then slides into the slot on the underside of the TV (my LG LCD TV at work has a similar base). You may be able to buy a replacment plate from LG's parts department or one of their authorized local TV repair centers (either have them special order it or maybe they have an old base in their shop from a broken/unrepairable TV).
This place has some used bases but not sure if any of them would be compatible with your particular model. It's possible that your base is shared with several other models.
http://www.tvpartsguy.com/servlet/the-Plasma--fdsh--LCD-TV-Stands-cln-LG/s/1/Categories
Godinster likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
