Panasonic VT50 vs Samsung E8000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-13-2012, 07:15 AM - Thread Starter
mystik610's Avatar
Looking to pick up a plasma and have come down to these two. This will be in a light controlled, dedicated media room (no windows). Any thoughts?
mystik610 is offline
post #2 of 6 Old 09-13-2012, 07:51 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Have you read the official threads for these two models to see which is the best fit for your particular needs/sources/content etc? There are a lot existing posts comparing these two but the bottom line is that you have to weigh the strengths and weaknesses of each display against one another and pick the one that fits your wants and needs better. The Panny does some things better and the Sammy does other things better and that's all been discussed a lot around here already.
Panny: Better blacks, better colors, brighter screen, but 720p content/sources look soft.
Sammy: Better processing and crisper image, but slightly poorer colors and poorer black level.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 09-13-2012, 10:35 AM
swillis55's Avatar
A bit fague and a better choice of words could have been used. A better description would be that colour accuracy is slightly better on the Panasonic but is subjective and many may only see the difference in side by side comparisons. Again, blacks are deeper on the Panny, especially in a light controlled environment. There is nothing "poor" with the colours or blacks on the Samsung.
swillis55 is offline
post #4 of 6 Old 09-13-2012, 04:13 PM
BillP's Avatar
Quoted: 259 Post(s)
Liked: 201
The VT50 won the VE shootout against all 2012 top displays, and generally gets the best reviews.
BillP is offline
post #5 of 6 Old 01-22-2013, 04:30 AM
ipodchicken's Avatar
I need to buy a new tv. My 4 year old samsung A850 lcd is dying and a big brown spot is visible in light scenes and white images like snow and sky.
I really want to go plasma because of the screen uniformity. That was the a850s biggest problem. I was able to dial the screen in so that it was very accurate in regards to color, but if I had one complaint it would be black levels and screen uniformity.
I'm considering either the e8000 or the VT50. The VT50 has been getting stellar reviews but I fear the possibility of image retention or worse; burn in.
Is the e8000 comparable to the VT50? Does the VT50 have less image retention problems than the GT50 and ST50? How does the VT50 compare to the E8000 in a moderately lit room by one relatively bright lamp?
Sorry for all the questions. Its just hard to go into best buy considering all those factors that typically won't be noticed until a week after use anyway. I really appreciate all the help.
EDIT: typo
ipodchicken is offline
post #6 of 6 Old 01-22-2013, 04:44 AM
Jay Mammoth's Avatar
Quoted: 30 Post(s)
Liked: 35
Originally Posted by ipodchicken View Post
I need to by a new tv. My 4 year old samsung A850 lcd is dying and a big brown spot is visible in light scenes and white images like snow and sky.
The fact that your Samsung is dying after only 4 years would put me off of their sets. I've been buying Panny plasmas for years and they are all still going strong. The VT50 is awesome.
Jay Mammoth is offline
