Small Plasma in bright room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-13-2012, 05:39 PM - Thread Starter
Greg_R's Avatar
I'm looking for a TV to place in our living room. The maximum physical width is 39.5" (so most/all 42" TVs would fit). I would like the picture quality / black levels of a plasma later at night but am concerned about the reflection off the screen. Question: Is there a 42" plasma with a screen with minimal reflection? Sunlight will be in the room during daytime viewing. Thanks!
Greg
Greg_R is offline
post #2 of 6 Old 09-13-2012, 11:51 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I just got a 42in plasma(the top of set is roughly 5ft above eye level) and was worried about reflection too.the walls are light yellow and have 3 different lights with shades with 1thatS brightest let's light through shade And onto wall 100-150 watt and it isn't too bad.I think the key is to have multiple lights in different locations so the light is Not all bright in one spot.the light does take way the black details a little if your really looking for it.
Real high watt lights could be a different story.
Vic12345 is offline
post #3 of 6 Old 09-14-2012, 07:27 AM
homerging's Avatar
Quoted: 31 Post(s)
Have you thought of looking for a P42ST30 second hand?
homerging is offline
post #4 of 6 Old 09-14-2012, 08:04 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Greg
There are only a few 42" Plasmas being made this year and none of them have any sort of Anti-Reflective Filter. Last year's ST30 series was the last 42 incher with an AR Filter.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 6 Old 09-14-2012, 08:21 AM
ttwomotor's Avatar
I think you will find turning side to side or a slight tilting of the display can make a big difference.
ttwomotor
ttwomotor is offline
post #6 of 6 Old 09-14-2012, 09:36 PM - Thread Starter
Greg_R's Avatar
The retailers I checked did not have this one in stock.
This TV is in a cabinet (hence the size restriction) with side doors. I think I could slide it back (cabinet depth was built for a CRT) and eliminate a lot of light reflection issues....
Greg_R is offline
