Sanyo 50" plasma power turns on then off? - AVS Forum | Home Theater Discussions And Reviews
Old 09-13-2012, 08:15 PM - Thread Starter
Maverick530's Avatar
I got this new plasma Tv since its broken from my aunt and i hope i can fix it,
whats going on is that when i push the power button (on the Tv it self or the Remote) the power light turns on for a few seconds (about 5-6) and then turns off again. So far i took off the back of the tv and was looking around and from what i see, none of the capacitors are blown, and i ended up taking off the whole power board and noticed that its still all perfectly green on the other side, so no discoloration.
There are two capacitors that i question that are blown since they feel a little uneven when i run my finger on the top of them how ever i believe that its just because they are the bigger ones and are probably made a little diffrently maybe, when looking at them they look perfectly fine.
so, anyone else have this problem
Tv: Sanyo 50" plasma
Model: Dp50749
Made in 2010
Maverick530 is offline
