panasonic ut50 default white balance value - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-18-2012, 05:59 PM - Thread Starter
klhaus's Avatar
I Mest up the wrong white balance setting in the service menu of my ut50 can someone tells me the default value for default normal and warm please
klhaus is offline
post #2 of 5 Old 09-19-2012, 02:28 AM
iBrad's Avatar
From the service manual:
WB-ADJ
R-CUT 80
G-CUT 80
B-CUT 80
R-DRV DF
G-DRV FF
B-DRV 7C
ALL-CUT 80
ALL-DRV FF
service manual download:
http://elektrotanya.com/panasonic_tc-p55ut50_ch_gpf15du.pdf/download.html
http://elektrotanya.com/?q=showresult
iBrad is offline
post #3 of 5 Old 09-19-2012, 02:51 AM
iBrad's Avatar
Go to this thread:
http://www.avsforum.com/t/1412033/the-official-panasonic-ut50-settings-issues-thread
iBrad is offline
post #4 of 5 Old 09-19-2012, 04:23 AM - Thread Starter
klhaus's Avatar
Thanks a lot
klhaus is offline
post #5 of 5 Old 09-19-2012, 06:28 AM
chunon's Avatar
Quoted: 2466 Post(s)
Liked: 2208
WB-ADJ
R-CUT 80
G-CUT 80
B-CUT 80
R-DRV DF
G-DRV FF
B-DRV 7C
ALL-CUT 80
ALL-DRV FF
The white balance setting are different from set to set, put on a 480i or 480p source and check the SD color space those should match what you had in HD.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
