Is white clipping/whitecrush common on plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-19-2012, 07:51 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I have a lg 42pa4500 (first plasma I've ever bought $400 plus tax).I've got this white crush/clipping on bright whites that bothers me a bit(I have to keep the contrast quite dim to prevent it).I don't want to take it back to the store,but I don't want a malfunctioning one.It crushes the blacks a bit like most tvs I've seen.It has a lot of positives I like about this tv.I don't like returning tvs if another one is going to have the same problem and going through the breakin slides again.
I only have a couple days to decide whether to return the tv too the store.
IS WHITE CLIPPING/WHITECRUSH A COMMON ISSUE ON PLASMA TVS?
Comments opinions appreciated
Vic12345 is offline
post #2 of 10 Old 09-20-2012, 01:16 AM
JForge's Avatar
Look at it this way . . . there's a enough range in the CONTRAST settings to take it into W-C range. So that means it's possible to set it to JUST-BELOW W-C level and get the brightest picture possible.
My old Pio and new Panny can both do that . . and I get the best, brightest picture possible for each set.
Regards . . . Jim
GT30 "Custom" Settings: http://www.controlcal.com/forum/showpost.php?p=6392
GT30 "THX" Settings: http://www.controlcal.com/forum/showpost.php?p=6393
GT30 "Vivid" Settings: http://www.controlcal.com/forum/showpost.php?p=6402
JForge is offline
post #3 of 10 Old 09-20-2012, 02:25 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Thanks JForge.I haven't tried the white clipping patterns yet.I guess I need to in order to get the best contrast setting, then make decision on whether to keep it..By the lack of responses I'm assuming white clipping is not a MAJOR issue.It wasn't as noticeable on the lcds I had.
Reducing the contrast Too much to stop the white clipping seems like it makes clipping more noticeable,besides making it dim.
Vic12345 is offline
post #4 of 10 Old 09-20-2012, 10:03 AM
JForge's Avatar
Reducing the contrast too much to stop the white clipping seems like it makes clipping more noticeable, besides making it dim.
Reducing the contrast will never make W-C "more noticeable" . . . just makes the picture dimmer!
For my 55GT30 panny, setting the contrast 85 - 88 or over [in the CUSTOM mode] puts the picture into the W-C onset.
Regards . . . Jim
JForge is offline
post #5 of 10 Old 09-20-2012, 02:35 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Not sure what the deal is with LG, but most Panasonic pdp's contrast levels are calibrated close to 100% in the both the standard and cinema modes, reducing any chance for white clipping. Even when using a using a grey scale test pattern on my C2 in the custom mode, I notice no clipping at maximum contrast even with a brightness setting close to 60%
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #6 of 10 Old 09-20-2012, 07:45 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
This plasma does not handle the brightwhites as well as the two lcds I had.There is more white clipping, and when white patches/ sections are next to darker shades the blacks are dark black and the white is over bright...The transition from dark black to the lighter blacks isn't real smooth( I am only calibrating by eye but am experienced).
I should of said when i reduce the contrast it loses too much brightness in comparison to the white clipping/ over bright whites you get rid of.
Just trying to decide whether too keep it or return it.
Vic12345 is offline
post #7 of 10 Old 09-20-2012, 10:11 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Personally, I think you would probably be happier with a Samsung or Panasonic. I'm not a big fan of LG pdp's.
Ian
mailiang is offline
post #8 of 10 Old 09-20-2012, 11:12 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Ian[/quote
Hi Ian would I be happier with a Samsung d450? And why?
Sometimes I look at this tv
In a dark room and it is impressive good..motion is good but hockey shows some blur.
Vic12345 is offline
post #9 of 10 Old 09-21-2012, 09:02 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Ian[/quote
If your looking for better motion performance you may want to consider a higher end model. I've never had motion blur on my 720p Panny, but if you're use to the higher brightness of an LCD, a Samsung would probably be a better choice.
Ian
mailiang is offline
post #10 of 10 Old 09-21-2012, 02:12 PM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Thanks for the quick reply
Vic12345 is offline
